Author: wmb Date: Tue Jul 12 11:17:29 2011 New Revision: 2346 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2346
Log: Checked in a file containing complex code for setting up the clocks on an MMP2. Might be useful some day; although much simpler code is currently in use.
Added: cpu/arm/mmp2/clocks-complex.fth
Added: cpu/arm/mmp2/clocks-complex.fth ============================================================================== --- /dev/null 00:00:00 1970 (empty, because file is newly added) +++ cpu/arm/mmp2/clocks-complex.fth Tue Jul 12 11:17:29 2011 (r2346) @@ -0,0 +1,308 @@ +purpose: A complex way to do MMP2 clock frequency setting based on Marvell code + +\ Our current chip_id is 00a0.a610 and stepping is 0000.4131 (A1) + +\ vcc pclk pdclk baclk xpclk dclk aclk name +create operating-points +decimal +1230 , 100 , 100 , 100 , 100 , 400 , 100 , \ "Ultra Low MIPS" +1230 , 200 , 200 , 200 , 200 , 400 , 200 , \ "Low MIPS" +1280 , 400 , 200 , 200 , 200 , 400 , 200 , \ "Video M MIPS" +1300 , 800 , 400 , 400 , 400 , 400 , 266 , \ "Video H MIPS" +1350 , 1001 , 500 , 500 , 500 , 400 , 266 , \ "Super H MIPS" +0 , +hex + +0 [if] +1300 , 800 , 400 , 400 , 400 , 400 , 200 , \ "Video H MIPS" - Z0/Z1 settings +1300 , 624 , 312 , 312 , 312 , 312 , 156 , \ "624MHz" - only for Z0 and Z1 steppings + + pj4-cc sp-cc fccr cgr pj4-cc-oct sp-cc-oct + cur 18fd96d9 8fd8241 3077313331 1077301101 + old 78fd8248 8fd8248 7077301110 1077301110 17.077.301.101 + cvr52ADXBCP 52ADXBpP +ok d# 100 find-op new-reg-values .s clear 878b86c3 88b86c3 800000 a000 20742703303 1042703303 +ok d# 200 find-op new-reg-values .s clear 87898241 8898241 800000 a000 20742301101 1042301101 +ok d# 400 find-op new-reg-values .s clear 87898240 8898240 800000 a000 20742301100 1042301100 +ok d# 800 find-op new-reg-values .s clear 87890240 8890240 20800000 8000 20742201100 1042201100 +ok d# 1001 find-op new-reg-values .s clear 87890240 8890240 40800000 c000 20742201100 1042201100 +[then] + +\ IDLE, EXTIDLE, APPS_IDLE, APPS_SLEEP, SYS_SLEEP all have vcc=1280 + +0 value 'op +: pclk ( -- mhz ) 'op 1 na+ @ ; +\ : pdclk ( -- mhz ) 'op 2 na+ @ ; \ This is effectively unused +: baclk ( -- mhz ) 'op 3 na+ @ ; +: xpclk ( -- mhz ) 'op 4 na+ @ ; +: dclk ( -- mhz ) 'op 5 na+ @ ; +: aclk ( -- mhz ) 'op 6 na+ @ ; +: datarate ( -- mhz ) dclk 2* ; + +: ~= ( n1 n2 -- flag ) - -2 2 between ; +: find-op ( mhz -- ) + operating-points begin dup @ while ( mhz adr ) + 2dup na1+ @ ~= if ( mhz adr ) + to 'op drop exit ( -- ) + then ( mhz adr ) + 7 na+ ( mhz adr' ) + repeat ( mhz adr ) + true abort" Can't find operating point" +; + +0 value old-dclk +0 value new-fccr +0 value pll-pj4-frequency +0 value pll-ad-frequency +0 value new-cgr + +: set-field ( val bits bit# -- val' ) lshift or ; +: >bit ( bit# -- ) 1 swap lshift ; +: set-bit ( val bit# -- val' ) >bit or ; + +create frequencies d# 400 , d# 800 , 0 , d# 26 , +: fccr>frequency ( source-id -- mhz ) frequencies swap na+ @ ; +: 'pll2-frequency ( -- adr ) frequencies 2 na+ ; + +create cgr-masks d# 13 >bit , d# 15 >bit , d# 14 >bit , 0 , +: fccr>cgr-mask ( source-id -- mhz ) cgr-masks swap na+ @ ; + +: frequency>fccr ( mhz -- fccr-bits ) + dup d# 26 = if drop 3 exit then \ Special case for VCXO frequency + d# 800 over mod 3 < if ( mhz ) \ Close to a divisor of 800 ? + d# 400 <= if 0 else 1 then ( fccr-bits ) + else ( mhz ) + 'pll2-frequency @ if ( mhz ) + drop ( ) + else ( mhz ) + 'pll2-frequency ! ( ) + then ( ) + 2 ( fccr-bits ) + then ( fccr-bits ) +; + +: mhz>source-frequency ( mhz fccr-bit# -- source-frequency ) + >r frequency>fccr ( fccr-bits r: fccr-bit# ) + dup r> lshift new-fccr or to new-fccr ( fccr-bits ) + dup fccr>cgr-mask new-cgr or to new-cgr ( fccr-bits ) + fccr>frequency ( source-frequency ) +; +: choose-pclk-source ( -- ) + pclk d# 29 mhz>source-frequency to pll-pj4-frequency ( ) +\ clip-pj4-clocks +; + +: choose-dclk-source ( -- ) + datarate d# 23 mhz>source-frequency to pll-ad-frequency ( ) +\ clip-ad-clocks +; + +\ The clock sources have been selected, so pll-pj4-frequency and pll-ad-frequency are valid +\ Calculate the various divisors and insert them into the appropriate fields for the +\ two clock control registers. +: compute-new-cc-regs ( -- pj4-cc sp-cc ) + 0 ( cc-reg ) + pclk if pll-pj4-frequency pclk / 1- 0 set-field then ( cc-reg' ) + xpclk if pll-pj4-frequency xpclk / 1- 9 set-field then ( cc-reg' ) + pll-pj4-frequency baclk / 1- baclk if 6 else 3 then set-field ( cc-reg' ) \ Either BA_CLK (6) or CS_CLK (3) + + datarate if pll-ad-frequency datarate / 1- d# 12 set-field then ( cc-reg' ) + aclk if pll-ad-frequency aclk / 1- d# 15 set-field then ( cc-reg' ) + +\ The lines following this block force both async bits to be set, so this conditional setting is irrelevant +\ pdclk datarate <> if d# 19 set-bit then \ Async2 if pdclock2 != DDRClk +\ baclk aclk <> if d# 23 set-bit then \ Async5 if baclk2 != aclk + + d# 19 set-bit ( cc-reg' ) \ PMUA_CC_MOH_ASYNC2 + d# 23 set-bit ( cc-reg' ) \ PMUA_CC_MOH_ASYNC5 + + \ Write a subset of the fields to the SP's clock control register before finishing the value for the PJ4's CC reg + dup d# 27 >bit or swap ( sp-cc-reg pj4-cc-reg ) \ PMUA_CC_SEA_SEA_ALLOW_SPD_CHG bit + others in PMUA_CC_SP + + pclk 0<> baclk 0<> or ( pdclk 0<> or ) xpclk 0<> or if d# 24 set-bit then ( cc-reg' ) \ PMUA_CC_MOH_MOH_FREQ_CHG_REQ + datarate if d# 25 set-bit then ( sp-cc-reg pj4-cc-reg' ) \ PMUA_CC_MOH_DDR_FREQ_CHG_REQ + aclk if d# 26 set-bit then ( sp-cc-reg pj4-cc-reg' ) \ PMUA_CC_MOH_BUS_FREQ_CHG_REQ +[ifdef] notdef + dup h# 0700.0000 and if d# 27 set-bit then ( sp-cc-reg pj4-cc-reg' ) +[then] + d# 31 set-bit ( sp-cc-reg pj4-cc-reg' ) \ PMUA_CC_MOH_MOH_RD_ST_CLEAR + swap ( pj4-cc-reg sp-cc-reg ) +; + +\ Assumes that 'op already points to an operating point table +: new-reg-values ( -- pj4-cc sp-cc fccr cgr ) + 0 to new-fccr 0 to new-cgr 'pll2-frequency off + choose-pclk-source + choose-dclk-source + +\ I think this write is deferred until the DDR clock setting step +\ writel(fccr, info->pmum_base + FCCR_OFF); + + compute-new-cc-regs ( pj4-cc sp-cc ) + new-fccr new-cgr ( pj4-cc sp-cc fccr cgr ) +; + +\ Beginning of section that accesses the hardware + +: +pmua ( -- adr ) h# d428.2800 + ; +: +pmum ( -- adr ) h# d405.0000 + ; + +: pmum-pll2cr ( -- adr ) h# 34 +pmum ; +: pmum-pll2-ctrl1 ( -- adr ) h# 414 +pmum ; +: get-pll2-frequency ( -- mhz ) + pmum-pll2cr l@ ( regval ) \ PMUM_PLL2CR + dup d# 19 5 bits ( regval refdiv ) + swap d# 10 9 bits ( refdiv fbdiv ) + 2+ d# 26 * ( refdiv numerator ) + swap 2+ / ( mhz ) +; +: reg-set ( mask -- ) >r r@ l@ or r> l! ; +: reg-clr ( mask -- ) >r r@ l@ swap invert and r> l! ; + +4 constant refdiv \ 4 is the only reference divisor value that is mentioned in the documentation + +: setup-pll2 ( freq -- ) + refdiv 2+ * d# 26 rounded-/ ( fbdiv ) + 1 d# 29 lshift pmum-pll2-ctrl1 reg-clr ( fbdiv ) \ make sure pll2 is in reset + + + pmum-pll2cr l@ ( fbdiv val ) + h# 100 invert and ( fbdiv val' ) \ PMUM_PLL2CR_PLL2_SW_EN off + dup pmum-pll2cr l! ( fbdiv val ) + + h# 0007.fc00 invert and refdiv d# 19 lshift or ( fbdiv val' ) + h# 00f8.0000 invert and swap d# 10 lshift or ( val' ) + + h# 200 or ( val' ) \ PMUM_PLL2CR_CTRL + dup pmum-pll2cr l! ( val ) + + h# 100 or ( val ) + pmum-pll2cr l! ( ) \ PMUM_PLL2CR_PLL2_SW_EN on + + 1 d# 29 lshift pmum-pll2-ctrl1 reg-set ( ) \ pll2 out of reset + + d# 20 ms \ C code uses 2M spins +; + +: ?change-pll2-frequency ( -- ) + 'pll2-frequency @ ?dup if ( mhz ) + dup get-pll2-frequency <> if ( mhz ) + setup-pll2 ( ) + else ( mhz ) + drop ( ) + then ( ) + then ( ) +; + +[ifdef] later +: set-sram-table ( table-adr table# -- ) + 4 lshift h# 8000.0000 or ( table-adr common-bits ) + #sram-table 0 do ( table-adr common-bits ) + over i 8 * + ( table-adr common-bits table-entry-adr ) + dup l@ h# c20 dmcu! ( table-adr common-bits table-entry-adr ) + la1+ l@ h# c30 dmcu! ( table-adr common-bits ) + over i or h# c00 dmcu! ( common-bits table-adr ) + loop ( table-adr common-bits ) + 2drop ( ) +; +: x-do-fcs ( cc-reg fccr dclk -- ) + dup old-dclk = if ( cc-reg fccr dclk ) + \ There is no need to do DDR recal if dclk is unchanged + drop ( cc-reg fccr ) + 0 ( cc-reg fccr pmua_mc_par_ctrl-val ) + else ( cc-reg fccr dclk ) + dup to old-dclk ( cc-reg fccr dclk ) + choose-ddr-table 0 