Author: wmb Date: 2009-01-23 20:45:08 +0100 (Fri, 23 Jan 2009) New Revision: 1076
Added: cpu/x86/pc/olpc/iflash.fth cpu/x86/pc/olpc/usbpwr.fth Log: Biosload build - Checked in olpc/iflash.fth and olpc/usbpwr.fth, needed by "biosload/config-olpc.fth" build version.
Added: cpu/x86/pc/olpc/iflash.fth =================================================================== --- cpu/x86/pc/olpc/iflash.fth (rev 0) +++ cpu/x86/pc/olpc/iflash.fth 2009-01-23 19:45:08 UTC (rev 1076) @@ -0,0 +1,71 @@ +\ Reflasher that merges Insyde BIOS with manufacturing data + +h# 300 constant /mfg-data-merge +mfg-data-end-offset /mfg-data-merge - constant mfg-data-merge-offset + +: $get-insyde ( filename$ -- ) + $read-open + flash-buf /flash ifd @ fgets ( len ) + ifd @ fclose + + /flash <> abort" Image file is the wrong length" + + flash-buf mfg-data-merge-offset + /mfg-data-merge 0 bskip ( residue ) + abort" Firmware image has data in the manufacturing data block" + + true to file-loaded? +; + +: merge-mfg-data ( -- ) + flash-base mfg-data-merge-offset + + flash-buf mfg-data-merge-offset + + /mfg-data-merge move +; + +: get-insyde ( ["filename"] -- ) + parse-word ( adr len ) + dup 0= if 2drop " u:\insyde.rom" then ( adr len ) + ." Reading " 2dup type cr ( adr len ) + $get-insyde +; + +: write-insyde ( -- ) + flash-buf /flash 0 write-flash-range +; + +: ireflash ( -- ) \ Flash from data already in memory + ?file + flash-write-enable + + merge-mfg-data + + write-insyde + + spi-us d# 20 < if + ['] verify catch if + ." Verify failed. Retrying once" cr + spi-identify + write-insyde + verify + then + flash-write-disable + else + .verify-msg + then +; + +: iflash ( ["filename"] -- ) get-insyde ?enough-power ireflash ; + +: save-insyde ( -- ) + " u:\insyde.rom" $write-open + + \ Get the FLASH data into a buffer, slowly to avoid locking out the EC + slow-flash-read + + \ Zap the manufacturing data + flash-buf mfg-data-merge-offset + /mfg-data-merge 0 fill + + flash-buf /flash ofd @ fputs + + ofd @ fclose +;
Added: cpu/x86/pc/olpc/usbpwr.fth =================================================================== --- cpu/x86/pc/olpc/usbpwr.fth (rev 0) +++ cpu/x86/pc/olpc/usbpwr.fth 2009-01-23 19:45:08 UTC (rev 1076) @@ -0,0 +1,27 @@ +purpose: Bounce USB power to reset devices + +\ This is used by the biosload build for OLPC to reset USB +\ devices. Insyde BIOS / GeodeROM leaves some USB sticks in +\ funny state in which reads fail. Power cycling fixes them. + +: power-cycle-usb ( -- ) + " /pci/usb@f,4" open-dev >r \ OHCI controller + + \ Configure the OHCI controller for global power switching + " hc-rh-desa@" r@ $call-method ( desA ) + h# 300 invert and ( desA' ) + " hc-rh-desa!" r@ $call-method ( desA ) + + \ Turn off the power from the OHCI point of view, leaving the + \ EHCI in control (the power switches are the logical OR + \ of the OHCI and EHCI controls) + 1 " hc-rh-stat!" r@ $call-method + r> close-dev + d# 100 ms + + " /pci/usb@f,5" open-dev ( ih ) \ EHCI controller + 4 0 do 0 i " portsc!" 4 pick $call-method loop ( ih ) + d# 100 ms + 4 0 do i " power-port" 3 pick $call-method loop ( ih ) + close-dev +;
