Author: wmb Date: 2008-09-30 22:27:58 +0200 (Tue, 30 Sep 2008) New Revision: 950
Modified: cpu/x86/pc/linux.fth Log: Linux support - move ramdisk to top of memory for compatibility with recent kernels that use boot protocols >= 2.03 . The previous ramdisk location (at load-base, e.g. 0x800000) was vulnerable to being overwritten by kernel initialization, especially for large kernels. This helps when using recent Fedora kernels, for example.
Modified: cpu/x86/pc/linux.fth =================================================================== --- cpu/x86/pc/linux.fth 2008-09-30 20:23:34 UTC (rev 949) +++ cpu/x86/pc/linux.fth 2008-09-30 20:27:58 UTC (rev 950) @@ -167,7 +167,19 @@ cr ( throw-code r: xt ) r> to load-path ( throw-code ) throw - loaded to /ramdisk to ramdisk-adr + + loaded to /ramdisk ( adr ) + + \ Move ramdisk to top of memory + + \ The initrd_addr_max field appeared in boot protocol 2.03 + h# 22c +lp l@ ( adr ramdisk-limit ) + ?dup if 1+ else h# 8000.0000 then ( adr ramdisk-limit ) + + memory-limit umin /ramdisk - ( adr new-ramdisk-adr ) + dup to ramdisk-adr ( adr new-ramdisk-adr ) + + /ramdisk move ( ) ; : cv-load-ramdisk ( -- ) " ramdisk" eval dup 0= if 2drop exit then ( name$ ) @@ -180,7 +192,6 @@ 0 0 1meg -1 mmu-map ( ) \ Make the parameter area accessible [then] 0 +lp h# 1000 0 mem-claim drop \ Play nice with memory reporting - 0 +lp h# 1000 erase ;
0 value linux-loaded?