set-sram-table ( cc-reg fccr ) + 4 ( cc-reg fccr pmua_mc_par_ctrl-val ) + then to pmua_mc_par_ctrl-val ( cc-reg fccr ) + + +\ STUFF +; +[then] +: do-fcs ( cc-reg fccr dclk -- ) + drop ." FCCR " .x ." CCR " .x cr +; + +: current-dclk ( -- mhz ) + 8 +pmum l@ d# 23 rshift 7 and fccr>frequency ( source-mhz ) + 4 +pmua l@ d# 12 rshift 7 and 1+ / +; + +: PMUcore2_hw_fc_seq ( -- ) + current-dclk to old-dclk +\ get-pll2-frequency to old-pll2-frequency +\ pll2-old-frequency pclk min to new-pll2-frequency + + d# 31 >bit 4 +pmua reg-clr \ PMUA_CC_MOH_MOH_RD_ST_CLEAR - clears PJ_RD_STATUS to allow frequency changing + + d# 21 >bit h# 88 +pmua reg-set \ Omit this on Z stepping - this is an undocumented bit in an undocumented debug register + + 1 >bit h# 98 +pmua reg-set \ PMUA_MOH_IMR_MOH_FC_INTR_MASK bit in PMUA_PJ_IMR register + + begin + 4 +pmua l@ d# 24 >bit and \ PMUA_DM_CC_MOH_SEA_RD_STATUS bit in DM_CC_MOH register + 0= until + + new-reg-values ( pj4-cc sp-cc fccr cgr ) + + ?change-pll2-frequency ( pj4-cc sp-cc fccr cgr ) + + h# 1024 +pmum l! ( pj4-cc sp-cc fccr ) + swap 0 +pmua l! ( pj4-cc-reg fccr ) + dclk do-fcs ( ) + +[ifdef] notdef + 2 >bit h# b4 +pmua reg-clr \ MC_FC_SLP_EN bit in PMUA_MC_SLP_REQ_PJ register +[then] + + d# 31 >bit 4 +pmua reg-clr \ PMUA_CC_MOH_MOH_RD_ST_CLEAR (the documentation is unclear - is this bit write 1 to clr?) +; + +0 [if] +0 value new-pll2-frequency +0 value old-pll2-frequency +: clip-pj4-clocks ( -- ) + pll-pj4-frequency pclk min to pclk ( ) +\ pll-pj4-frequency pdclk min to pdclk ( ) + pll-pj4-frequency baclk min to baclk ( ) + pll-pj4-frequency xpclk min to xpclk ( ) +; +: clip-ad-clocks ( -- ) + pll-ad-frequency aclk min to aclk ( ) + pll-ad-frequency datarate min to datarate ( ) +; + +: old-choose-pclk-source ( -- ) + pclk case + d# 100 of d# 400 d# 13 >bit 0 endof + d# 200 of d# 400 d# 13 >bit 0 endof + d# 400 of d# 400 d# 13 >bit 0 endof + d# 800 of d# 800 d# 15 >bit 1 endof + ( default ) + old-pll2-frequency new-pll2-frequency <> if + new-pll2-frequency setup-pll2 + then + >r new-pll2-frequency d# 14 >bit 2 r> + endcase ( pll-pj4-frequency acgr-bits fccr-bits ) + + d# 29 lshift to new-fccr ( pll-pj4-frequency acgr-bits ) + new-cgr or to new-cgr ( pll-pj4-frequency ) + to pll-pj4-frequency ( ) +\ clip-pj4-clocks +; +: old-choose-dclk-source ( -- ) + datarate case + d# 100 of d# 400 d# 13 >bit 0 endof + d# 200 of d# 400 d# 13 >bit 0 endof + d# 400 of d# 400 d# 13 >bit 0 endof + d# 800 of d# 800 d# 15 >bit 1 endof + ( default ) >r pll-pj4-frequency d# 14 >bit 2 r> + endcase ( pll-ad-frequency acgr-bits fccr-bits ) + + new-fccr over d# 23 set-field to new-fccr ( pll-ad-frequency acgr-bits ) + new-cgr or to new-cgr ( pll-ad-frequency ) + to pll-ad-frequency ( ) +\ clip-ad-clocks +; +[then]
