Author: rsmith Date: 2009-10-01 07:26:33 +0200 (Thu, 01 Oct 2009) New Revision: 1381
Modified: cpu/x86/pc/olpc/charge.fth dev/olpc/kb3700/battery.fth Log: OLPC: Fix various batman bugs
The bat man code has a few problems with Gen 1.5. The formatting also didn't handle negative number right. Add new command 'bat-charge' which will force the charger on and then show vitals.
Modified: cpu/x86/pc/olpc/charge.fth =================================================================== --- cpu/x86/pc/olpc/charge.fth 2009-09-25 01:54:20 UTC (rev 1380) +++ cpu/x86/pc/olpc/charge.fth 2009-10-01 05:26:33 UTC (rev 1381) @@ -29,11 +29,12 @@ 0 logstr c! time&date >unix-seconds >sd, logstr $cat soc >sd, logstr $cat - uvolt@ >sd, logstr $cat - cur@ >sd, logstr $cat - bat-temp >sd, logstr $cat - bat-acr@ s16>s32 dup >sd, logstr $cat - start-acr - bg-acr>mAh >sd.dd logstr $cat + uvolt@ dup >sd, logstr $cat 100 / ( V__.1mV ) + cur@ dup >sd, logstr $cat 100 / ( V_.1mV I__.1mA ) + * drop ( W_mW ) + bat-temp >sd, logstr $cat + bat-acr@ s16>s32 dup >sd, logstr $cat + start-acr - bg-acr>mAh >sd.dd, logstr $cat r> base ! ;
Modified: dev/olpc/kb3700/battery.fth =================================================================== --- dev/olpc/kb3700/battery.fth 2009-09-25 01:54:20 UTC (rev 1380) +++ dev/olpc/kb3700/battery.fth 2009-10-01 05:26:33 UTC (rev 1381) @@ -123,7 +123,18 @@ \ (stdout off) this will miss some state changes. \
-h# FA00 constant ec-rambase +h# FA00 constant ec-rambase +h# 20 constant ec-platformID + +h# FC00 constant ec-gpiobase +h# 00 constant ec-gpiofs00 +h# 12 constant ec-gpio-0A + +h# FE00 constant ec-pwmbase +h# 08 constant ec-pwmhigh2 +h# 09 constant ec-pwmhigh3 +h# 0A constant ec-pwmhigh4 + : ec-ram@ ec-rambase + ec@ ;
: next-bstate @@ -134,11 +145,10 @@
: see-bstate 0 begin - next-bstate - dup 0 = if - cr - then - dup . key? + next-bstate dup . + dup 4 = if + cr + then key? until ;
@@ -155,11 +165,32 @@ until ;
+\ Get platformID so we can decide if this is a gen 1 or gen 1.5 +: bat-pid@ ( -- id ) ec-platformID ec-ram@ ; + +\ Gen 1.5 Leds are PWM. In the interest of simplicity this just +\ adjusts the pwm value rather than fully turning the led off because +\ for off you have to disable the pwm and then set it to IO low. +\ pwm value of 0x00 is the same as full scale. +: bat-red-led-pwm-on ( -- ) h# ff ec-pwmbase ec-pwmhigh4 + ec! ; +: bat-green-led-pwm-on ( -- ) h# ff ec-pwmbase ec-pwmhigh2 + ec! ; +: bat-yellow-led-pwm-on ( -- ) bat-red-led-pwm-on bat-green-led-pwm-on ; +: bat-red-led-pwm-off ( -- ) h# 01 ec-pwmbase ec-pwmhigh4 + ec! ; +: bat-green-led-pwm-off ( -- ) h# 01 ec-pwmbase ec-pwmhigh2 + ec! ; +: bat-yellow-led-pwm-off ( -- ) bat-red-led-pwm-off bat-green-led-pwm-off ; + +\ On XO 1 we just clear the IO on Gen 1.5 its bit more complex +: bat-chg-led-off + bat-pid@ h# cf > if bat-yellow-led-pwm-off else + fc24 ec@ 03 or fc24 ec! + then +; + \ Turn on the charging mosfet : bat-enable-charge ( -- ) fc21 ec@ 40 or fc21 ec! ;
