Author: wmb Date: Sat Feb 13 06:58:02 2010 New Revision: 1740 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/1740
Log: SDHCI - added support for erase-blocks and predeclaring the write size, and fixed a potential coherence problem with duplicate deblocker instances.
Modified: dev/mmc/sdhci/sdhci.fth dev/mmc/sdhci/sdmmc.fth
Modified: dev/mmc/sdhci/sdhci.fth ============================================================================== --- dev/mmc/sdhci/sdhci.fth Sat Feb 13 06:52:26 2010 (r1739) +++ dev/mmc/sdhci/sdhci.fth Sat Feb 13 06:58:02 2010 (r1740) @@ -377,6 +377,13 @@ drop ( ) ;
+\ Command register: --cccccc.TTDI.C-rr c-command# T-CmdType D-dataPresent I-CmdIndexCheck C-CmdCRCcheck r-responseType +\ CmdType: 00-normal 01-suspend 10-resume 11-abort +\ ResponseType: 00-none 01-136 10-48 11-48_and_check_busy +\ Argument register: +\ Mode register: --Md-ABD M-Multi d-Direction A-Auto_CMD12 B-BlockCntEnable D-DMAEnable + + : cmd ( arg cmd mode -- ) debug? if ." CMD: " over 4 u.r space then wait-ready @@ -499,11 +506,13 @@ : protected? ( group# -- 32-bits ) h# 1e1a cmd response ; \ CMD30 R1 UNTESTED
: erase-blocks ( block# #blocks -- ) \ UNTESTED + intstat-on dup 0= if 2drop exit then 1- bounds ( last first ) h# 201a 0 cmd ( last ) \ CMD32 - R1 h# 211a 0 cmd ( ) \ CMD33 - R1 - h# 261b 0 cmd \ CMD38 - R1b (wait for busy) + 0 h# 261b 0 cmd \ CMD38 - R1b (wait for busy) + intstat-off ;
\ CMD40 is MMC @@ -517,11 +526,25 @@
: set-oc ( ocr -- ocr' ) app-prefix h# 2902 0 cmd response ; \ ACMD41 R3
-\ This sends back 512 bits in a single data block. -: app-get-status ( -- status ) app-prefix 0 h# 0d1a h# 12 cmd response ; \ ACMD13 R1 UNTESTED +\ This sends back 512 bits (64 bytes) in a single data block. See sdstatbits +\ It contains things like the allocation unit size and the speed class. +: app-get-status ( -- buf ) \ ACMD13 R1 + intstat-on + scratch-buf d# 64 dup (dma-setup) + app-prefix 0 h# 0d3a h# 13 cmd + response h# 20 and 0= abort" ACMD13 not implemented!" + 2 wait + dma-release + scratch-buf + intstat-off +;
: get-#write-blocks ( -- n ) app-prefix 0 h# 161a 0 cmd response ; \ ACMD22 R1 UNTESTED
+\ Using this before a write-multiple command speeds up the write by +\ avoiding unnecessary preservation of data that will be clobbered. +: pre-write-erase ( #blocks -- ) intstat-on app-prefix ( #blocks ) h# 171a 0 cmd ; \ ACMD23 R1 + \ You might want to turn this off for data transfer, as it controls \ a resistor on one of the data lines : set-card-detect ( on/off -- ) app-prefix h# 2a1a 0 cmd ; \ ACMD42 R1 UNTESTED @@ -934,24 +957,29 @@ dma-len /block / ;
-: r/w-blocks-start ( addr block# #blocks in? -- error? ) - wait-dma-done - over 0= if 2drop 2drop false exit then \ Prevents hangs - intstat-on - >r ( addr block# #blocks r: in? ) - rot dma-setup ( block# r: in? ) - wait-write-done if true exit then - address-shift lshift r> if - read-multiple - else - write-multiple true to writing? - then - true to dma? - false +: r/w-blocks-start ( addr block# #blocks in? fresh? -- error? ) + wait-dma-done ( addr block# #blocks fresh? in? ) + 2 pick 0= if 3drop 2drop false exit then \ Prevents hangs + intstat-on ( addr block# #blocks fresh? in? ) + 2 pick >r >r >r ( addr block# #blocks r: #blocks fresh? in? ) + rot dma-setup ( block# r: #blocks fresh? in? ) + wait-write-done if drop r> r> r> 3drop true exit then ( block# ) + address-shift lshift r> if ( block# r: #blocks fresh? ) + r> r> 2drop ( block# ) + read-multiple ( ) + else ( block# r: #blocks fresh? ) + r> if r> pre-write-erase else r> drop then ( block# ) + write-multiple true to writing? ( ) + then ( ) + true to dma? ( ) + false ( error? ) +; +: fresh-write-blocks-start ( addr block# #blocks -- error? ) + false true r/w-blocks-start ;
