Author: wmb Date: 2009-10-02 23:59:51 +0200 (Fri, 02 Oct 2009) New Revision: 1386
Added: cpu/x86/pc/mmxdot.fth cpu/x86/pc/mmxdotcode.fth Modified: cpu/x86/pc/ramtest.fth Log: X86 - Added early startup diagnostic routines that use MMX registers to avoid the need for memory, while preserving the general register state.
Added: cpu/x86/pc/mmxdot.fth =================================================================== --- cpu/x86/pc/mmxdot.fth (rev 0) +++ cpu/x86/pc/mmxdot.fth 2009-10-02 21:59:51 UTC (rev 1386) @@ -0,0 +1,75 @@ +\ See license at end of file +purpose: Assemble a call to the mm0dot routine, preserving general registers + +: mmxsave ( -- ) " ax mm7 movd" eval ; +: mmxrestore ( -- ) " mm7 ax movd" eval ; +: mmxarg ( ea -- ) " mm0 movd" eval ; \ Put numeric argument in mm0 +: mmx#arg ( immed -- ) " # ax mov ax mm0 movd" eval ; +: mmx#arg1 ( immed -- ) " # ax mov ax mm1 movd" eval ; +: mmxcall ( name$ -- ) + here asm-base - asm-origin + d# 10 + " # ax mov" eval \ 5 bytes - return address in ax + eval " #) jmp" eval \ 5 bytes +; +: mmxdot ( ea -- ) + mmxsave + mmxarg + " mm0dot" mmxcall + mmxrestore +; +: #mmxdot ( immed -- ) + mmxsave + mmx#arg " mm0dot" mmxcall + mmxrestore +; +: mmxemit ( char-ea -- ) + mmxsave + mmxarg " mm0emit" mmxcall + mmxrestore +; +: #mmxemit ( immed-char -- ) + mmxsave + mmx#arg " mm0emit" mmxcall + mmxrestore +; +: #mmxdump ( adr-immed len-immed -- ) + mmxsave + mmx#arg1 mmx#arg " mm0dump" mmxcall + mmxrestore +; +: mmxdump ( adr-ea len-immed -- ) + mmxsave ( adr-ea len-immed ) + \ Do ea arg first in case it refers to ax; otherwise mmx#arg1 would clobber ax + >r mmx#arg r> ( len-immed ) + mmx#arg1 " mm0dump" mmxcall + mmxrestore +; +: #mmxcfg-dump ( adr-immed len-immed -- ) + mmxsave + mmx#arg1 mmx#arg " mm0cfg-dump" mmxcall + mmxrestore +; +: mmxcr ( -- ) carret #mmxemit linefeed #mmxemit ; + +\ LICENSE_BEGIN +\ Copyright (c) 2009 FirmWorks +\ +\ Permission is hereby granted, free of charge, to any person obtaining +\ a copy of this software and associated documentation files (the +\ "Software"), to deal in the Software without restriction, including +\ without limitation the rights to use, copy, modify, merge, publish, +\ distribute, sublicense, and/or sell copies of the Software, and to +\ permit persons to whom the Software is furnished to do so, subject to +\ the following conditions: +\ +\ The above copyright notice and this permission notice shall be +\ included in all copies or substantial portions of the Software. +\ +\ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, +\ EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF +\ MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND +\ NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE +\ LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION +\ OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION +\ WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. +\ +\ LICENSE_END