\ Turn off the charging mosfet -: bat-disable-charge ( -- ) fc21 ec@ 40 invert and fc21 ec! 03 fc24 ec! ; +: bat-disable-charge ( -- ) fc21 ec@ 40 invert and fc21 ec! bat-chg-led-off ;
\ Turn on the trickle charge with max system voltage : bat-enable-trickle ( -- ) fc23 ec@ 1 or fc23 ec! 01 fc24 ec! ; @@ -470,40 +501,45 @@ r> base ! ;
+\ Retrieve the key battery stats in bulk and put it on the stack +\ sign extending the values that are 2's complement. +: bg-charge-info@ + ds-bank-buf 6 h# 0c 1w-read ( ) + ds-bank-buf c@ 8 << ( voltage_msb ) + ds-bank-buf 1 + c@ or s16>s32 ( voltage ) + ds-bank-buf 2 + c@ 8 << ( voltage current_msb ) + ds-bank-buf 3 + c@ or s16>s32 ( voltage current ) + ds-bank-buf 4 + c@ 8 << ( voltage current ACR_msb ) + ds-bank-buf 5 + c@ or s16>s32 ( voltage current ACR ) +; + : >sd.ddd ( n -- formatted ) base @ >r decimal - dup abs <# u# u# u# [char] . hold u#s rot sign u#> + dup abs <# u# u# u# [char] . hold u# u#s swap sign u#> r> base ! ;
: >sd.dd ( n -- formatted ) base @ >r decimal - dup abs <# u# u# [char] . hold u#s rot sign u#> + dup abs <# u# u# [char] . hold u# u#s swap sign u#> r> base ! ;
: bg-acr>mAh ( raw-value -- acr_in_mAh ) - abs d# 625 ( mV ) * d# 15 ( mOhm ) / - over 0< if negate then ;
: bg-V>V ( raw-value - Volts ) - abs d# 488 ( mV ) * 2* d# 100 / 5 >> - over 0< if negate then ;
: bg-I>mA ( raw-value -- I_in_mA ) - abs 3 >> + 3 >>a d# 15625 ( nV ) * d# 15 ( mOhm ) / d# 10 / - over 0< if negate then ;
: bg-temp>degc ( raw-value -- temp_in_degc ) - abs d# 125 * d# 10 / 5 >> - over 0< if negate then ;
h# 90 buffer: logstr @@ -515,6 +551,11 @@ <# " " hold$ u#s " 0x" hold$ u#> ;
+\ Read values directly rather than using the ec-cmd + +: bat-I@ ( -- rawI ) h# 02 bat-b@ 8 << h# 03 bat-b@ or s16>s32 ; +: bat-V@ ( -- rawV ) h# 00 bat-b@ 8 << h# 01 bat-b@ or s16>s32 ; + : bat-lfp-dataf@ base @ >r 0 logstr c! @@ -545,14 +586,15 @@ >sdx logstr $cat
decimal + bat-V@ bg-V>V >sd.ddd logstr $cat " " logstr $cat \ V + bat-I@ bg-I>mA >sd.dd logstr $cat " " logstr $cat \ I + h# 54 bat-b@ 8 << h# 55 bat-b@ or s16>s32 \ ACR bg-acr>mAh >sd.dd logstr $cat " " logstr $cat - h# 00 bat-b@ 8 << h# 01 bat-b@ or s16>s32 \ V - bg-V>V >sd.ddd logstr $cat " " logstr $cat - h# 02 bat-b@ 8 << h# 03 bat-b@ or s16>s32 \ I - bg-I>mA >sd.dd logstr $cat " " logstr $cat + h# 06 bat-b@ 8 << h# 07 bat-b@ or \ Temp bg-temp>degc >sd.dd logstr $cat " " logstr $cat + \ h# 17 bat-b@ 8 << h# 18 bat-b@ or \ NiMh Chargetime \ >sd logstr $cat
@@ -569,6 +611,18 @@ r> base ! ;
+: .bg-acr ( raw_acr_in_s32 -- ) + bg-acr>mAh >sd.dd type +; + +: .bg-current ( raw_I_in_s32 -- ) + bg-I>mA >sd.dd type +; + +: .bg-volt ( raw_V_in_s32 -- ) + bg-V>V >sd.ddd type +; + : bat-debug begin bat-lfp-dataf@ @@ -591,6 +645,27 @@ ofd @ fclose ;
+ +0 value bg-last-acr +0 value bg-v_avg + +: bat-charge ( -- ) + batman-init? + bat-enable-charge + bg-acr@ + begin + bg-charge-info@ + dup to bg-last-acr + ." ACR:" .bg-acr ." I:" .bg-current ." V:" .bg-volt + dup bg-last-acr swap - ." Chg:" .bg-acr + cr + 500 ms + key? + until + drop + bat-disable-charge +; + dev / new-device " battery" device-name
