Author: wmb Date: 2008-11-11 00:56:29 +0100 (Tue, 11 Nov 2008) New Revision: 1000
Modified: cpu/x86/pc/neptune/fw.bth dev/dnet/dnet.fth Log: Neptune ethernet driver - initial checkin of working version.
Modified: cpu/x86/pc/neptune/fw.bth =================================================================== --- cpu/x86/pc/neptune/fw.bth 2008-11-08 06:01:40 UTC (rev 999) +++ cpu/x86/pc/neptune/fw.bth 2008-11-10 23:56:29 UTC (rev 1000) @@ -237,6 +237,31 @@ fload ${BP}/dev/geode/usb.fth ' noop to go-hook \ this is required for accessing USB device from client program (e.g. VME)
+devalias net /ethernet + +8 buffer: mac-address-buf +: random-mac-address ( -- adr len ) + mac-address-buf @ 0= if + \ Get a pseudo-random number + + \ Seed it with the real time clock and the timestamp counter + time&date xor xor xor xor xor ( seed ) + tsc@ xor xor ( seed' ) + + \ Scramble it a bit with a linear congruence + d# 1103515245 * d# 12345 + h# 7FFFFFFF and ( rn1 ) + dup mac-address-buf ! ( rn1 ) + d# 1103515245 * d# 12345 + h# 7FFFFFFF and ( rn2 ) + mac-address-buf 3 + ! ( ) + + \ Turn off the multicast bit and turn on the locally-assigned bit + mac-address-buf c@ h# fe and 2 or mac-address-buf c! + then + + mac-address-buf 6 +; +' random-mac-address to system-mac-address + \ false to stand-init-debug? true to stand-init-debug?
Modified: dev/dnet/dnet.fth =================================================================== --- dev/dnet/dnet.fth 2008-11-08 06:01:40 UTC (rev 999) +++ dev/dnet/dnet.fth 2008-11-10 23:56:29 UTC (rev 1000) @@ -1,330 +1,405 @@ -purpose: Ethenet Driver for Lattice Ethernet device (dnet) +purpose: Driver for DAVE Ethernet FPGA (Lattice IP) \ See license at end of file
-hex -headers +" ethernet" name +" Lattice,tri-speed-eth" encode-string " compatible" property +" network" device-type
-: copyright ( -- ) - ." Copyright (c) 2008 Dave Srl. All Rights Reserved." cr -; +h# 100000 constant /irq-regs \ Total size of adapter�s register bank +h# 10000000 constant /mac-regs \ Total size of adapter�s register bank
-\ Register offsets from the adapter�s base address +\ Define "reg" property +\ PCI Configuration Space +my-address my-space encode-phys 0 encode-int encode+ 0 encode-int encode+
-\ TODO remove the following -0 constant control \ 1 byte W/O - writing one bits causes things to happen -2 constant unicast-addr \ 6 bytes R/W - Ethernet address for reception -8 constant xmit-status \ 1 byte - 0 => busy 1 => okay else => error -9 constant xmit-fifo \ 1 byte - write repetitively to setup packet -a constant xmit-len \ 16 bits - length of packet to send -c constant rcv-rdy \ 1 byte - count of waiting packets -d constant rcv-fifo \ 1 byte - read repetitively to remove first packet -e constant rcv-len \ 16 bits -10 constant local-addr \ 6 bytes R/O - Factory-assigned Ethernet address -\ until here +\ Memory Space Base Address Register 10 +my-address my-space h# 0200.0010 or encode-phys encode+ +0 encode-int encode+ /irq-regs encode-int encode+
+\ Memory Space Base Address Register 14 +my-address my-space h# 0200.0014 or encode-phys encode+ +0 encode-int encode+ /mac-regs encode-int encode+
-\ dnet register definition +\ \ PCI Expansion ROM - not present +\ my-address my-space h# 200.0030 or encode-phys encode+ +\ 0 encode-int encode+ h# 10.0000 encode-int encode+
-0 constant rx-len-fifo -4 constant rx-data-fifo -8 constant tx-len-fifo -c constant rx-data-fifo +" reg" property
