Author: quozl Date: Mon Oct 22 06:22:25 2012 New Revision: 3378 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3378
Log: OLPC XO-4 - indentation fix, no effective change.
Modified: cpu/arm/olpc/cl4/testitems.fth
Modified: cpu/arm/olpc/cl4/testitems.fth ============================================================================== --- cpu/arm/olpc/cl4/testitems.fth Mon Oct 22 06:01:35 2012 (r3377) +++ cpu/arm/olpc/cl4/testitems.fth Mon Oct 22 06:22:25 2012 (r3378) @@ -21,24 +21,25 @@ icon: leds.icon rom:leds.565
-: cpu-item ( -- ) " /cpu" mfg-test-dev ; -: battery-item ( -- ) " /battery" mfg-test-dev ; -: spiflash-item ( -- ) " /flash" mfg-test-dev ; -: memory-item ( -- ) " /memory" mfg-test-dev ; -: usb-item ( -- ) " /usb/hub" mfg-test-dev ; -: int-sd-item ( -- ) " int:0" mfg-test-dev ; -: ext-sd-item ( -- ) " ext:0" mfg-test-dev ; -: rtc-item ( -- ) " /rtc" mfg-test-dev ; -: display-item ( -- ) " /display" gfx-test-dev ; -: audio-item ( -- ) " /audio" mfg-test-dev ; -: camera-item ( -- ) " /camera" gfx-test-dev ; -: wlan-item ( -- ) " /wlan" mfg-test-dev ; -: timer-item ( -- ) " /timer" mfg-test-dev ; -: touch-item ( -- ) " /touchscreen" mfg-test-dev - " mouse" mfg-test-dev ; -: keyboard-item ( -- ) " keyboard" mfg-test-dev ; -: switch-item ( -- ) " /accelerometer" mfg-test-dev " /switches" mfg-test-dev ; -: leds-item ( -- ) " /leds" mfg-test-dev ; +: cpu-item ( -- ) " /cpu" mfg-test-dev ; +: battery-item ( -- ) " /battery" mfg-test-dev ; +: spiflash-item ( -- ) " /flash" mfg-test-dev ; +: memory-item ( -- ) " /memory" mfg-test-dev ; +: usb-item ( -- ) " /usb/hub" mfg-test-dev ; +: int-sd-item ( -- ) " int:0" mfg-test-dev ; +: ext-sd-item ( -- ) " ext:0" mfg-test-dev ; +: rtc-item ( -- ) " /rtc" mfg-test-dev ; +: display-item ( -- ) " /display" gfx-test-dev ; +: audio-item ( -- ) " /audio" mfg-test-dev ; +: camera-item ( -- ) " /camera" gfx-test-dev ; +: wlan-item ( -- ) " /wlan" mfg-test-dev ; +: timer-item ( -- ) " /timer" mfg-test-dev ; +: touch-item ( -- ) " /touchscreen" mfg-test-dev + " mouse" mfg-test-dev ; +: keyboard-item ( -- ) " keyboard" mfg-test-dev ; +: switch-item ( -- ) " /accelerometer" mfg-test-dev + " /switches" mfg-test-dev ; +: leds-item ( -- ) " /leds" mfg-test-dev ;
: olpc-test-menu-items ( -- ) 0 to #mfgtests
