Author: rsmith Date: 2010-01-13 00:49:03 +0100 (Wed, 13 Jan 2010) New Revision: 1662
Modified: cpu/x86/pc/olpc/via/smt.fth Log: OLPC 1.5: Make smt fw version compare work like in the builds
Version compare now checks for the requested version to be
the version on the laptop before tries to do a firmware upgrade
Modified: cpu/x86/pc/olpc/via/smt.fth =================================================================== --- cpu/x86/pc/olpc/via/smt.fth 2010-01-12 22:45:35 UTC (rev 1661) +++ cpu/x86/pc/olpc/via/smt.fth 2010-01-12 23:49:03 UTC (rev 1662) @@ -2,6 +2,16 @@
visible
+\ Does a base 36 compare on the firmware versions +\ true if $2 <= $1 +: fw-$compare ( $1 $2 -- $2>$1 ) + base @ >r d# 36 base ! ( $1 $2 ) + $number if exit then ( $1 n2 ) + -rot $number if exit then ( n2 n1 ) + pop-base u<= +; + + : wanted-fw$ ( -- $ ) " q3a23" ;
@@ -21,7 +31,10 @@
: ?update-firmware ( -- ) \ Exit if the existing firmware and the wanted firmware are the same - fw-version$ wanted-fw$ nocase-$= if exit then + fw-version$ wanted-fw$ fw-$compare if + fw-version$ type ." >= " wanted-fw$ type cr + ." Not updating fimware" cr exit + then ." Updating firmware to version " fw-version$ type cr d# 2000 ms ?enough-power
