Author: quozl Date: Fri Sep 7 10:39:55 2012 New Revision: 3299 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3299
Log: OLPC XO-4 - Neonode, re-enable too-strong fail
Modified: cpu/arm/olpc/nn-touchscreen.fth ============================================================================== --- cpu/arm/olpc/nn-touchscreen.fth Fri Sep 7 01:38:55 2012 (r3298) +++ cpu/arm/olpc/nn-touchscreen.fth Fri Sep 7 10:39:55 2012 (r3299) @@ -485,7 +485,6 @@
[ifdef] nn-fll \ forced LED levels test : test-fll-signal ( signal# signal-value led-level -- ) -[ifdef] nn-too-strong-is-fatal dup 0= if fault rot ." fail on axis signal " .d @@ -494,7 +493,6 @@ cr exit then -[then] dup h# c > if fault rot ." fail on axis signal " .d
