Author: wmb Date: Wed Jan 19 23:48:49 2011 New Revision: 2122 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2122
Log: Copied ppc/fixvoc.fth to arm/fixvoc.fth to eliminate ARM build dependency on PPC subtree.
Added: cpu/arm/fixvoc.fth Modified: cpu/arm/kernel.bth
Added: cpu/arm/fixvoc.fth ============================================================================== --- /dev/null 00:00:00 1970 (empty, because file is newly added) +++ cpu/arm/fixvoc.fth Wed Jan 19 23:48:49 2011 (r2122) @@ -0,0 +1,52 @@ +purpose: Fixup vocabularies at the end of kernel metacompilation +\ See license at end of file + +only forth meta also forth also definitions +\ Nasty kludge to resolve the to pointer to the does> clause of vocabulary +\ within "forth". The problem is that the code field of "forth" contains +\ a call instruction to the does> clause of vocabulary. This call is a +\ forward reference which cannot be resolved in the same way as compiled +\ addresses. + +: used-t ( definer-acf child-acf -- ) + [ also meta ] token!-t [ previous ] +; + +: fix-vocabularies ( -- ) + [""] <vocabulary> also symbols find previous ( acf true | str false ) + 0= abort" Can't find <vocabulary> in symbols" + dup resolution@ >r ( acf ) ( Return stack: <vocabulary>-adr ) + dup first-occurrence@ ( acf occurrence ) + \ Don't let fixall muck with this entry later + 0 rot >first-occurrence ! ( occurrence ) + begin another-occurrence? while ( occurrence ) + dup [ meta ] token@-t [ forth ] swap ( next-occurrence occurrence ) + \ Calculate the longword offset to the vocabulary does> clause + r@ swap used-t + repeat + r> drop +; + +\ LICENSE_BEGIN +\ Copyright (c) 2007 FirmWorks +\ +\ Permission is hereby granted, free of charge, to any person obtaining +\ a copy of this software and associated documentation files (the +\ "Software"), to deal in the Software without restriction, including +\ without limitation the rights to use, copy, modify, merge, publish, +\ distribute, sublicense, and/or sell copies of the Software, and to +\ permit persons to whom the Software is furnished to do so, subject to +\ the following conditions: +\ +\ The above copyright notice and this permission notice shall be +\ included in all copies or substantial portions of the Software. +\ +\ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, +\ EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF +\ MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND +\ NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE +\ LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION +\ OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION +\ WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. +\ +\ LICENSE_END
Modified: cpu/arm/kernel.bth ============================================================================== --- cpu/arm/kernel.bth Wed Jan 19 23:47:46 2011 (r2121) +++ cpu/arm/kernel.bth Wed Jan 19 23:48:49 2011 (r2122) @@ -59,7 +59,7 @@ \ : : : lastacf .name cr ; fload ${BP}/cpu/arm/target.fth fload ${BP}/forth/kernel/forward.fth -fload ${BP}/cpu/ppc/fixvoc.fth +fload ${BP}/cpu/arm/fixvoc.fth fload ${BP}/forth/kernel/metacompile.fth
fload ${BP}/cpu/arm/metarel.fth
