Author: wmb Date: Mon Aug 29 03:46:46 2011 New Revision: 2486 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2486
Log: OLPC XO-1.75 - improvements to suspend/resume code; still not 100% working.
Modified: cpu/arm/mmp2/dramrecal.fth
Modified: cpu/arm/mmp2/dramrecal.fth ============================================================================== --- cpu/arm/mmp2/dramrecal.fth Mon Aug 29 03:36:56 2011 (r2485) +++ cpu/arm/mmp2/dramrecal.fth Mon Aug 29 03:46:46 2011 (r2486) @@ -58,20 +58,102 @@ end-code here ddr-recal - constant /ddr-recal
-h# d000.0000 constant memctrl-pa -h# d000.0000 constant memctrl-va -h# d100.0000 constant sram-pa -h# d100.0000 constant sram-va -sram-va h# 2.0000 + constant 'ddr-recal +label ddr-self-refresh ( r0:memctrl-va -- ) + mov r1, #0x1 \ Block all data requests + str r1, [r0, #0x7e0] \ SDRAM_CTRL14
-: ddr-recal-to-sram ( -- ) + ldr r1, [r0, #0x120] \ USER_INITIATED_COMMAND0 + bic r1, r1, #0xc0 \ USER_SR_REQUEST field + orr r1, r1, #0x40 \ Enter Self Refresh value + str r1, [r0, #0x120] \ USER_INITIATED_COMMAND0 + + \ This block was commented-out in the Linux code, and the value is incorrect for OLPC in any case + \ mov r1, #0x03000000 \ PAD_TERM_SWITCH_MODE: Termination disabled + \ orr r1, r1, #0x000a \ ODT{1,0}_SWITCH_MODE: Termination controlled by Read and Write enables + \ str r1, [r0, #0x770] \ SDRAM_CTRL7_SDRAM_ODT_CTRL2 + +[ifdef] notdef + ldr r1, [r0, #0x1e0] \ PHY_CTRL8 + bic r1,r1,#0x07700000 \ PHY_ADCM_ZPDRV: 0 PHY_ADCM_ZNDRV: 0 (Disable drivers 6:0) + str r1, [r0, #0x1e0] \ PHY_CTRL8 +[then] + + set r2, #0xfe086000 + set r3, #0xfe050000 + str r2, [r3] \ Final write to SP votes + + mcr p15,0,r0,7,10,4 \ Data Synchronization Barrier +\ dsb \ Data Synchronization Barrier + wfi \ Wait for interrupt + +[ifdef] notdef + ldr r1, [r0, #0x1e0] \ PHY_CTRL8 + orr r1,r1,#0x07700000 \ PHY_ADCM_ZPDRV: 7 PHY_ADCM_ZNDRV: 7 (Enable drivers 6:0) + str r1, [r0, #0x1e0] \ PHY_CTRL8 +[then] + + \ This block was commented-out in the Linux code, and the value is incorrect for OLPC in any case + \ mov r1, #0x02000000 \ PAD_TERM_SWITCH_MODE: Termination enabled during all reads + \ orr r1, r1, #0x000a \ ODT{1,0}_SWITCH_MODE: Termination controlled by Read and Write enables + \ str r1, [r0, #0x770] \ SDRAM_CTRL7_SDRAM_ODT_CTRL2 + + mov r1, #0x80000000 \ PHY_SYNC_EN + str r1, [r0, #0x240] \ PHY_CTRL14 + + ldr r1, [r0, #230] \ PHY_CTRL13 + orr r1,r1,#0xf0000000 \ DLL_RESET_TIMER: 15*256 memory clocks +\ mov r1, #0xf0000000 \ DLL_RESET_TIMER: 15*256 memory clocks +\ orr r1, r1, #0x0040 \ DLL_PHSEL: 4 (45 + 4*3 = 57 degrees) - adjust? + str r1, [r0, #230] \ PHY_CTRL13 + + mov r1, #0x20000000 \ PHY_DLL_RESET + str r1, [r0, #0x240] \ PHY_CTRL14 + + mov r1, #0x40000000 \ DLL_UPDATE_EN + str r1, [r0, #0x240] \ PHY_CTRL14 + + ldr r1, [r0, #0x120] \ USER_INITIATED_COMMAND0 + bic r1, r1, #0xc0 \ USER_SR_REQUEST field + orr r1, r1, #0x80 \ Exit Self Refresh value + str r1, [r0, #0x120] \ USER_INITIATED_COMMAND0 + + ldr r1, [r0, #0x80] \ SDRAM_CTRL1 + orr r1, r1, #0x40 \ DLL_RESET + str r1, [r0, #0x80] \ SDRAM_CTRL1 + + mov r1, #0x01000000 \ Chip select 0 + orr r1, r1, #0x0100 \ USER_LMR0_REQ - Initiate Mode Register Set + str r1, [r0, #0x120] \ USER_INITIATED_COMMAND0 + + \ ldr r1, [r0, #0x120] \ USER_INITIATED_COMMAND0 + \ bic r1, r1, #0xc0 \ USER_SR_REQUEST field + \ orr r1, r1, #0x80 \ Exit Self Refresh value + \ str r1, [r0, #0x120] \ USER_INITIATED_COMMAND0 + + mov r1, #0x0 \ Unblock data requests + str r1, [r0, #0x7e0] \ SDRAM_CTRL14 + + mov pc, lr +end-code +here ddr-self-refresh - constant /ddr-self-refresh + +memctrl-pa constant memctrl-va + +: ddr-code-to-sram ( -- ) memctrl-pa h# c02 or memctrl-va map-section \ Map the memory controller - sram-pa h# c0e or sram-va map-section \ Make the code cacheable + +\ sram is already mapped by initmmu.fth +\ sram-pa h# c0e or sram-va map-section \ Make the code cacheable + ddr-recal 'ddr-recal /ddr-recal move + 'ddr-recal /ddr-recal sync-cache + + ddr-self-refresh 'ddr-self-refresh /ddr-self-refresh move + 'ddr-self-refresh /ddr-self-refresh sync-cache ;
stand-init: Setup DDR3 recalibration - ddr-recal-to-sram + ddr-code-to-sram ;
\ Call this from OFW to perform a recalibration @@ -82,6 +164,259 @@ mov pc,r1 c;
+\ Call this from OFW to enter self-refresh +code do-self-refresh ( -- ) + set r0,`memctrl-va #` \ Memory controller virtual address + set r1,`'ddr-self-refresh #` \ Address of ddr-self-refresh routine in SRAM + mov lr,pc + mov pc,r1 +c; + +: +apbc ( offset -- io-offset ) h# 01.5000 + ; +: +apmu ( offset -- io-offset ) h# 28.2800 + ; +: +mpmu ( offset -- io-offset ) h# 05.0000 + ; +: +scu ( offset -- io-offset ) h# 28.2c00 + ; +: +icu ( offset -- io-offset ) h# 28.2000 + ; + +: io-set ( mask offset -- ) dup io@ rot or swap io! ; +: io-clr ( mask offset -- ) dup io@ rot invert and swap io! ; + +: apbc-clr-rst ( offset -- ) +apbc 4 swap io-clr ; +: apbc-set-rst ( offset -- ) +apbc 4 swap io-set ; + +: disable-apbc-clks ( -- ) + \ 3 h# 38 +apbc io-clr \ GPIO + 3 h# 74 +apbc io-clr \ MPMU + 3 h# 78 +apbc io-clr \ IPC + 3 h# 90 +apbc io-clr \ THSENS1 + + \ h# 38 apbc-set-rst + h# 74 apbc-set-rst \ MPMU + h# 78 apbc-set-rst \ IPC + h# 90 apbc-set-rst \ THSENS1 +; +: enable-apbc-clks ( -- ) + \ 3 h# 38 +apbc io-set \ GPIO + 3 h# 74 +apbc io-set \ MPMU + 3 h# 78 +apbc io-set \ IPC + 3 h# 90 +apbc io-set \ THSENS1 + + \ h# 38 apbc-clr-rst + h# 74 apbc-clr-rst \ MPMU + h# 78 apbc-clr-rst \ IPC + h# 90 apbc-clr-rst \ THSENS1 +; +: disable-scu-clks ( -- ) + 0 h# 64 +scu io! \ SCU_AXIFAB_CKGT_CTRL0 - Close AXI fabric clock gate + 0 h# 68 +scu io! \ SCU_AXIFAB_CKGT_CTRL1 + h# f0 h# 1c +scu io-set \ SCU_MCB_CONF +; +: enable-scu-clks ( -- ) + h# 3003003 h# 64 +scu io! \ SCU_AXIFAB_CKGT_CTRL0 - Open AXI fabric clock gate + h# 0303030 h# 68 +scu io! \ SCU_AXIFAB_CKGT_CTRL1 + h# f0 h# 1c +scu io-clr \ SCU_MCB_CONF +; +: disable-apmu-clks ( -- ) + h# 3f h# d8 +apmu io-clr \ PMUA_MSPRO_CLK_RES_CTRL + h# 1fffd h# dc +apmu io-clr \ PMUA_GLB_CLK_RES_CTRL +\ 0 h# 68 +apmu io! \ PMUA_WTM_CLK_RES_CTRL + h# 9 h# 5c +apmu io-clr \ PMUA_USB_CLK_RES_CTRL +; +: enable-apmu-clks ( -- ) + h# 3f h# d8 +apmu