Author: quozl Date: Fri Aug 17 05:53:07 2012 New Revision: 3188 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3188
Log: OLPC - libertas antenna test, comply with new firmware specification that requires ordering of antenna selection commands. Now works on XO-4 A2.
Modified: dev/libertas.fth
Modified: dev/libertas.fth ============================================================================== --- dev/libertas.fth Fri Aug 17 01:27:49 2012 (r3187) +++ dev/libertas.fth Fri Aug 17 05:53:07 2012 (r3188) @@ -1692,12 +1692,18 @@ outbuf-wait drop ;
+\ When changing from antenna diversity to single antenna, +\ issue ACT_SET_TX before ACT_SET_RX. : set-antenna ( antenna -- ) - 1 ( ACT_SET_RX ) rf-antenna ( ) + dup 2 ( ACT_SET_TX ) rf-antenna ( antenna ) + 1 ( ACT_SET_RX ) rf-antenna ( ) ;
+\ When changing from single antenna to antenna diversity, +\ issue ACT_SET_RX before ACT_SET_TX. : set-antenna-diversity ( -- ) h# ffff 1 ( ACT_SET_RX ) rf-antenna + h# ffff 2 ( ACT_SET_TX ) rf-antenna ;
: get-antenna ( -- antenna ) @@ -2197,18 +2203,20 @@ : .rx-antenna ( antenna -- ) 6 rshift case - b# 00 of ." 0" endof - b# 01 of ." 1" endof - b# 10 of ." d" endof + b# 00 of ." 0" endof + b# 01 of ." 1" endof + b# 10 of ." d" endof \ diversity + b# 11 of ." ?" endof endcase ;
: .tx-antenna ( antenna -- ) 6 rshift case - b# 00 of ." 0" endof - b# 01 of ." 1" endof - b# 10 of ." r" endof + b# 00 of ." 0" endof + b# 01 of ." 1" endof + b# 10 of ." r" endof \ same antenna as receive antenna + b# 11 of ." ?" endof endcase ;
@@ -2221,8 +2229,8 @@ get-antenna ( base antenna ) hex ." ant" .antenna ( base ) - ." rx " h# 3f bbp-reg@ .rx-antenna - ." tx " h# 40 bbp-reg@ .tx-antenna + ." rx " h# 3f bbp-reg@ .rx-antenna ( base ) + ." tx " h# 40 bbp-reg@ .tx-antenna ( base ) base ! ;
@@ -2236,16 +2244,16 @@ ." keys: (0,1,2,3,d,a,s,q)" cr begin d# 100 ms show-antenna key? if - cr show-antenna key + cr key case - h# 71 ( q ) of cr exit endof - h# 1b of cr exit endof - h# 30 ( 0 ) of ." antenna to 0" 0 set-antenna endof - h# 31 ( 1 ) of ." antenna to 1" 1 set-antenna endof - h# 32 ( 2 ) of ." antenna to 2" 2 set-antenna endof - h# 33 ( 3 ) of ." antenna to 3" 3 set-antenna endof - h# 64 ( d ) of ." diversity" cr set-antenna-diversity endof - h# 61 ( a ) of ." associate" cr close open drop endof + h# 71 ( q ) of ." quit" exit endof + h# 1b of exit endof + h# 30 ( 0 ) of ." antenna to 0 " 0 set-antenna cr endof + h# 31 ( 1 ) of ." antenna to 1 " 1 set-antenna cr endof + h# 32 ( 2 ) of ." antenna to 2 " 2 set-antenna cr endof + h# 33 ( 3 ) of ." antenna to 3 " 3 set-antenna cr endof + h# 64 ( d ) of ." diversity " set-antenna-diversity cr endof + h# 61 ( a ) of ." associate " close open drop endof h# 73 ( s ) of ta-scan endof endcase then
