Author: wmb Date: 2009-08-06 02:15:55 +0200 (Thu, 06 Aug 2009) New Revision: 1284
Modified: dev/pckbd.fth Log: PC keyboard - Increased timeout values to cope with slow embedded controllers.
Modified: dev/pckbd.fth =================================================================== --- dev/pckbd.fth 2009-08-06 00:15:18 UTC (rev 1283) +++ dev/pckbd.fth 2009-08-06 00:15:55 UTC (rev 1284) @@ -123,7 +123,7 @@ : got-ack? ( -- true | timeout? false ) begin \ No response - retry once - d# 10 timed-read if true false exit then ( data ) + d# 50 timed-read if true false exit then ( data ) case h# fa of true exit endof \ ACK - exit without retry h# fe of false false exit endof \ RETRY - retry as long as we keep getting fe @@ -259,7 +259,7 @@ [ifndef] demo-board : ?olpc-keyboard ( -- ) " enable-intf" $call-parent - begin 5 timed-read 0= while + begin d# 50 timed-read 0= while drop true to keyboard-present? repeat @@ -274,11 +274,11 @@ h# f2 cmd
\ Keyboards return the ID sequence ab XX - 2 timed-read if exit then ( id1 ) + d# 50 timed-read if exit then ( id1 ) h# ab <> if exit then
\ The ENE keyboard controller return ab 41 - 2 timed-read if exit then ( id2 ) + d# 50 timed-read if exit then ( id2 ) h# 41 <> if exit then
\ This looks like an ENE controller, so flip the mapping table