: r/w-blocks ( addr block# #blocks in? -- actual ) - r/w-blocks-start if -1 exit then r/w-blocks-finish + false r/w-blocks-start if -1 exit then r/w-blocks-finish ;
: r/w-ioblocks ( reg# function# inc? addr len blksz in? -- actual ) @@ -1010,6 +1038,17 @@ swap 0 -rot do 2* i csdbit or -1 +loop ;
+\ Decoder for the result of ACMD13 - app-get-status +: sdstatbit ( bit# -- b ) + d# 511 swap - ( bit#' ) + dup 3 rshift scratch-buf + c@ ( bit-offset byte ) + swap 7 and 7 xor rshift 1 and +; +: sdstatbits ( high low -- bits ) + swap 0 -rot do 2* i sdstatbit or -1 +loop +; + + \ The calculation below is shown on page 81 of the \ SD Physical Layer Simplified Specification Version 2.00. : size ( -- d.bytes )
Modified: dev/mmc/sdhci/sdmmc.fth ============================================================================== --- dev/mmc/sdhci/sdmmc.fth Sat Feb 13 06:52:26 2010 (r1739) +++ dev/mmc/sdhci/sdmmc.fth Sat Feb 13 06:58:02 2010 (r1740) @@ -15,7 +15,7 @@ \ block or record oriented, but the OBP external interface is byte-oriented, \ in order to be independent of particular device block sizes.
-0 instance value deblocker +0 value deblocker
external
@@ -31,11 +31,15 @@ false " r/w-blocks" $call-parent ;
+: erase-blocks ( block# #blocks -- ) + " erase-blocks" $call-parent +; + \ Asynchronous write. Completes on the next call to \ write-blocks-start, write-blocks-finish, or close. \ (Don't do other read/write operations in between.) : write-blocks-start ( adr block# #blocks -- error? ) - false " r/w-blocks-start" $call-parent + " fresh-write-blocks-start" $call-parent ; : write-blocks-end ( -- error? ) false " r/w-blocks-end" $call-parent @@ -48,33 +52,43 @@ : dma-free ( vadr size -- ) " dma-free" $call-parent ;
: set-unit ( -- ) 0 my-unit " set-address" $call-parent ; + +0 value open-count : open ( -- ) set-unit - " attach-card" $call-parent 0= if false exit then + open-count 0= if + " attach-card" $call-parent 0= if false exit then
- " " " deblocker" $open-package ?dup if - to deblocker - else - ." Can't open deblocker package" cr - false exit + " " " deblocker" $open-package to deblocker + deblocker 0= if + ." Can't open deblocker package" cr + false exit + then then
- my-args " disk-label" $open-package ?dup if ( ihandle ) - to label-package + my-args " disk-label" $open-package to label-package + label-package if 0 0 " offset" label-package $call-method to offset-high to offset-low else ." Can't open disk label package" cr - deblocker close-package false exit + open-count 0= if + deblocker close-package + then + false exit then
+ open-count 1+ to open-count true ;
: close ( -- ) - label-package close-package - deblocker close-package - \ Close packages first in case of delayed write flush - " detach-card" $call-parent + open-count dup 1- to open-count ( prev-open-count ) + label-package close-package ( prev-open-count ) + 1 = if ( ) + deblocker close-package ( ) + \ Close packages first in case of delayed write flush + " detach-card" $call-parent ( ) + then ( ) ;
: block-size ( -- n ) h# 200 ;
