Author: wmb Date: 2009-12-10 23:57:37 +0100 (Thu, 10 Dec 2009) New Revision: 1566
Added: cpu/x86/pc/olpc/via/assy.fth Log: Initial revision of ASSY phase manufacturing test script.
Added: cpu/x86/pc/olpc/via/assy.fth =================================================================== --- cpu/x86/pc/olpc/via/assy.fth (rev 0) +++ cpu/x86/pc/olpc/via/assy.fth 2009-12-10 22:57:37 UTC (rev 1566) @@ -0,0 +1,261 @@ +\ Manufacturing test boot script for ASSY state + +: swid$ ( -- adr len ) " OFW ASSY test $Revision$" ; + +\ Location of the files containing KA tag data +: ka-dir$ ( -- adr len ) " http:\10.1.0.1\ka" ; + +\ Remove possible trailing carriage return from the line +: ?remove-cr ( adr len -- adr len' ) + dup if ( adr len ) + 2dup + 1- c@ carret = if ( adr len ) + 1- + then + then +; + +[ifndef] $read-file +\ Read entire file into allocated memory +: $read-file ( filename$ -- true | data$ false ) + open-dev ?dup 0= if true exit then >r ( r: ih ) + " size" r@ $call-method drop ( len r: ih ) + dup alloc-mem swap ( adr len r: ih ) + 2dup " read" r@ $call-method ( adr len actual r: ih ) + r> close-dev ( adr len actual ) + over <> if ( adr len ) + free-mem true exit + then ( adr len ) + false +; +[then] + +: put-ka-tag ( value$ key$ -- ) + 2over 8 min ka-dir$ " %s%s" sprintf ( value$ key$ filename$ ) + $read-file if ( value$ key$ ) + ." ERROR: No KA tag file for " 2swap type cr ( key$ ) + 2drop ( ) + else ( value$ key$ file-data$ ) + 2swap ($add-tag) ( value$ ) + 2drop ( ) + then +; + +: put-tag ( value$ key$ -- ) + 2dup " KA" $= if ( value$ key$ ) + put-ka-tag exit + then ( value$ key$ ) + 2swap dup if add-null then 2swap ( value$' key$ ) + ($add-tag) ( ) +; + +: .instructions ( adr len -- ) + cr blue-letters type black-letters cr +; +: .problem ( adr len -- ) + red-letters type black-letters cr +; + +: check-smt-status ( -- ) + " SS" find-tag 0= abort" Board failed SMT !!!" ( adr len ) + -null ( adr len' ) + " EN" $= 0= abort" Board failed SMT !!!" ( ) +; + +: fwver$ ( -- adr len ) h# ffff.ffc6 6 ; +: board#$ ( -- adr len ) + " B#" find-tag 0= abort" Missing B# tag !!!" + -null +; + +d# 20 buffer: sn-buf +: sn$ ( -- adr len ) sn-buf count ; + +: try-get-sn ( -- ) + sn-buf 1+ d# 20 accept ( n ) + d# 12 <> if + " Wrong length, try again" .problem + false exit + then + sn-buf 1+ " TSHC" comp if + " Must begin with TSHC, try again" .problem + false exit + then + sn-buf 2+ sn-buf 1+ d# 11 move \ Elide the T + d# 11 sn-buf c! + true +; + +: get-sn ( -- ) + ." *****" + + begin + " Please Input Serial Number ......" .instructions + try-get-sn + until +; + +d# 38 buffer: uuid-buf +: uuid$ ( -- ) uuid-buf count ; + +: uuid-bytes ( n -- ) + push-hex + 0 ?do + random-byte (.2) 2dup upper uuid-buf $cat + loop + pop-base +; + +: make-uuid ( -- ) + 0 uuid-buf c! + 4 uuid-bytes " -" uuid-buf $cat + 2 uuid-bytes " -" uuid-buf $cat + 2 uuid-bytes " -" uuid-buf $cat + 2 uuid-bytes " -" uuid-buf $cat + 6 uuid-bytes +; + +d# 20 buffer: mac-buf +: mac$ ( -- ) mac-buf count ; + +: format-mac-address ( adr len -- ) + 0 mac-buf c! + push-hex + drop + 5 0 do ( adr ) + dup c@ (.2) mac-buf $cat ( adr ) + " -" mac-buf $cat ( adr ) + 1+ ( adr ) + loop ( adr ) + c@ (.2) mac-buf $cat ( ) + mac$ upper ( ) + pop-base +; + +: get-mac ( -- ) + " /wlan:force" open-dev ?dup if ( wlan-ih ) + >r + " local-mac-address" r@ ihandle>phandle get-package-property if + " XX-XX-XX-XX-XX-XX" mac-buf place + else ( adr len ) + format-mac-address ( ) + then + r> close-dev + else + " XX-XX-XX-XX-XX-XX" mac-buf place + then +; + +: swdl-date$ ( -- adr len ) + push-decimal + today swap rot <# u# u# drop u# u# drop u# u# u# u# u#> + pop-base +; +: get-info ( -- ) + check-smt-status + get-mac + make-uuid + get-sn +; + +0 0 2value response$ + +: clear-mfg-buf ( -- ) + mfg-data-buf /flash-block h# ff fill +; + +: execute-downloads ( adr len -- ) + begin dup while ( adr len ) + linefeed left-parse-string ( rem$ line$ ) + ?remove-cr ( rem$ line$ ) + [char] : left-parse-string ( rem$ value$ key$ ) + " Command" $= if ( rem$ value$ ) + evaluate ( rem$ ) + then ( rem$ value$ ) + 2drop ( rem$ ) + repeat ( rem$ ) + 2drop ( ) +; + +: parse-tags ( adr len -- ) + begin dup while ( adr len ) + linefeed left-parse-string ( rem$ line$ ) + ?remove-cr ( rem$ line$ ) + [char] : left-parse-string ( rem$ value$ key$ ) + dup 2 = if ( rem$ value$ key$ ) + put-tag ( rem$ ) + else ( rem$ value$ key$ ) + 4drop ( rem$ ) + then ( rem$ ) + repeat ( adr len ) + 2drop ( ) +; + +: inject-tags ( -- ) + flash-write-enable + clear-mfg-buf + + " " " ww" put-tag + sn$ " SN" put-tag + fwver$ " BV" put-tag + swid$ " T#" put-tag + uuid$ " U#" put-tag + mac$ " WM" put-tag + swdl-date$ " SD" put-tag + +\ " EN" " SS" put-tag +\ " NA" " FQ" put-tag + + response$ parse-tags + (put-mfg-data) + flash-write-disable +; + +: make-assy-request ( -- ) + sn$ " %s.txt" sprintf open-temp-file + mac$ " WM:" put-key+value + uuid$ " U#:" put-key+value + swid$ " T#:" put-key+value + fwver$ " BV:" put-key+value + board#$ " B#:" put-key+value + sn$ " SN:" put-key+value +; + +: assy-tag-exchange ( -- ) + make-assy-request ( ) + " Request" submit-file ( ) + " Response" get-response to response$ +; + +: silent-probe-usb ( -- ) + " /" ['] (probe-usb2) scan-subtree + " /" ['] (probe-usb1) scan-subtree + report-disk report-net report-keyboard +; + +: wired-lan? ( -- flag ) + " /usb/ethernet" locate-device if false else drop true then +; +: wait-lan ( -- ) + wired-lan? 0= if + " Connect USB Ethernet Adapter" .instructions + begin d# 1000 ms silent-probe-usb wired-lan? until + then +; + +: start-assy-test ( -- ) + wait-lan + + get-info + + ." Getting server response " + cifs-connect assy-tag-exchange cifs-disconnect + ." Done" cr + + execute-downloads + inject-tags + + ." Powering off ..." d# 2000 ms + power-off +; + +start-assy-test
