Author: wmb Date: Sat Aug 6 00:28:47 2011 New Revision: 2420 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2420
Log: Removed carriage returns from line endings in a file.
Modified: dev/intel/graphics/pineview.fth
Modified: dev/intel/graphics/pineview.fth ============================================================================== --- dev/intel/graphics/pineview.fth Sat Aug 6 00:26:44 2011 (r2419) +++ dev/intel/graphics/pineview.fth Sat Aug 6 00:28:47 2011 (r2420) @@ -1,424 +1,424 @@ -\ See license at end of file -purpose: Display driver for Intel Pineview using 1280x800 LCD panel on LVDS - -\ This is an i915 variant. The driver hardcodes some assumptions about display -\ resolution and output device. - -\ 0 0 " 2,0" " /pci" begin-package - -" display" device-name - -\ Configuration space registers -my-address my-space encode-phys - 0 encode-int encode+ 0 encode-int encode+ - -\ MMIO register bank -0 0 my-space 0200.0010 + encode-phys encode+ - 0 encode-int encode+ h# 80000 encode-int encode+ - -\ I/O Space registers -0 0 my-space h# 0100.0014 + encode-phys encode+ - 0 encode-int encode+ 8 encode-int encode+ - -\ Aperture -0 0 my-space h# 0200.0018 + encode-phys encode+ - 0 encode-int encode+ h# 1000.0000 encode-int encode+ - -\ GATT -0 0 my-space h# 0200.001c + encode-phys encode+ - 0 encode-int encode+ h# 0004.0000 encode-int encode+ - - " reg" property - -: my-l@ ( offset -- l ) my-space + " config-l@" $call-parent ; -: my-l! ( l offset -- ) my-space + " config-l!" $call-parent ; -: my-w@ ( offset -- w ) my-space + " config-w@" $call-parent ; -: my-w! ( w offset -- ) my-space + " config-w!" $call-parent ; - -false value scaled? - -d# 16 value depth - -0 value vdc -: page-bits ( n -- n' ) h# fff invert and ; - -: pci-len ( bar-offset -- len ) - >r - r@ my-l@ ( oldval ) - -1 r@ my-l! ( oldval ) - r@ my-l@ ( oldval writable-bits ) - swap r> my-l! ( writable-bits ) - h# f invert and ( top-bits ) - invert 1+ ( len ) -; - -0 value gtt -0 value gatt - -0 value gtt-phys -0 value gatt-phys -0 value gtt-start -0 value /gtt -0 value /gatt -0 value stolen-base -0 value scratch-page -0 value scratch-page-pa - -h# 20.0000 value /fb \ Enough for 1280x800x16bpp - -: mmio@ ( offset -- l ) vdc + rl@ ; -: mmio! ( l offset -- ) vdc + rl! ; - -: adr>page# ( adr -- page# ) d# 12 rshift ; -: page#>adr ( page# -- adr ) d# 12 lshift ; -h# 1000 constant /page - -: map-bar ( phys.lo len bar# -- vadr ) - swap >r ( phys.lo bar# r: len ) - my-space + h# 200.0000 + ( phys.lo phys.hi r: len ) - 0 swap r> ( phys.lo,mid,hi len ) - " map-in" $call-parent -; - -: /stolen ( -- n ) - h# 52 my-w@ 4 >> h# f and case - 0 of 0 endof - 1 of h# 10.0000 endof - 3 of h# 80.0000 endof - true abort" Invalid value in Graphics Mode Select field" - endcase -; -: init-gtt ( -- ) - h# 18 my-l@ page-bits to gatt-phys - h# 1c my-l@ page-bits to gtt-start - h# 1c pci-len to /gtt \ Can also be determined from config register 52 - h# 18 pci-len to /gatt - h# 5c my-l@ to stolen-base - - h# 0 /gtt h# 1c map-bar to gtt - - \ Insert the stolen pages into the GTT - stolen-base 1 + ( pte-template ) - /stolen 0 do ( pte-template ) - dup i + gtt i adr>page# la+ rl! ( pte-template ) - /page +loop ( pte-template ) - drop - - \ Fill the rest of the GTT with PTEs for a scratch page - /page " dma-alloc" $call-parent to scratch-page - scratch-page h# 1000 false " dma-map-in" $call-parent