Author: wmb Date: Wed Aug 29 03:20:38 2012 New Revision: 3238 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3238
Log: OLPC ARM - Audio driver - use the new "my-clocks-on/off" facility to move the clock enabling code out of this file into the PMUA driver.
Modified: cpu/arm/mmp2/pmua.fth cpu/arm/olpc/sound.fth
Modified: cpu/arm/mmp2/pmua.fth ============================================================================== --- cpu/arm/mmp2/pmua.fth Wed Aug 29 02:50:52 2012 (r3237) +++ cpu/arm/mmp2/pmua.fth Wed Aug 29 03:20:38 2012 (r3238) @@ -121,37 +121,6 @@ [then] " clock-enable-registers" property
-[ifdef] notdef - " clock-enable-registers" get-property if ( on? clock# ) - 2drop exit ( -- ) - then ( on? clock# propval$ ) - - \ Offset into clock-enable-registers array - rot h# 10 * ( on? propval$ offset ) - 2dup <= if ( on? propval$ offset ) - 4drop exit ( -- ) - then ( on? propval-adr$ offset ) - /string ( on? propval-adr$' ) - - \ Get register offset - decode-int >r ( on? propval-adr$' r: reg-offset ) - - \ Apply the clear mask to the register value - decode-int invert ( on? propval-adr$' clr-mask r: reg-offset ) - r@ pmua@ and ( on? propval-adr$' regval r: reg-offset ) - -rot ( on? regval propval-adr$ r: reg-offset ) - - \ Apply the set mask if the clock is being turned on - 3 roll if ( regval propval-adr$ r: reg-offset ) - get-encoded-int or ( regval' r: reg-offset ) - else ( regval propval-adr$ r: reg-offset ) - 2drop ( regval r: reg-offset ) - then ( regval r: reg-offset ) - - \ Write back the modified register value - r> pmua! ( ) -[then] - : generic-on/off ( on? clock# -- ) get-reg&masks if drop exit then ( on? set-mask clr-mask reg ) >r r@ pmua@ and ( on? set-mask regval r: reg ) @@ -159,6 +128,71 @@ r> pmua! ;
+h# 10c constant audio-clk + +[ifdef] mmp3 +h# 164 constant audio-dsa +h# 1e4 constant isld-dspa-ctrl +h# 240 constant audio-sram-pwr +[then] + +\ Discrepancies - ms vs us, double-enabling of AXI +: dly d# 10 us ; + +: audio-island-on ( -- ) +[ifdef] mmp3 + h# 200 audio-clk pmua-set dly \ Power switch on + h# 400 audio-clk pmua-set dly \ Power switch more on + 1 audio-sram-pwr pmua-set dly \ Audio SRAM on + 2 audio-sram-pwr pmua-set dly \ Audio SRAM more on + 4 audio-sram-pwr pmua-set dly \ Audio core on + 8 audio-sram-pwr pmua-set dly \ Audio core more on + h# 100 audio-clk pmua-set dly \ Disable isolation + + 4 audio-clk pmua-set \ Start audio SRAM redundancy repair + begin audio-clk pmua@ 4 and 0= until \ And wait until done + + \ Bring audio island out of reset + 1 audio-dsa pmua-set + 4 audio-dsa pmua-set + 1 audio-dsa pmua-set + + \ Enable dummy clocks to the SRAMs + h# 10 isld-dspa-ctrl pmua-set d# 250 us h# 10 isld-dspa-ctrl pmua-clr + + \ Enable the AXI/APB clocks to the Audio island prior to programming island registers + 2 audio-dsa pmua-set + 8 audio-dsa pmua-set +[else] + h# 600 audio-clk pmua! dly \ Turn on power + h# 610 audio-clk pmua! dly \ Enable clock + h# 