Author: quozl Date: Fri Sep 30 01:59:27 2011 New Revision: 2549 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2549
Log: OLPC XO-1.75 - add thermal watchdog disable used in testing
Modified: cpu/arm/mmp2/thermal.fth
Modified: cpu/arm/mmp2/thermal.fth ============================================================================== --- cpu/arm/mmp2/thermal.fth Fri Sep 30 00:51:18 2011 (r2548) +++ cpu/arm/mmp2/thermal.fth Fri Sep 30 01:59:27 2011 (r2549) @@ -8,6 +8,8 @@ h# 10000 thermal-base io! \ Enable sensing ;
+\ thermal watchdog is enabled by CForth + : cpu-temperature ( -- celcius ) 0 ( acc ) d# 100 0 do ( acc ) \ Accumulate 100 samples @@ -22,6 +24,28 @@ d# 52940 - d# 196 / ( celcius ) ;
+: ?thermal ( -- ) + cpu-temperature d# 70 > abort " CPU too hot" +; + +[ifndef] wdtpcr +main-pmu-pa h# 200 + constant wdtpcr +[then] + +\ disable thermal watchdog, please use only in controlled conditions +: thermal-off + wdtpcr io@ + b# 0101.1111 and + wdtpcr io! +; + +: thermal-on + wdtpcr io@ + b# 1101.1111 and + b# 1000.0000 or + wdtpcr io! +; + thermal-base h# 4 + value wd-thresh : wd-thresh@ ( -- n ) wd-thresh io@ ; : wd-thresh! ( n -- ) wd-thresh io! ;