-100 constant verid -104 constant intr-src -108 constant intr-enb -10c constant rx-status -110 constant tx-status -114 constant rx-frames-cnt -118 constant tx-frames-cnt -11c constant rx-fifo-th -120 constant tx-fifo-th -124 constant sys-ctl -128 constant pause-tmr +0 instance value chip +: map-regs ( -- ) + h# 0040.0000 0 my-space h# 14 + h# 0200.0000 or h# 1000 + " map-in" $call-parent to chip + 2 my-space 4 + " config-w!" $call-parent +; +: unmap-regs ( -- ) + 0 my-space 4 + " config-w!" $call-parent + chip h# 1000 " map-out" $call-parent +; +: reg@ ( offset -- l ) chip + rl@ ; +: reg! ( l offset -- ) chip + rl! ;
-200 constant macreg-data -204 constant macreg-addr -1 d# 31 << constant macreg-write +: rx-cmd-fifo@ ( -- l ) 0 reg@ ; +: rx-data-fifo@ ( -- l ) 4 reg@ ; +: tx-cmd-fifo! ( l -- ) 8 reg! ; +: tx-data-fifo! ( l -- ) h# c reg! ;
-\ TODO: dnet rx & tx statistics counter registers +: capa@ ( -- l ) h# 100 reg@ ;
+1 constant mdio +2 constant irq +4 constant gigabit +8 constant dma +h# 10 constant rmii
-\ macreg register definition -0 constant macreg-mode -2 constant macreg-rxtx-mode -4 constant macreg-max_pkt_size -8 constant macreg-igp -a constant macreg-mac_addr_0 -c constant macreg-mac_addr_1 -e constant macreg-mac_addr_2 -12 constant macreg-tx_rx_sts -14 constant macreg-gmii_mng_ctl -16 constant macreg-gmii_mng_dat +: intr-src@ ( -- l ) h# 104 reg@ ; +: intr-src! ( l -- ) h# 104 reg! ; +: intr-enb@ ( -- l ) h# 108 reg@ ; +: intr-enb! ( l -- ) h# 108 reg! ;
-100000 constant /regs \ Total size of adapter�s register bank -10000000 constant /real-regs \ Total size of adapter�s register bank +4 constant tx-dat-ae +h# 10 constant tx-fifo-f +h# 100 constant rx-cmd-af +h# 200 constant rx-cmd-ff +h# 400 constant rx-data-af +h# 1000 constant tx-smry +h# 2000 constant rx-smry +h# 4000 constant glob-enb +h# 8000 constant phy
-: map-in ( addr space size -- virt ) " map-in" $call-parent ; +: rx-status@ ( -- l ) h# 10c reg@ ; +: rx-status! ( l -- ) h# 10c reg! ;
-: map-out ( virt size -- ) " map-out" $call-parent ; +1 constant stat-rx-cmd-af +2 constant stat-rx-cmd-ff +4 constant stat-rx-data-f
-: my-w@ ( offset -- w ) my-space + " config-w@" $call-parent ; -: my-w! ( w offset -- ) my-space + " config-w!" $call-parent ; +: tx-status@ ( -- l ) h# 110 reg@ ; +: tx-status! ( l -- ) h# 110 reg! ;
-" ethernet" device-name -" Lattice,tri-speed-eth" encode-string " compatible" property -" network" device-type +4 constant stat-tx-data-ae +h# 10 constant stat-tx-fifo-f
-\ Some of Apple�s Open Firmware implementations have a bug in their map-in method. The -\ bug causes phys.lo and phys.mid to be treated as absolute addresses rather than -\ offsets even when working with relocatable addresses. -\ To overcome this bug, the Open Firmware Working Group in conjunction with Apple has -\ adopted a workaround that is keyed to the presence or absence of the add-range method -\ in the PCI node. If the add-range method is present in an Apple ROM, the map-in -\ method is broken. If the add-range property is absent, the map-in method behaves -\ correctly. -\ The following methods allow the FCode driver to accomodate both broken and working -\ map-in methods. -: map-in-broken? ( -- flag ) - \ Look for the method that is present when the bug is present - " add-range" my-parent ihandle>phandle ( adr len phandle ) - find-method dup if nip then ( flag ) \ Discard xt if present -; +: rx-fifo-th@ ( -- l ) h# 11c reg@ ; +: rx-fifo-th! ( l -- ) h# 11c reg! ; +: tx-fifo-th@ ( -- l ) h# 120 reg@ ; +: tx-fifo-th! ( l -- ) h# 120 reg! ; +: sys-ctl@ ( -- l ) h# 124 reg@ ; +: sys-ctl! ( l -- ) h# 124 reg! ;