to scratch-page-pa - - /gatt /stolen ?do - scratch-page-pa 1+ gtt i adr>page# la+ rl! - /page +loop - - gtt /gtt + /page - rl@ drop \ Sync -; -: memory-setup ( -- ) - h# 0 h# 80000 h# 10 map-bar to vdc \ & - 4 my-w@ 7 or 4 my-w! \ Enable bus mastering, memory and I/O access - - init-gtt - - " address" get-my-property if - gatt-phys encode-int " address" property - h# 0 /fb h# 18 map-bar to frame-buffer-adr - else - decode-int to frame-buffer-adr - 2drop - then -; - -\ Geometry for 1280x800 LCD - -d# 1280 constant hdisplay -d# 1296 constant hsstart -d# 1344 constant hsend -d# 1440 constant htotal - -d# 800 constant vdisplay -d# 801 constant vsstart -d# 804 constant vsend -d# 818 constant vtotal - -d# 1024 value width \ If scaled is false, will be replaced with hdisplay -d# 768 value height \ If scaled is false, will be replaced with vdisplay - -\ h# d804.0000 constant dpll-val \ VCO, high speed, VGA disable, LVDS, clock div 10, post div 4 -h# 8480.0000 constant dpll-val-a \ Pipe A & -h# 9802.0000 constant dpll-val-b \ Pipe B & -dpll-val-b constant dpll-val - -h# 0020.0074 constant fp-val \ N, M1, M2 divisors & -h# 9500.0000 constant dspcntr-val \ Enable, NoGamma, 16bpp ? no alpha, pipe b & - -\ Empirically this has no effect. It is probably for CRT output -\ : dac-on ( -- ) -\ h# c000.0018 h# 61100 mmio! \ 80000000-DAC_ON 40000000-PIPEB 10-PVSYNC 8-PHSYNC -\ ; - -: bytes/line ( -- n ) width depth 8 / * ; - -h# 0000 constant pipe-a -h# 1000 constant pipe-b -pipe-b value pipe - -: mmio!! ( value offset -- ) tuck mmio! mmio@ drop ; - -: pipe@ ( offset -- n ) pipe + mmio@ ; -: pipe! ( n offset -- ) pipe + mmio! ; -: pipe!! ( n offset -- ) pipe + mmio!! ; - -h# 70180 constant dspcntr-reg -h# 70184 constant dspbase-reg -h# 70008 constant pipeconf-reg -h# 61230 constant pfit-reg -h# 61180 constant lvds-reg - -\ Packs two 16-bit values into a 32-bit register, offsetting -\ each value by -1 -: crtconf! ( low high reg -- ) - >r swap 1- swap 1- wljoin r> pipe! -; - -\ A few of the pipe-dependent registers are at offsets of 4 -\ instead of h# 1000. - -: +pipe ( offset -- offset' ) pipe if 4 + then ; - -: fpreg! ( value -- ) h# 6040 +pipe mmio! ; - -: dpll! ( value -- ) - h# 6014 +pipe mmio!! - d# 150 " us" evaluate -; -: dpll@ ( -- value ) h# 6014 +pipe mmio@ ; -: wait-vblank ( -- ) d# 30 ms ; - -h# 8000.0000 constant enable-bit - -: load-lut ( -- ) - 100 0 do - i i i 0 bljoin h# a000 pipe 2/ + i la+ l! - loop -; - -: crtc-dpms-off ( -- ) \ CRTC prepare method - \ Disable display plane - dspcntr-reg pipe@ ( val ) - dup enable-bit and if ( val ) - enable-bit invert and dspcntr-reg pipe! - dspbase-reg pipe@ dspbase-reg pipe!! - else - drop - then - wait-vblank - - \ Disable display pipes - pipeconf-reg pipe@ ( val ) - dup enable-bit and if ( val ) - enable-bit invert and pipeconf-reg pipe!! - else - drop - then - wait-vblank - - dpll@ dup enable-bit and if - enable-bit invert and dpll! - else - drop - then -; - -: crtc-dpms-on ( -- ) \ CRTC commit method - dpll@ dup enable-bit and 0= if ( value ) - dup dpll! ( value ) - enable-bit or dup dpll! dpll! ( ) - else ( value ) - drop ( ) - then - - pipeconf-reg pipe@ dup enable-bit and 0= if - enable-bit or pipeconf-reg pipe! - else - drop - then - - dspcntr-reg pipe@ dup enable-bit and if - enable-bit or dspcntr-reg pipe! - dspbase-reg pipe@ dspbase-reg pipe! - else - drop - then - - load-lut -; - -: lvds-set-mode ( -- ) - \ When using LVDS, you have to do this little dance to turn on the PLL - - fp-val fpreg! - dpll-val enable-bit invert and dpll! \ VCO_ENABLE off for now - - lvds-reg mmio@ \ LVDS configuration - h# c030.0300 or \ LVDS_PORT_EN , LVDS_PIPEB_SELECT , LVDS_A0A2_CLKA_POWER_UP ?? what is 30.0000 bit - h# 0000.003c invert and \ ! LVDS_CLKB_POWER_UP , ! LVDS_B0B3_POWER_UP - lvds-reg mmio!! - - fp-val fpreg! - dpll-val dpll! \ VCO_ENABLE on - - \ Double write because Linux driver does it because BIOS does it - dpll-val dpll! \ VCO_ENABLE on - - \ Now that the dance is over we can configure the geometry - - hdisplay htotal h# 60000 crtconf! \ H Display - hdisplay htotal h# 60004 crtconf! \ H Blanking - hsstart hsend h# 60008 crtconf! \ H Sync - vdisplay vtotal h# 6000c crtconf! \ V Display - vdisplay vtotal h# 60010 crtconf! \ V Blanking - vsstart vsend h# 60014 crtconf! \ V Sync - - bytes/line h# 70188 pipe! \ Pitch (stride) - width height h# 70190 crtconf! \ Size - 0 h# 7018c pipe! \ Position - height width h# 6001c crtconf! \ Pipe source - enable-bit pipeconf-reg pipe!! \ Pipe config - - wait-vblank - - dspcntr-val dspcntr-reg pipe! \ Display control - - 0 dspbase-reg pipe! \ PIPExBASE - - enable-bit h# 71400 mmio! \ Disable VGA plane - - wait-vblank -; - -d# 100 constant backlight-min-period -false value backlight-inverse? -: set-backlight ( percentage -- ) - h# 61254 mmio@ lwsplit nip ( percent max ) - backlight-min-period max ( percent max' ) - 1 invert and >r ( percent r: max' ) - - d# 20 max ( percentage' r: max ) - r@ * d# 100 / ( duty-cycle r: max ) - - backlight-inverse? if ( duty-cycle r: max ) - r@ swap - ( duty-cycle' ) - then ( duty-cycle r: max ) - - 1 invert and ( duty-cycle r: max ) \ Low bit must be 0 - r> wljoin h# 61254 mmio! ( ) \ BLC_PWM_CTL -; - -d# 100 value backlight-val - -h# 61200 constant pp-status -h# 61204 constant pp-control -: lvds-on ( -- ) - pp-control mmio@ 1 or pp-control mmio! \ POWER_TARGET_ON - begin pp-status mmio@ enable-bit and until - backlight-val set-backlight -; -: lvds-off ( -- ) - 0 set-backlight - pp-control mmio@ 1 invert and pp-control mmio! - begin pp-status mmio@ enable-bit and 0= until -; - -: .ps pp-status mmio@ . ; -: pctl pp-control mmio! ; - -: lvds-scaling ( -- ) - scaled? if h# 8000.2668 else 0 then - pfit-reg mmio! -\ pipe h# 1000 / d# 29 lshift pfit-reg mmio! -; -: setmode ( -- ) - scaled? if d# 1024 d# 768 else hdisplay vdisplay then - to height to width - memory-setup - lvds-off \ Output prepare method - crtc-dpms-off \ CRTC prepare method - lvds-set-mode \ CRTC mode_set method - lvds-scaling \ Output mode_set method - crtc-dpms-on \ CRTC commit method - lvds-on \ Output commit method -; - -: erase-frame-buffer ( -- ) - frame-buffer-adr /fb ( adr len ) - depth case - 8 of h# 0f fill endof - d# 16 of h# ffff " wfill" evaluate endof - d# 32 of h# ffff.ffff " lfill" evaluate endof - ( default ) nip nip - endcase - h# f to background-color -; -: map-frame-buffer ( -- ) - 0 /fb h# 18 map-bar to frame-buffer-adr -; -: dump-regs ( -- ) - h# 80000 0 do - i mmio@ dup 0<> swap h# ffffffff <> and if - i 5 u.r i mmio@ 9 u.r cr - then - 4 +loop -; - -: declare-props ( -- ) \ Instantiate screen properties - " width" get-my-property if - width encode-int " width" property - height encode-int " height" property - depth encode-int " depth" property - bytes/line