Author: wmb Date: Wed Oct 3 23:59:49 2012 New Revision: 3352 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3352
Log: OLPC x86 - fixed build regression for platforms where the WLAN driver is in FCode.
Modified: dev/mmc/sdhci/mv8686/sdio.fth
Modified: dev/mmc/sdhci/mv8686/sdio.fth ============================================================================== --- dev/mmc/sdhci/mv8686/sdio.fth Wed Oct 3 23:59:11 2012 (r3351) +++ dev/mmc/sdhci/mv8686/sdio.fth Wed Oct 3 23:59:49 2012 (r3352) @@ -20,7 +20,11 @@ instance defer get-ctrl-port ( -- port# ) instance defer get-write-port ( -- port# )
-0 0 2value default-fw$ +\ FCode doesn't have 2value so we do it this way +0 value fw-adr +0 value fw-len +: default-fw$ ( -- adr len ) fw-adr fw-len ; +: set-default-fw$ ( adr len -- ) to fw-len to fw-adr ;
0 value ioport d# 256 constant blksz \ Block size for data tx/rx @@ -90,7 +94,7 @@ ['] 0 to get-ctrl-port ['] 0 to get-write-port
- " rom:sd8686.bin" to default-fw$ + " rom:sd8686.bin" set-default-fw$ " mv8686" ?set-module-property
\ This really depends on the firmware that we load, but we don't want @@ -173,7 +177,7 @@ ['] mv8787-rx-ready? to rx-ready? ['] mv8787-get-ctrl-port to get-ctrl-port ['] mv8787-get-write-port to get-write-port - " rom:mv8787.bin" to default-fw$ + " rom:mv8787.bin" set-default-fw$ " mv8787" ?set-module-property false to helper? true to multifunction?
