Author: wmb Date: 2009-04-01 16:10:48 +0200 (Wed, 01 Apr 2009) New Revision: 1130
Modified: cpu/x86/pc/olpc/fw.bth Log: Q2E38 redux - Missing TS tag treated as manufacturing mode too.
Modified: cpu/x86/pc/olpc/fw.bth =================================================================== --- cpu/x86/pc/olpc/fw.bth 2009-04-01 13:22:54 UTC (rev 1129) +++ cpu/x86/pc/olpc/fw.bth 2009-04-01 14:10:48 UTC (rev 1130) @@ -518,12 +518,16 @@ : ?factory-boot-sequence ( -- flag ) \ TS is the "test station" tag. Its value is set to "DL" at the \ end of manufacturing test. - " TS" find-tag if ( adr len ) - ?-null " DL" $= 0= if - " disk:\boot\olpc.fth nand:\boot\olpc.fth /xp sd:\boot\olpc.fth /prober /usb/ethernet /usb/wlan" - to boot-device - then - then + " TS" find-tag if ( adr len ) + ?-null " DL" $= 0= ( in-factory? ) + else ( ) + \ Missing TS tag is treated as in factory + true ( in-factory? ) + then ( in-factory? ) + if ( ) + " disk:\boot\olpc.fth nand:\boot\olpc.fth /xp sd:\boot\olpc.fth /prober /usb/ethernet /usb/wlan" + to boot-device + then ( ) ;