encode-int " linebytes" property - else - 2drop - then -; - -defer gp-install ' noop to gp-install - -: set-terminal ( -- ) - width height ( width height ) - over char-width / over char-height / ( width height rows cols ) - bytes/line depth " fb-install" evaluate gp-install ( ) -; - - -0 value open-count - -: display-remove ( -- ) - open-count 1 = if - then - open-count 1- 0 max to open-count -; - -: display-install ( -- ) - open-count 0= if - setmode - declare-props \ Setup properites - map-frame-buffer - erase-frame-buffer - else - map-frame-buffer - then - default-font set-font - set-terminal - open-count 1+ to open-count -; - -: display-selftest ( -- failed? ) false ; - -' display-install is-install -' display-remove is-remove -' display-selftest is-selftest - -" display" device-type -" ISO8859-1" encode-string " character-set" property -0 0 encode-bytes " iso6429-1983-colors" property +\ See license at end of file +purpose: Display driver for Intel Pineview using 1280x800 LCD panel on LVDS + +\ This is an i915 variant. The driver hardcodes some assumptions about display +\ resolution and output device. + +\ 0 0 " 2,0" " /pci" begin-package + +" display" device-name + +\ Configuration space registers +my-address my-space encode-phys + 0 encode-int encode+ 0 encode-int encode+ + +\ MMIO register bank +0 0 my-space 0200.0010 + encode-phys encode+ + 0 encode-int encode+ h# 80000 encode-int encode+ + +\ I/O Space registers +0 0 my-space h# 0100.0014 + encode-phys encode+ + 0 encode-int encode+ 8 encode-int encode+ + +\ Aperture +0 0 my-space h# 0200.0018 + encode-phys encode+ + 0 encode-int encode+ h# 1000.0000 encode-int encode+ + +\ GATT +0 0 my-space h# 0200.001c + encode-phys encode+ + 0 encode-int encode+ h# 0004.0000 encode-int encode+ + + " reg" property + +: my-l@ ( offset -- l ) my-space + " config-l@" $call-parent ; +: my-l! ( l offset -- ) my-space + " config-l!" $call-parent ; +: my-w@ ( offset -- w ) my-space + " config-w@" $call-parent ; +: my-w! ( w offset -- ) my-space + " config-w!" $call-parent ; + +false value scaled? + +d# 16 value depth + +0 value vdc +: page-bits ( n -- n' ) h# fff invert and ; + +: pci-len ( bar-offset -- len ) + >r + r@ my-l@ ( oldval ) + -1 r@ my-l! ( oldval ) + r@ my-l@ ( oldval writable-bits ) + swap r> my-l! ( writable-bits ) + h# f invert and ( top-bits ) + invert 1+ ( len ) +; + +0 value gtt +0 value gatt + +0 value gtt-phys +0 value gatt-phys +0 value gtt-start +0 value /gtt +0 value /gatt +0 value stolen-base +0 value scratch-page +0 value scratch-page-pa + +h# 20.0000 value /fb \ Enough for 1280x800x16bpp + +: mmio@ ( offset -- l ) vdc + rl@ ; +: mmio! ( l offset -- ) vdc + rl! ; + +: adr>page# ( adr -- page# ) d# 12 rshift ; +: page#>adr ( page# -- adr ) d# 12 lshift ; +h# 1000 constant /page + +: map-bar ( phys.lo len bar# -- vadr ) + swap >r ( phys.lo bar# r: len ) + my-space + h# 200.0000 + ( phys.lo phys.hi r: len ) + 0 swap r> ( phys.lo,mid,hi len ) + " map-in" $call-parent +; + +: /stolen ( -- n ) + h# 52 my-w@ 4 >> h# f and case + 0 of 0 endof + 1 of h# 10.0000 endof + 3 of h# 80.0000 endof + true abort" Invalid value in Graphics Mode Select field" + endcase +; +: init-gtt ( -- ) + h# 18 my-l@ page-bits to gatt-phys + h# 1c my-l@ page-bits to gtt-start + h# 1c pci-len to /gtt \ Can also be determined from config register 52 + h# 18 pci-len to /gatt + h# 5c my-l@ to