Added: cpu/x86/pc/mmxdotcode.fth =================================================================== --- cpu/x86/pc/mmxdotcode.fth (rev 0) +++ cpu/x86/pc/mmxdotcode.fth 2009-10-02 21:59:51 UTC (rev 1386) @@ -0,0 +1,226 @@ +\ See license at end of file +purpose: Low-level numeric output for tracing startup code + +\ Requires MMX registers + +protected-mode + +label mm0emit ( mm0: char ax: retadr -- ) + ax mm1 movd + dx mm4 movd + + h# 3fd # dx mov begin dx al in h# 40 # al and 0<> until + h# 3f8 # dx mov mm0 ax movd al dx out + h# 3fd # dx mov begin dx al in h# 40 # al and 0<> until + + mm4 dx movd + mm1 ax movd + + ax jmp +end-code + +label mm0dot ( mm0: n ax: retadr -- ) + ax mm1 movd + bx mm2 movd + cx mm3 movd + dx mm4 movd + + mm0 bx movd + 8 # cx mov + + begin + bx 4 # rol + bl al mov + + h# f # al and + d# 10 # al cmp + >= if + ascii a d# 10 - # al add + else + ascii 0 # al add + then + + al ah mov + + h# 3fd # dx mov begin dx al in h# 40 # al and 0<> until + 3f8 # dx mov ah al mov al dx out + loopa + h# 3fd # dx mov begin dx al in h# 40 # al and 0<> until + h# 3f8 # dx mov h# 20 # al mov al dx out + h# 3fd # dx mov begin dx al in h# 40 # al and 0<> until + + mm4 dx movd + mm3 cx movd + mm2 bx movd + mm1 ax movd + + ax jmp +end-code + +label mm0dump ( mm0: adr mm1: len ax: retadr -- ) + ax mm6 movd + bx mm5 movd + cx mm4 movd + dx mm3 movd + si mm2 movd + + mm0 si movd + mm1 cx movd + + begin + al lods + al bl mov + + bl al mov + + 4 # al shr + h# f # al and + d# 10 # al cmp + >= if + ascii a d# 10 - # al add + else + ascii 0 # al add + then + + al ah mov + + h# 3fd # dx mov begin dx al in h# 40 # al and 0<> until + 3f8 # dx mov ah al mov al dx out + + bl al mov + + h# f # al and + d# 10 # al cmp + >= if + ascii a d# 10 - # al add + else + ascii 0 # al add + then + + al ah mov + + h# 3fd # dx mov begin dx al in h# 40 # al and 0<> until + 3f8 # dx mov ah al mov al dx out + + h# 3fd # dx mov begin dx al in h# 40 # al and 0<> until + + si ax mov h# f # al and 0= if + h# 0d # al mov h# 3f8 # dx mov al dx out + h# 3fd # dx mov begin dx al in h# 40 # al and 0<> until + h# 0a # al mov h# 3f8 # dx mov al dx out + else + h# 20 # al mov h# 3f8 # dx mov al dx out + then + + h# 3fd # dx mov begin dx al in h# 40 # al and 0<> until + cx dec 0= until + + mm2 si movd + mm3 dx movd + mm4 cx movd + mm5 bx movd + mm6 ax movd + + ax jmp +end-code + +label mm0cfg-dump ( mm0: adr mm1: len ax: retadr -- ) + ax mm6 movd + bx mm5 movd + cx mm4 movd + dx mm3 movd + si mm2 movd + + mm0 si movd + mm1 cx movd + + begin + si ax mov + h# 7fff.fffc # ax and + h# 8000.0000 # ax or + h# cf8 # dx mov + ax dx out + si dx mov + 3 # dx and + h# cfc # dx add + dx al in + si inc + + al bl mov + + bl al mov + + 4 # al shr + h# f # al and + d# 10 # al cmp + >= if + ascii a d# 10 - # al add + else + ascii 0 # al add + then + + al ah mov + + h# 3fd # dx mov begin dx al in h# 40 # al and 0<> until + 3f8 # dx mov ah al mov al dx out + + bl al mov + + h# f # al and + d# 10 # al cmp + >= if + ascii a d# 10 - # al add + else + ascii 0 # al add + then + + al ah mov + + h# 3fd # dx mov begin dx al in h# 40 # al and 0<> until + 3f8 # dx mov ah al mov al dx out + + h# 3fd # dx mov begin dx al in h# 40 # al and 0<> until + + si ax mov h# f # al and 0= if + h# 0d # al mov h# 3f8 # dx mov al dx out + h# 3fd # dx mov begin dx al in h# 40 # al and 0<> until + h# 0a # al mov h# 3f8 # dx mov al dx out + else + h# 20 # al mov h# 3f8 # dx mov al dx out + then + + h# 3fd # dx mov begin dx al in h# 40 # al and 0<> until + cx dec 0= until + + mm2 si movd + mm3 dx movd + mm4 cx movd + mm5 bx movd + mm6 ax movd + + ax jmp +end-code + +\ LICENSE_BEGIN +\ Copyright (c) 2009 FirmWorks +\ +\ Permission is hereby granted, free of charge, to any person obtaining +\ a copy of this software and associated documentation files (the +\ "Software"), to deal in the Software without restriction, including +\ without limitation the rights to use, copy, modify, merge, publish, +\ distribute, sublicense, and/or sell copies of the Software, and to +\ permit persons to whom the Software is furnished to do so, subject to +\ the following conditions: +\ +\ The above copyright notice and this permission notice shall be +\ included in all copies or substantial portions of the Software. +\ +\ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, +\ EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF +\ MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND +\ NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE +\ LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION +\ OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION +\ WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. +\ +\ LICENSE_END
Modified: cpu/x86/pc/ramtest.fth =================================================================== --- cpu/x86/pc/ramtest.fth 2009-10-02 21:58:33 UTC (rev 1385) +++ cpu/x86/pc/ramtest.fth 2009-10-02 21:59:51 UTC (rev 1386) @@ -1,9 +1,9 @@ \ This can be included in-line in the early startup code, just \ after memory controller turn-on, to verify basic RAM sanity.
+ramtest-start #mmxdot mmxcr + ascii I report ascii n report ascii c report -carret report linefeed report -\ here asm-base - ResetBase + .x cr ramtest-start # ax mov begin ax 0 [ax] mov @@ -11,15 +11,18 @@ ramtest-end # ax cmp 0= until
+ascii . report + ramtest-start # ax mov begin 0 [ax] bx mov - ax bx cmp <> if - ax di mov + \ ax bx cmp <> if +ax bx cmp <> if + ax mmxdot + bx mmxdot + 0 [ax] mmxdot ascii B report ascii A report ascii D report - di ax mov dot #) call - 0 [di] ax mov dot #) call -1 [if] \ Fire up C Forth +0 [if] \ Fire up C Forth dcached-base 6 + 0 206 set-msr \ Dcache base address, write back /dcached negate h# 800 + f 207 set-msr \ Dcache size \ This region is for CForth @@ -42,9 +45,7 @@
h# ffff.0000 # ax mov ax jmp [then] - - - begin again + begin hlt again then 4 # ax add ramtest-end # ax cmp @@ -53,7 +54,6 @@ carret report linefeed report
ascii P report ascii a report ascii t report ascii 5 report -carret report linefeed report ramtest-start # ax mov begin h# 55555555 # 0 [ax] mov @@ -61,14 +61,16 @@ ramtest-end # ax cmp 0= until
+ascii . report + ramtest-start # ax mov begin 0 [ax] bx mov h# 55555555 # bx cmp <> if - ( bx ax mov ) dot #) call + ax mmxdot + bx mmxdot ascii B report ascii A report ascii D report - h# ffff.0000 # ax mov ax jmp \ CForth - begin again + begin hlt again then 4 # ax add ramtest-end # ax cmp @@ -77,7 +79,6 @@ carret report linefeed report
ascii P report ascii a report ascii t report ascii A report -carret report linefeed report ramtest-start # ax mov begin h# aaaaaaaa # 0 [ax] mov @@ -85,12 +86,16 @@ ramtest-end # ax cmp 0= until
+ascii . report + ramtest-start # ax mov begin 0 [ax] bx mov h# aaaaaaaa # bx cmp <> if + ax mmxdot + bx mmxdot ascii B report ascii A report ascii D report - begin again + begin hlt again then 4 # ax add ramtest-end # ax cmp
