Author: wmb Date: Fri Sep 30 02:13:12 2011 New Revision: 2552 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2552
Log: ARM XO-1.75 - Used pmua! instead of explicit addresses in camera driver. Should be no functional change.
Modified: dev/olpc/mmp2camera/ccic.fth
Modified: dev/olpc/mmp2camera/ccic.fth ============================================================================== --- dev/olpc/mmp2camera/ccic.fth Fri Sep 30 02:11:51 2011 (r2551) +++ dev/olpc/mmp2camera/ccic.fth Fri Sep 30 02:13:12 2011 (r2552) @@ -74,8 +74,8 @@
: power-on ( -- ) \ Enable clocks - h# 3f h# 282828 io! \ Clock gating - AHB, Internal PIXCLK, AXI clock always on - h# 0003.805b h# 282850 io! \ PMUA clock config for CCIC - /1, PLL1/16, AXI arb, AXI, perip on + h# 3f h# 28 pmua! \ Clock gating - AHB, Internal PIXCLK, AXI clock always on + h# 0003.805b h# 50 pmua! \ PMUA clock config for CCIC - /1, PLL1/16, AXI arb, AXI, perip on
\ h# 0000.0002 h# 88 cl! \ Clock select - PIXMCLK, 797/2 (PLL1/16) / 2 -> 24.9 MHz \ h# 4000.0002 h# 88 cl! \ Clock select - AXI, 797/2 (PLL1/16) / 2 -> 24.9 MHz