stolen-base + + h# 0 /gtt h# 1c map-bar to gtt + + \ Insert the stolen pages into the GTT + stolen-base 1 + ( pte-template ) + /stolen 0 do ( pte-template ) + dup i + gtt i adr>page# la+ rl! ( pte-template ) + /page +loop ( pte-template ) + drop + + \ Fill the rest of the GTT with PTEs for a scratch page + /page " dma-alloc" $call-parent to scratch-page + scratch-page h# 1000 false " dma-map-in" $call-parent to scratch-page-pa + + /gatt /stolen ?do + scratch-page-pa 1+ gtt i adr>page# la+ rl! + /page +loop + + gtt /gtt + /page - rl@ drop \ Sync +; +: memory-setup ( -- ) + h# 0 h# 80000 h# 10 map-bar to vdc \ & + 4 my-w@ 7 or 4 my-w! \ Enable bus mastering, memory and I/O access + + init-gtt + + " address" get-my-property if + gatt-phys encode-int " address" property + h# 0 /fb h# 18 map-bar to frame-buffer-adr + else + decode-int to frame-buffer-adr + 2drop + then +; + +\ Geometry for 1280x800 LCD + +d# 1280 constant hdisplay +d# 1296 constant hsstart +d# 1344 constant hsend +d# 1440 constant htotal + +d# 800 constant vdisplay +d# 801 constant vsstart +d# 804 constant vsend +d# 818 constant vtotal + +d# 1024 value width \ If scaled is false, will be replaced with hdisplay +d# 768 value height \ If scaled is false, will be replaced with vdisplay + +\ h# d804.0000 constant dpll-val \ VCO, high speed, VGA disable, LVDS, clock div 10, post div 4 +h# 8480.0000 constant dpll-val-a \ Pipe A & +h# 9802.0000 constant dpll-val-b \ Pipe B & +dpll-val-b constant dpll-val + +h# 0020.0074 constant fp-val \ N, M1, M2 divisors & +h# 9500.0000 constant dspcntr-val \ Enable, NoGamma, 16bpp ? no alpha, pipe b & + +\ Empirically this has no effect. It is probably for CRT output +\ : dac-on ( -- ) +\ h# c000.0018 h# 61100 mmio! \ 80000000-DAC_ON 40000000-PIPEB 10-PVSYNC 8-PHSYNC +\ ; + +: bytes/line ( -- n ) width depth 8 / * ; + +h# 0000 constant pipe-a +h# 1000 constant pipe-b +pipe-b value pipe + +: mmio!! ( value offset -- ) tuck mmio! mmio@ drop ; + +: pipe@ ( offset -- n ) pipe + mmio@ ; +: pipe! ( n offset -- ) pipe + mmio! ; +: pipe!! ( n offset -- ) pipe + mmio!! ; + +h# 70180 constant dspcntr-reg +h# 70184 constant dspbase-reg +h# 70008 constant pipeconf-reg +h# 61230 constant pfit-reg +h# 61180 constant lvds-reg + +\ Packs two 16-bit values into a 32-bit register, offsetting +\ each value by -1 +: crtconf! ( low high reg -- ) + >r swap 1- swap 1- wljoin r> pipe! +; + +\ A few of the pipe-dependent registers are at offsets of 4 +\ instead of h# 1000. + +: +pipe ( offset -- offset' ) pipe if 4 + then ; + +: fpreg! ( value -- ) h# 6040 +pipe mmio! ; + +: dpll! ( value -- ) + h# 6014 +pipe mmio!! + d# 150 " us" evaluate +; +: dpll@ ( -- value ) h# 6014 +pipe mmio@ ; +: wait-vblank ( -- ) d# 30 ms ; + +h# 8000.0000 constant enable-bit + +: load-lut ( -- ) + 100 0 do + i i i 0 bljoin h# a000 pipe 2/ + i la+ l! + loop +; + +: crtc-dpms-off ( -- ) \ CRTC prepare method + \ Disable display plane + dspcntr-reg pipe@ ( val ) + dup enable-bit and if ( val ) + enable-bit invert and dspcntr-reg pipe! + dspbase-reg pipe@ dspbase-reg pipe!! + else + drop + then + wait-vblank + + \ Disable display pipes + pipeconf-reg pipe@ ( val ) + dup enable-bit and if ( val ) + enable-bit invert and pipeconf-reg pipe!! + else + drop + then + wait-vblank + + dpll@ dup enable-bit and if + enable-bit invert and dpll! + else + drop + then +; + +: crtc-dpms-on ( -- ) \ CRTC