-\ Return phys.lo and phys.mid of the address assigned to the PCI base address -\ register indicated by phys.hi . -: get-base-address ( phys.hi -- phys.lo phys.mid phys.hi ) - " assigned-addresses" get-my-property if ( phys.hi ) - ." No address property found!" cr - 0 0 rot exit \ Error exit - then ( phys.hi adr len ) - rot >r ( adr len ) ( r: phys.hi ) - \ Found assigned-addresses, get address - begin dup while ( adr len' ) \ Loop over entries - decode-phys ( adr len' phys.lo phys.mid phys.hi ) - h# ff and r@ h# ff and = if ( adr len' phys.lo phys.mid ) \ This one? - 2swap 2drop ( phys.lo phys.mid ) \ This is the one - r> exit ( phys.lo phys.mid phys.hi ) - else ( adr len� phys.lo phys.mid ) \ Not this one - 2drop ( adr len� ) - then ( adr len� ) - decode-int drop decode-int drop \ Discard boring fields - repeat - 2drop ( ) - ." Base address not assigned!" cr - 0 0 r> ( 0 0 phys.hi ) -; +8 constant rx-flush +h# 10 constant tx-flush
-\ String comparision -: $= ( adr0 len0 adr1 len1 -- equal? ) - 2 pick <> if 3drop false exit then ( adr0 len0 adr1 ) - swap comp 0= +defer us-delay +: set-delay ( -- ) + " us" $find 0= if 2drop ['] ms then to us-delay ;
-\ Define "reg" property -\ PCI Configuration Space -my-address my-space encode-phys 0 encode-int encode+ 0 encode-int encode+ +: be-w@ ( adr -- w ) dup 1+ c@ swap c@ bwjoin ; +: be-w! ( w adr -- w ) >r wbsplit r@ c! r> 1+ c! ;
-\ Memory Space Base Address Register 10 -my-address my-space 0200.0010 or encode-phys encode+ -0 encode-int encode+ /regs encode-int encode+ +: pause-tmr@ ( -- l ) h# 128 reg@ ; +: pause-tmr! ( l -- ) h# 128 reg! ; +: rx-fifo-wcnt@ ( -- l ) h# 12c reg@ ; +: tx-fifo-wcnt@ ( -- l ) h# 130 reg@ ;
-\ Memory Space Base Address Register 14 -my-address my-space 0200.0014 or encode-phys encode+ -0 encode-int encode+ /real-regs encode-int encode+ +: tmac@ ( reg# -- w ) h# 204 reg! 1 us-delay h# 200 reg@ ; +: tmac! ( w reg# -- ) swap h# 200 reg! h# 8000.0000 or h# 204 reg! 1 us-delay ;
-\ PCI Expansion ROM -my-address my-space h# 200.0030 or encode-phys encode+ -0 encode-int encode+ h# 10.0000 encode-int encode+ -" reg" property +: mode@ ( -- w ) 0 tmac@ ; +: mode! ( w -- ) 0 tmac! ;
--1 instance value chipbase --1 instance value real-chipbase +\ Mode register bits +1 constant gbit-en +2 constant fc-en +4 constant rx-en +8 constant tx-en
-: map-regs ( -- ) - map-in-broken? if - my-space h# 8200.0010 or get-base-address ( phys.lo phys.mid phys.hi ) - else - my-address my-space h# 200.0010 or ( phys.lo phys.mid phys.hi ) - then ( phys.lo phys.mid phys.hi ) +: tx-rx-ctl@ ( -- w ) 2 tmac@ ; +: tx-rx-ctl! ( w -- ) 2 tmac! ;
- /regs map-in to chipbase - 4 dup my-w@ 2 or swap my-w! \ Enable memory space - chipbase encode-int " address" property +\ tx-rx-ctl bits
- map-in-broken? if - my-space h# 8200.0010 or get-base-address ( phys.lo phys.mid phys.hi ) - else - my-address my-space h# 200.0014 or ( phys.lo phys.mid phys.hi ) - then ( phys.lo phys.mid phys.hi ) + 1 constant prms + 2 constant discard-fcs + 4 constant tx-dis-fcs + 8 constant receive-pause +h# 10 constant receive-mltcst +h# 20 constant hden +h# 40 constant drop-control +h# 80 constant receive-brdcst +h# 100 constant receive-short
- /real-regs map-in to real-chipbase - real-chipbase encode-int " real-address" property +: max-pkt-size@ ( -- w ) 4 tmac@ ; +: max-pkt-size! ( w -- ) 4 tmac! ;
