Author: wmb Date: Sat Aug 11 02:29:52 2012 New Revision: 3152 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3152
Log: OLPC ARM - refactor svn 3148 for stylistic consistency with other ec-version-dependent addresses. Should be no substantive difference.
Modified: cpu/arm/olpc/ecflash.fth cpu/arm/olpc/edi.fth
Modified: cpu/arm/olpc/ecflash.fth ============================================================================== --- cpu/arm/olpc/ecflash.fth Fri Aug 10 15:54:46 2012 (r3151) +++ cpu/arm/olpc/ecflash.fth Sat Aug 11 02:29:52 2012 (r3152) @@ -26,11 +26,7 @@ load-base swap ?ec-image-valid ; \ Tells the EC to auto-restart after power cycling -: set-ec-reboot ( -- ) - 1 - kb9010? if h# ff01 else h# f018 then - edi-b! -; +: set-ec-reboot ( -- ) 1 ecreboot edi-b! ; : ?reflash-ec-flags ( adr -- ) use-edi-spi ( adr ) edi-open-active ( adr ) \ avoids holding EC in reset
Modified: cpu/arm/olpc/edi.fth ============================================================================== --- cpu/arm/olpc/edi.fth Fri Aug 10 15:54:46 2012 (r3151) +++ cpu/arm/olpc/edi.fth Sat Aug 11 02:29:52 2012 (r3152) @@ -20,6 +20,7 @@ : efcmd ( -- reg# ) kb9010? if h# feac else h# fea7 then ; : efdat ( -- reg# ) kb9010? if h# feab else h# feaa then ; : rst8051 ( -- reg# ) kb9010? if h# ff14 else h# f010 then ; +: ecreboot ( -- reg# ) kb9010? if h# ff01 else h# f018 then ;
\ Issues with .py code \ A14:A8 should be A15:A8 several places
