Author: wmb Date: Thu Sep 27 23:17:26 2012 New Revision: 3341 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3341
Log: Debugger - improve visual debugger redisplay so it's rarely necessary to use the L command. See OLPC trac #12105.
Modified: forth/lib/debug.fth
Modified: forth/lib/debug.fth ============================================================================== --- forth/lib/debug.fth Thu Sep 27 03:23:16 2012 (r3340) +++ forth/lib/debug.fth Thu Sep 27 23:17:26 2012 (r3341) @@ -37,7 +37,9 @@ variable step? step? on variable res headers -false value redisplay? + +-1 value displayed-xt +: force-redisplay ( -- ) -1 to displayed-xt ;
: (debug) (s low-adr hi-adr -- ) unbug 1 cnt ! ip> ! <ip ! pnext @@ -46,8 +48,9 @@ slow-next? on then step? on - true is redisplay? + force-redisplay ; + headerless : 'unnest (s pfa -- pfa' ) begin dup ta1+ swap token@ ['] unnest = until @@ -188,6 +191,8 @@ : restore# ( -- ) #buf-save #-buf /#buf - d# 72 move hld-save @ hld ! ; 0 value the-ip 0 value the-rp +: redisplay? ( -- flag ) displayed-xt the-ip find-cfa <> ; + : (.rs ( -- ) show-rstack @ 0= if exit then ." return-stack: " @@ -210,6 +215,7 @@ d# 40 rmargin ! ." Stack: " #out @ #line @ to full-stack-xy cr \ For stack the-ip debug-see + the-ip find-cfa to displayed-xt cr \ Display the initial stack on the cursor line the-ip ip>position 0= if ( col row ) @@ -224,7 +230,6 @@ setup-2d-display then 0 show-rstack ! - false is redisplay? then ; : show-debug-stack ( -- ) @@ -269,7 +274,7 @@ ascii U of the-rp ['] up1 try endof \ Up ascii C of \ Continue step? @ 0= step? ! - step? @ 0= if true to scrolling-debug? true to redisplay? then + step? @ 0= if true to scrolling-debug? force-redisplay then true endof
@@ -290,10 +295,10 @@ ascii * of the-ip find-cfa dup <ip ! 'unnest ip> ! false endof ascii \ of show-rstack @ 0= show-rstack ! false endof \ toggle return stack display ascii X of hex-stack @ 0= hex-stack ! false endof \ toggle heX stack display - ascii L of true to redisplay? false endof \ Redisplay + ascii L of force-redisplay false endof \ Redisplay ascii V of \ toggle Visual (2D) mode scrolling-debug? 0= to scrolling-debug? - scrolling-debug? 0= if true to redisplay? then false + scrolling-debug? 0= if force-redisplay then false endof ( default ) true swap endcase @@ -309,7 +314,7 @@ debug-interact \ scrolling-debug? 0= if to-result-loc then the-ip token@ dup ['] unnest = swap ['] exit = or if - cr true is redisplay? + cr force-redisplay then slow-next? @ if pnext then ; @@ -325,7 +330,7 @@ (debug ; : debugging ( -- ) ' .debug-short-help dup (debug execute ; -: resume (s -- ) true is exit-interact? pnext ; +: resume (s -- ) true is exit-interact? force-redisplay pnext ; : stepping (s -- ) step? on ; : tracing (s -- ) step? off ;