-; +: ipg-val@ ( -- w ) 8 tmac@ ; +: ipg-val! ( w -- ) 8 tmac! ;
-: unmap-regs ( -- ) - 4 dup my-w@ 4 invert and swap my-w! \ Disable memory space - chipbase /regs map-out -1 to chipbase - real-chipbase /real-regs map-out -1 to chipbase - " address" delete-property +: mac-addr@ ( index -- w ) /w* h# a + tmac@ ; +: mac-addr! ( n index -- ) /w* h# a + tmac! ; + +: set-mac-addr ( adr len -- ) + drop + dup be-w@ 0 mac-addr! wa1+ + dup be-w@ 1 mac-addr! wa1+ + be-w@ 2 mac-addr! ; +: get-mac-addr ( adr 6 -- ) + drop + 0 mac-addr@ over be-w! wa1+ + 1 mac-addr@ over be-w! wa1+ + 2 mac-addr@ swap be-w! +;
-: e@ ( register -- byte ) real-chipbase 4000000 + + rb@ ; -: e! ( byte register -- ) real-chipbase 4000000 + + rb! ; -: ew@ ( register -- 16-bits ) real-chipbase 4000000 + + rw@ ; -: ew! ( 16-bits register -- ) real-chipbase 4000000 + + rw! ; -: el@ ( register -- 16-bits ) real-chipbase 4000000 + + rl@ ; -: el! ( 16-bits register -- ) real-chipbase 4000000 + + rl! ; +: tx-rx-stat@ ( -- w ) h# 12 tmac@ ; +: tx-rx-stat! ( w -- ) h# 12 tmac! ;
-: mac@ ( register -- 16-bits) - \ write address to address register - macreg-addr el! - \ read data register - macreg-data el@ -; +\ tx-rx-stat bits
-: mac! ( 16-bits register -- 16-bits ) - \ write data to data register - swap macreg-data el! - \ write address to address register - macreg-write or macreg-addr el! + 1 constant tx-idle + 2 constant pause-frame + 4 constant crc-error + 8 constant error-frame +h# 10 constant long-frame +h# 20 constant short-frame +h# 40 constant ipg-shrink +h# 80 constant multcst-frame +h# 100 constant brdcst-frame +h# 200 constant tagged-frame +h# 400 constant rx-idle
+: gmii-mng-ctl@ ( -- w ) h# 14 tmac@ ; +: gmii-mng-ctl! ( w -- ) h# 14 tmac! ; + +\ gmii-mng-ctl bits + +h# 2000 constant rw-phyreg +h# 4000 constant cmd-fin + +: gmii-mng-dat@ ( -- w ) h# 16 tmac@ ; +: gmii-mng-dat! ( w -- ) h# 16 tmac! ; + +: gmii-wait ( -- ) + d# 100 0 do + gmii-mng-ctl@ cmd-fin and if unloop exit then + d# 10 us-delay + loop + ." Lattice Ethernet - GMII_MNG_CTL stuck busy" cr + abort ;
-: control-on ( control-bit -- ) control e@ or control e! ; -: control-off ( control-bit -- ) invert control e@ and control e! ; +0 instance value phy# +: mii-read ( reg -- w ) + phy# bwjoin gmii-mng-ctl! ( ) + gmii-wait gmii-mng-dat@ +; +: mii-write ( n reg -- ) + swap gmii-mng-dat! ( reg ) + phy# bwjoin rw-phyreg or gmii-mng-ctl! ( ) + gmii-wait +; +: find-phy ( -- error? ) + h# 20 0 do + i to phy# + 2 mii-read h# ffff <> if false unloop exit then + loop + true +;
-: reset-chip ( -- ) 1 control e! ; -: receive-on ( -- ) 2 control-on ; -: return-buffer ( -- ) 4 control-on ; -: start-xmit ( -- ) 8 control-on ; -: promiscuous ( -- ) 10 control-on ; -: loopback-on ( -- ) 20 control-on ; -: loopback-off ( -- ) 20 control-off ; +: vlan-tag@ ( -- w ) h# 32 tmac@ ; +: vlan-tag! ( w -- ) h# 32 tmac! ;
-: receive-ready? ( -- #pkts-waiting ) rcv-rdy e@ ; -: wait-for-packet ( -- ) begin key? receive-ready? or until ; +: mlt-tab@ ( index -- w ) /w* h# 32 + tmac@ ; +: mlt-tab! ( n index -- ) /w* h# 32 + tmac! ;
-\ Create local-mac-address property from the information in the chip -map-regs -6 alloc-mem ( mem-addr ) -6 0 do local-addr i + rb@ over i + c! loop ( mem-addr ) -6 2dup encode-string " local-mac-address" property ( mem-addr 6 ) -free-mem -unmap-regs +: paus-op@ ( -- w ) h# 34 tmac@ ; +: paus-op! ( w -- ) h# 34 tmac! ;
