Author: wmb Date: Mon Jan 23 18:56:03 2012 New Revision: 2842 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2842
Log: Tags - added instructions in forth/lib/toctags for using the Forth tag files with EMACS
Modified: forth/lib/toctags
Modified: forth/lib/toctags ============================================================================== --- forth/lib/toctags Mon Jan 23 18:55:59 2012 (r2841) +++ forth/lib/toctags Mon Jan 23 18:56:03 2012 (r2842) @@ -16,3 +16,23 @@ sed -e "s,${BP},${homedir}," $* | LC_ALL=C sort | uniq | cat tags.hdr - >tags rm tags.hdr
+# To use the tags file from EMACS: +# a) Get vtags.el per http://www.gnu.org/software/vtags/ and arrange for it to be loaded +# b) If you use gforth.el, modify it as follows: +# +#--- gforth.el.orig 2012-01-18 23:04:28.420686187 -1000 +#+++ gforth.el 2012-01-18 23:05:20.560177102 -1000 +#@@ -1125,6 +1126,4 @@ +# (unless (or regexp-p next-p) +#- (setq tagname (concat "\(^\|\s-+\)\(" (regexp-quote tagname) +#- "\)\s-*\x7f"))) +#- (switch-to-buffer +#- (find-tag-noselect tagname next-p t))) +#+ (setq tagname (concat tagname "\t"))) +#+ (find-tag tagname t)) +# +# To tell EMACS which tags table to use, +# M-x customize-variable tags-table-list +# Then, if use gforth.el, you can use M-. from a Forth mode buffer to find a tag. +# In any case, you can use M-t from anywhere to find a tag, but the matching won't +# be as precise as with M-. -- you may have to select from a disambiguation list.
