Author: wmb Date: 2009-12-11 06:15:35 +0100 (Fri, 11 Dec 2009) New Revision: 1568
Modified: dev/olpc/kb3700/battery.fth Log: OLPC battery test - eliminated timeouts for SMT operator convenience, eliminated AC disconnect test in SMT phase.
Modified: dev/olpc/kb3700/battery.fth =================================================================== --- dev/olpc/kb3700/battery.fth 2009-12-11 05:13:41 UTC (rev 1567) +++ dev/olpc/kb3700/battery.fth 2009-12-11 05:15:35 UTC (rev 1568) @@ -796,15 +796,20 @@
: wait-no-ac ( -- error? ) ." Disconnect AC power to continue.. " - d# 200 0 do + begin + bat-status@ h# 10 and ( ac-connected? ) + while d# 100 ms - bat-status@ h# 10 and 0= if - false unloop cr exit + + key? if + key h# 1b = if + ." ERROR: AC still connected" cr + true exit + then then - loop + repeat cr - ." ERROR: AC not disconnected" cr - true + false ;
\ Test that we can run without AC power. @@ -825,15 +830,20 @@
: wait-ac ( -- error? ) ." Connect AC power to continue.. " - d# 200 0 do + begin + bat-status@ h# 10 and 0= ( ac-disconnected? ) + while d# 100 ms - bat-status@ h# 10 and if - false unloop cr exit + + key? if + key h# 1b = if + ." ERROR: AC not connected" cr + true exit + then then - loop + repeat cr - ." ERROR: AC not connected" cr - true + false ;
: test-charging ( -- error? ) @@ -853,7 +863,9 @@
: interactive-test ( -- error? ) test-battery if true exit then - test-discharging if true exit then + smt-test? 0= if \ Skip this test in SMT + test-discharging if true exit then + then test-charging if true exit then false ;