-: initchip ( -- ) - reset-chip - \ Ask the host system for the station address and give it to the adapter - mac-address 0 do ( addr ) - dup i + c@ unicast-addr i + e! ( addr ) - loop drop - receive-on \ Enable reception +: link-down ( -- ) + mode@ rx-en tx-en or invert and mode! ;
-: net-init ( -- succeeded? ) - \ loopback-on loopback-test loopback-off if init-chip true else false then - true +: set/clear ( val bits set? -- val' ) + if or else invert and then ;
-\ Check for incoming Ethernet packets while using promiscuous mode. -: watch-test ( -- ) - ." Looking for Ethernet packets." cr - ." �.� is a good packet. �X� is a bad packet." cr - ." Press any key to stop." cr - begin - wait-for-packet - receive-ready? if - rcv-len ew@ 8000 and 0= if ." ." else ." X" then - return-buffer - then - key? dup if key drop then - until +: link-up ( gigabit? half-duplex? -- ) + tx-rx-ctl@ hden rot set/clear tx-rx-ctl! ( gigabit? ) + mode@ gbit-en rot set/clear ( mode' ) + rx-en tx-en or or mode! ( ) ;
-: (watch-net) ( -- ) - map-regs - promiscuous - net-init if watch-test reset-chip then - unmap-regs +: marvell-fixup ( -- ) h# 4148 h# 18 mii-write ; + +: reset-hw ( -- ) + fc-en mode! + d# 20 rx-fifo-th! + d# 25 tx-fifo-th! + rx-flush tx-flush or sys-ctl! + 1 ms + 0 sys-ctl! ;
-: le-selftest ( -- passed? ) - net-init - \ dup if net-off then +\ String comparision +: $= ( adr0 len0 adr1 len1 -- equal? ) + 2 pick <> if 3drop false exit then ( adr0 len0 adr1 ) + swap comp 0= ;
-external -: read ( addr requested-len -- actual-len ) - \ Exit if packet not yet available - receive-ready? 0= if 2drop -2 exit then - rcv-len ew@ dup 8000 and = if ( addr requested-len packet-len ) - 3drop return-buffer \ Discard bad packet - -1 exit - then ( addr requested-len packet-len ) +\ Handle some possible argument values +0 instance value promiscuous?
- \ Truncate to fit into the supplied buffer - min ( addr actual-len ) +0 instance value tftp-args +0 instance value tftp-len
- \ Note: For a DMA-based adapter, the driver would have to synchronize caches (e.g. - \ with "dma-sync") and copy the packet from the DMA buffer into the result buffer. +: parse-args ( -- ) + my-args begin ( rem$ ) + 2dup to tftp-len to tftp-args ( rem$ ) + dup while ( rem$ ) + ascii , left-parse-string ( rem$ head$ ) + 2dup " promiscuous" $= if true to promiscuous? else ( rem$ head$ ) +\ 2dup " loopback" $= if true to loopback? else ( rem$ head$ ) + 2drop 2drop exit ( ) + then ( rem$ head$ ) + 2drop ( rem$ ) + repeat ( rem$ ) + 2drop ( ) +;
- tuck bounds ?do rcv-fifo e@ i c! loop ( actual-len ) - return-buffer ( actual-len ) +\ Wait for autonegotiation complete. Returns true if the link is down. +: phy-wait ( -- error? ) + d# 500 0 do + 1 mii-read h# 20 and if false unloop exit then + 1 ms + loop + true ;
-: close ( -- ) reset-chip unmap-regs ; +\ Determine whether to use gigabit mode and half-duplex mode +\ based on information from the PHY
-: open ( -- ok? ) - map-regs - mac-address encode-string " mac-address" property - \ initchip - \ my-args " promiscuous" $= if promiscuous then +: link-type ( -- gigabit? half-duplex? ) + \ Merge together our 1000BT capabilites and the link partner's + 9 mii-read 2 lshift d# 10 mii-read and ( bits )
