Author: wmb Date: Mon Jan 16 22:05:18 2012 New Revision: 2828 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2828
Log: struct.fth - added 2field for creating two fields with the same offset and size
Modified: forth/lib/struct.fth
Modified: forth/lib/struct.fth ============================================================================== --- forth/lib/struct.fth Mon Jan 16 22:05:14 2012 (r2827) +++ forth/lib/struct.fth Mon Jan 16 22:05:18 2012 (r2828) @@ -6,3 +6,9 @@ create over , + does> @ + ( base -- addr ) ; + +\ Create two name fields with the same offset and size +: 2field \ name name ( offset size -- offset' ) + 2dup field drop + field +;