710 audio-clk pmua! dly \ Disable isolation + h# 712 audio-clk pmua! dly \ Release reset +[then] +; + +: audio-island-off ( -- ) +[ifdef] true +[ifdef] mmp3 + h# a audio-dsa pmua-clr \ Disable AXI and APB clocks + h# 5 audio-dsa pmua-clr \ Put AXI and APB clocks in reset + h# 100 audio-clk pmua-clr \ Enable isolation + h# c audio-sram-pwr pmua-clr \ Audio core off + h# 3 audio-sram-pwr pmua-clr \ Audio SRAM off + h# 600 audio-clk pmua-clr \ Enable isolation +[else] + h# 710 audio-clk pmua! \ Set peripheral reset + h# 610 audio-clk pmua! \ Enable isolation + h# 600 audio-clk pmua! \ Disable clock + h# 000 audio-clk pmua! \ Turn off power +[then] +[then] + 0 audio-clk pmua! +; +: audio-on/off ( on? -- ) + if audio-island-on else audio-island-off then +; + [ifdef] mmp3 : ccic-isp-island-off ( -- ) h# 600 h# 1fc pmua! \ Isolation enabled @@ -231,6 +265,10 @@ drop ccic-on/off exit ( -- ) then ( on? clock# )
+ dup d# 20 = if \ AUDIO ( on? clock# ) + drop audio-on/off exit ( -- ) + then + generic-on/off ;
Modified: cpu/arm/olpc/sound.fth ============================================================================== --- cpu/arm/olpc/sound.fth Wed Aug 29 02:50:52 2012 (r3237) +++ cpu/arm/olpc/sound.fth Wed Aug 29 03:20:38 2012 (r3238) @@ -82,17 +82,9 @@ : adma! ( n offset -- ) adma-base + rl! ; : adma@ ( offset -- n ) adma-base + rl@ ;
-h# 10c +pmua constant audio-clk -[ifdef] mmp3 -h# 164 +pmua constant audio-dsa -h# 1e4 +pmua constant isld-dspa-ctrl -h# 240 +pmua constant audio-sram-pwr -[then] - -: audio-clock! ( -- ) audio-clk io! ; : audio-clock-off ( -- ) 0 h# 38 sspa! - 0 audio-clock! + my-clock-off ; : start-audio-pll ( -- error? ) \ For VCXO=26 MHz, OCLK=12.2880 MHz @@ -110,42 +102,9 @@
: dly d# 10 us ;
-\ Discrepancies - ms vs us, double-enabling of AXI -: audio-island-on ( -- ) -[ifdef] mmp3 - h# 200 audio-clk io-set dly \ Power switch on - h# 400 audio-clk io-set dly \ Power switch more on - 1 audio-sram-pwr io-set dly \ Audio SRAM on - 2 audio-sram-pwr io-set dly \ Audio SRAM more on - 4 audio-sram-pwr io-set dly \ Audio core on - 8 audio-sram-pwr io-set dly \ Audio core more on - h# 100 audio-clk io-set dly \ Disable isolation - - 4 audio-clk io-set \ Start audio SRAM redundancy repair - begin audio-clk io@ 4 and 0= until \ And wait until done - - \ Bring audio island out of reset - 1 audio-dsa io-set - 4 audio-dsa io-set - 1 audio-dsa io-set - - \ Enable dummy clocks to the SRAMs - h# 10 isld-dspa-ctrl io-set d# 250 us h# 10 isld-dspa-ctrl io-clr - - \ Enable the AXI/APB clocks to the Audio island prior to programming island registers - 2 audio-dsa io-set - 8 audio-dsa io-set -[else] - h# 600 audio-clock! dly \ Enable - h# 610 audio-clock! dly \ Release reset - h# 710 audio-clock! dly \ Enable - h# 712 audio-clock! dly \ Release reset -[then] -; - false value use-audio-pll? : audio-clock-on ( -- error? ) - audio-island-on + my-clock-on
use-audio-pll? if start-audio-pll if true exit then