- \ Note: For a DMA-based adapter, the driver would have to allocate DMA memory for - \ packet buffers, construct buffer descriptor data structures, and possibly - \ synchronize caches (e.g. with "dma-sync"). - true + \ Gigabit if either 1000BT full duplex or 1000BT half duplex + dup h# c00 and if \ 1000BT ? ( bits ) + \ Half duplex if not full duplex + true swap h# 800 and 0= ( gigabit? half-duplex? ) + exit + then ( bits ) + drop ( ) + + false ( gigabit? ) + \ Merge our 10/100BT capabilities and the link partner's + 4 mii-read 5 mii-read and ( gigabit? bits ) + + \ 100BT FD? + dup h# 100 and if drop false exit then ( gigabit? bits ) + + \ 100BT HD? + dup h# 80 and if drop true exit then ( gigabit? bits ) + + \ Half duplex if not 10BT FD + h# 40 and 0= ( gigabit? half-duplex? ) ;
-: write ( addr len -- actual ) - begin xmit-status e@ 0<> until - \ Note: For a DMA-based adapter, the driver would have to copy the - \ packet into the DMA buffer and synchronize caches (e.g. with "dma-sync"). - \ Copy packet into chip - tuck bounds ?do i c@ xmit-fifo e! loop - \ Set length register - dup h# 64 max xmit-len ew! - start-xmit +: ?marvell-fix ( -- ) + 1 mii-read h# 0141 <> if exit then + 2 mii-read h# 0cc0 <> if exit then + h# 4148 h# 18 mii-write \ LINK1000 as Link LED, TX as activity LED ;
-: load ( addr -- len ) - " obp-tftp" find-package if ( addr phandle ) - my-args rot open-package ( addr ihandle|0 ) - else ( addr ) - 0 ( addr 0 ) - then ( addr ihandle|0 ) - dup 0= abort" Can�t open obp-tftp support package" ( addr ihandle ) +: setup-link ( -- okay? ) + find-phy if + ." Lattice Ethernet: Can't find the PHY" cr + false exit + then
- >r - " load" r@ $call-method ( len ) - r> close-package + ?marvell-fix + + phy-wait if ." Link down" cr false exit then + + link-type link-up + true ;
-: selftest ( -- failed? ) +: init-hw ( -- ) + reset-hw + + mac-address set-mac-addr + + tx-rx-ctl@ + promiscuous? if prms or then + \ Not supporting multicast yet + receive-pause or + receive-brdcst or + drop-control or + discard-fcs or + tx-rx-ctl! + intr-src@ drop \ Clear IRQs + 0 intr-enb! \ Disable IRQs +; +: open ( -- okay? ) map-regs - le-selftest 0= + set-delay + parse-args + init-hw + setup-link ( okay? ) +; + +: close ( -- ) + reset-hw \ Includes the effect of link-down unmap-regs ;
-: watch-net ( -- ) - selftest 0= if (watch-net) then +: read ( adr len -- actual ) + rx-fifo-wcnt@ d# 16 rshift if ( adr len ) + rx-cmd-fifo@ lwsplit ( adr len actual stats ) + h# df18 and ?dup if ( adr len actual error ) + ." RX packet error " .x cr ( adr len actual ) + 3drop -2 exit + then ( adr len actual ) + min tuck ( actual' adr actual' ) + bounds ?do rx-data-fifo@ i l! /l +loop + else + 2drop -2 + then ; -fcode-end
+d# 2048 constant dnet-fifo-size + +: write ( adr len -- actual ) + tuck ( actual adr len ) + over 3 and over 3 + + 2 rshift >r ( actual adr len r: #words ) + dnet-fifo-size r@ - ( actual adr len needed r: #words ) + begin dup tx-fifo-wcnt@ > until ( actual adr len needed r: #words ) + drop ( actual adr len ) + over 3 and d# 16 lshift + swap ( actual tx-cmd adr r: #words ) + 3 invert and r> /l* bounds ?do ( actual tx-cmd ) + i l@ tx-data-fifo! ( actual tx-cmd ) + /l +loop ( actual tx-cmd ) + tx-cmd-fifo! ( actual ) +; + +: load ( adr -- len ) + " obp-tftp" find-package if ( adr phandle ) + tftp-args tftp-len rot open-package ( adr ihandle|0 ) + else ( adr ) + 0 ( adr 0 ) + then ( adr ihandle|0 ) + + dup 0= if ." Can't open obp-tftp support package" abort then + ( adr ihandle ) + + >r + " load" r@ $call-method ( len ) + r> close-package +; + \ LICENSE_BEGIN -\ Copyright (c) 2008 Dave Srl +\ Copyright (c) 2008 FirmWorks \ \ Permission is hereby granted, free of charge, to any person obtaining \ a copy of this software and associated documentation files (the