io-set \ PMUA_MSPRO_CLK_RES_CTRL + h# 1fffd h# dc +apmu io-set \ PMUA_GLB_CLK_RES_CTRL +\ h# 1b h# 68 +apmu io! \ PMUA_WTM_CLK_RES_CTRL + h# 9 h# 5c +apmu io-set \ PMUA_USB_CLK_RES_CTRL +; +: disable-mpmu-clks ( -- ) + h# a010 h# 1024 +mpmu io! \ MPMU_ACGR + + h# a010 h# 0024 +mpmu io! \ MPMU_CGR_SP ??? + +\ h# 2000.0000 h# 414 +mpmu io-clr \ MPMU_PLL2_CTRL1 + h# 8000.0000 h# 0040 +mpmu io-clr \ MPMU_ISCCR1 + h# 8000.0000 h# 0044 +mpmu io-clr \ MPMU_ISCCR2 +; +: enable-mpmu-clks ( -- ) + h# dffe.fffe h# 1024 +mpmu io! \ MPMU_ACGR +\ h# 2000.0000 h# 0414 +mpmu io-set \ MPMU_PLL2_CTRL1 + h# 8000.0000 h# 0040 +mpmu io-set \ MPMU_ISCCR1 + h# 8000.0000 h# 0044 +mpmu io-set \ MPMU_ISCCR2 +; +: disable-twsi-clks ( -- ) + \ set RST in APBC_TWSIx_CLK_RST registers + +[ifdef] notdef + \ just disable TWSI1 clk rather than reset it since it's needed to access PMIC onkey + \ when system is waken up from low power mode */ + 0 4 +apbc io! \ Disable TWSI1 clock +[else] + h# 04 apbc-set-rst \ TWSI1 +[then] + h# 08 apbc-set-rst \ TWSI2 + h# 0c apbc-set-rst \ TWSI3 + h# 10 apbc-set-rst \ TWSI4 + h# 7c apbc-set-rst \ TWSI5 + h# 80 apbc-set-rst \ TWSI6 +; +: enable-twsi-clks ( -- ) +[ifdef] notdef + 3 4 +apbc io! \ Enable TWSI1 clock +[else] + h# 04 apbc-clr-rst \ TWSI1 +[then] + h# 08 apbc-clr-rst \ TWSI2 + h# 0c apbc-clr-rst \ TWSI3 + h# 10 apbc-clr-rst \ TWSI4 + h# 7c apbc-clr-rst \ TWSI5 + h# 80 apbc-clr-rst \ TWSI6 +; +: disable-clks ( -- ) + disable-twsi-clks + disable-apbc-clks + disable-scu-clks + disable-apmu-clks + disable-mpmu-clks +; +: enable-clks ( -- ) + enable-mpmu-clks + enable-apmu-clks + enable-scu-clks + enable-apbc-clks + enable-twsi-clks +; + +\ Wakeup ports - from datasheet page 718 +\ WAKEUP0: CAWAKE (MIPI-HSI wakeup) +\ WAKEUP1: Audio Island +\ WAKEUP2: GPIO +\ WAKEUP3: Keypress,Trackball,Rotary +\ WAKEUP4: Timers, RTC ALARM, WDT +\ WAKEUP5: USB PHY +\ WAKEUP6: SDH1_CD, SDH3_CD, MSP_INS +\ WAKEUP7: PMIC INT +5 value sleep-depth +: setup-wakeup-sources ( -- mask ) + h# 0002.0094 h# 4c +mpmu io! \ RTC_ALARM, WAKEUP7, WAKEUP4, WAKEUP2 +\ h# 0002.0094 h# 104c +mpmu io! \ RTC_ALARM, WAKEUP7, WAKEUP4, WAKEUP2 ??? + h# ff08.7fff ( mask ) \ Enable all wakeup ports +; +: block-irqs ( -- ) 1 h# 110 +icu io! ; + +0 value save-apcr +0 value save-idlecfg + +: restore-run-state ( -- ) + save-apcr h# 1000 +mpmu io! ( ) \ Restore APCR + save-idlecfg h# 18 +apmu io! ( ) \ Restore IDLE_CFG +; +: setup-sleep-state ( -- ) + \ begin mmp2_pm_enter_lowpower_mode(state) + + h# 1000 +mpmu io@ to save-apcr + h# 18 +apmu io@ to save-idlecfg + + save-apcr ( apcr ) + h# ac08.0000 invert and ( apcr' ) \ Clear AXISD, SLPEN, DDRCORSD, APBSD, VCXOSD + + sleep-depth 5 >= if \ state at least POWER_MODE_SYS_SLEEP (turn off oscillator) + h# 0008.0000 or ( apcr' ) \ Set VCXOSD + then + + h# 2000.0000 0 +mpmu io-clr \ In SP, clear SLPEN - we might set it later + + sleep-depth 4 >= if \ state at least POWER_MODE_CHIP_SLEEP (turn off most of SoC) + h# 2008.0000 0 +mpmu io-set \ In SP, also set SLPEN, VCXOSD + h# 2000.0000 or ( apcr' ) \ Set SLPEN + setup-wakeup-sources and ( apcr' ) + then + + sleep-depth 3 >= if \ state at least POWER_MODE_APPS_SLEEP (turn off slow IO) + h# de00.0000 0 +mpmu io-set \ In SP, set AXISD, resvd, SPSD, DDRCORSD, APBSD resvd, + h# 0400.0000 or ( apcr' ) \ Set APBSD + then + + h# 8030.0020 h# 14 +apmu io! ( apcr ) \ IN PMUA_SP_IDLE_CFG, set , DIVIDER_RESET_EN, SP_DIS_MC_SW_REQ, SP_MC_WAKE_EN, TCM_STATE_RETAIN + + sleep-depth 2 >= if \ state at least POWER_MODE_APPS_IDLE (turn off fast IO and DDR) + h# 8800.0000 or ( apcr' ) \ Set AXISD, DDRCORSD + then + + h# 5200.0000 or ( apcr' ) \ Set DSPSD (bit 30, reserved), SPSD (bit 28), BBSD (bit 25, resvd) + + save-idlecfg 1 invert and ( apcr idle ) \ PMUA_MOH_IDLE + + sleep-depth 2 >= if \ state at least POWER_MODE_APPS_IDLE + h# 0000.0020 or ( apcr idle' ) \ PJ_PWRDWN + then + + sleep-depth 1 >= if \ state at least POWER_MODE_CORE_EXTIDLE + h# 3000.0000 invert and ( apcr idle' ) \ PJ_ISO_MODE_CNTRL - isolation controlled by processor logic and active + h# 000a.0000 or ( apcr idle' ) \ 2 L2 power switches, 1 L1 power switch, 3 core power switches + then + + h# 0020.0000 or ( apcr idle' ) \ PJ_DIS_MC_SW_REQ - disable idle entry using software register bits + h# 0010.0000 or ( apcr idle' ) \ PJ_MC_WAKE_EN - wake memory controller when core wakes + + 0 h# b0 +apmu io! ( apcr idle ) \ PMUA_MC_HW_SLP_TYPE - self-refresh power down + + h# 18 +apmu io! ( apcr ) \ Set IDLE_CFG register + h# 1000 +mpmu io! ( ) \ Set APCR register + + \ end mmp2_pm_enter_lowpower_mode(state) +; + +: screen-dark + " screen-ih iselect h# 12 mode! 0 h# 190 lcd! iunselect" eval \ Saves 1.05W + 0 h# 4c +apmu io! \ Kill the display clocks - saves 100 mW + \ 0 h# 54 +apmu io! \ Kill the SDIO 0 clocks - insignificant savings + \ 0 h# 58 +apmu io! \ Kill the SDIO 1 clocks - insignificant savings + d# 34 gpio-clr \ Kill the WLAN power - saves 100 mW +; +: stdin-idle-on ['] safe-idle to stdin-idle d# 15 enable-interrupt ; +: stdin-idle-off ['] noop to stdin-idle install-uart-io d# 15 disable-interrupt ; + +: str ( -- ) + stdin-idle-off + 5 h# 38 +mpmu io! \ Use 32 kHz clock instead of VCXO for slow clock + +\ OLPC: Unmask main PMU interrupt - don't know if this is necessary +\ h# 400 h# 174 +icu io-clr +\ d# 35 enable-interrupt + +\ The PMIC_INT line is unconnected on XO-1.75. Normally it would come from the EC, +\ presumably for the purpose of waking on a keystroke. +\ 4 enable-interrupt \ Route PMIC interrupt to PJ4 IRQ +\ 2 h# 168 +icu io-clr \ Enable PMIC interrupt + + setup-sleep-state + +\ h# 00c0.0000 h# 8c +apmu io-set \ Power down CoreSight SRAM + + \ TODO - need to power down sram/l2$ + \ mmp2_cpu_disable_l2(0); + \ outer_cache.flush_range(0, -1ul); + + \ TODO - handle low power island? + + disable-clks + + \ begin mmp2_cpu_do_idle() + block-irqs ( ) \ Block IRQs - will be cleared by PMU + do-self-refresh ( ) + + restore-run-state + \ end mmp2_cpu_do_idle() + + enable-clks + + ." STR out" cr + \ mmp2_cpu_enable_l2(0); + + \ idle_cfg &= (~PMUA_MOH_SRAM_PWRDWN); + stdin-idle-on +; + \ LICENSE_BEGIN \ Copyright (c) 2011 FirmWorks \