commit method + dpll@ dup enable-bit and 0= if ( value ) + dup dpll! ( value ) + enable-bit or dup dpll! dpll! ( ) + else ( value ) + drop ( ) + then + + pipeconf-reg pipe@ dup enable-bit and 0= if + enable-bit or pipeconf-reg pipe! + else + drop + then + + dspcntr-reg pipe@ dup enable-bit and if + enable-bit or dspcntr-reg pipe! + dspbase-reg pipe@ dspbase-reg pipe! + else + drop + then + + load-lut +; + +: lvds-set-mode ( -- ) + \ When using LVDS, you have to do this little dance to turn on the PLL + + fp-val fpreg! + dpll-val enable-bit invert and dpll! \ VCO_ENABLE off for now + + lvds-reg mmio@ \ LVDS configuration + h# c030.0300 or \ LVDS_PORT_EN , LVDS_PIPEB_SELECT , LVDS_A0A2_CLKA_POWER_UP ?? what is 30.0000 bit + h# 0000.003c invert and \ ! LVDS_CLKB_POWER_UP , ! LVDS_B0B3_POWER_UP + lvds-reg mmio!! + + fp-val fpreg! + dpll-val dpll! \ VCO_ENABLE on + + \ Double write because Linux driver does it because BIOS does it + dpll-val dpll! \ VCO_ENABLE on + + \ Now that the dance is over we can configure the geometry + + hdisplay htotal h# 60000 crtconf! \ H Display + hdisplay htotal h# 60004 crtconf! \ H Blanking + hsstart hsend h# 60008 crtconf! \ H Sync + vdisplay vtotal h# 6000c crtconf! \ V Display + vdisplay vtotal h# 60010 crtconf! \ V Blanking + vsstart vsend h# 60014 crtconf! \ V Sync + + bytes/line h# 70188 pipe! \ Pitch (stride) + width height h# 70190 crtconf! \ Size + 0 h# 7018c pipe! \ Position + height width h# 6001c crtconf! \ Pipe source + enable-bit pipeconf-reg pipe!! \ Pipe config + + wait-vblank + + dspcntr-val dspcntr-reg pipe! \ Display control + + 0 dspbase-reg pipe! \ PIPExBASE + + enable-bit h# 71400 mmio! \ Disable VGA plane + + wait-vblank +; + +d# 100 constant backlight-min-period +false value backlight-inverse? +: set-backlight ( percentage -- ) + h# 61254 mmio@ lwsplit nip ( percent max ) + backlight-min-period max ( percent max' ) + 1 invert and >r ( percent r: max' ) + + d# 20 max ( percentage' r: max ) + r@ * d# 100 / ( duty-cycle r: max ) + + backlight-inverse? if ( duty-cycle r: max ) + r@ swap - ( duty-cycle' ) + then ( duty-cycle r: max ) + + 1 invert and ( duty-cycle r: max ) \ Low bit must be 0 + r> wljoin h# 61254 mmio! ( ) \ BLC_PWM_CTL +; + +d# 100 value backlight-val + +h# 61200 constant pp-status +h# 61204 constant pp-control +: lvds-on ( -- ) + pp-control mmio@ 1 or pp-control mmio! \ POWER_TARGET_ON + begin pp-status mmio@ enable-bit and until + backlight-val set-backlight +; +: lvds-off ( -- ) + 0 set-backlight + pp-control mmio@ 1 invert and pp-control mmio! + begin pp-status mmio@ enable-bit and 0= until +; + +: .ps pp-status mmio@ . ; +: pctl pp-control mmio! ; + +: lvds-scaling ( -- ) + scaled? if h# 8000.2668 else 0 then + pfit-reg mmio! +\ pipe h# 1000 / d# 29 lshift pfit-reg mmio! +; +: setmode ( -- ) + scaled? if d# 1024 d# 768 else hdisplay vdisplay then + to height to width + memory-setup + lvds-off \ Output prepare method + crtc-dpms-off \ CRTC prepare method + lvds-set-mode \ CRTC mode_set method + lvds-scaling \ Output mode_set method + crtc-dpms-on \ CRTC commit method + lvds-on \ Output commit method +; + +: erase-frame-buffer ( -- ) + frame-buffer-adr /fb ( adr len ) + depth case + 8 of h# 0f fill endof + d# 16 of h# ffff " wfill" evaluate endof + d# 32 of h# ffff.ffff " lfill" evaluate endof + ( default ) nip nip + endcase + h# f to background-color +; +: map-frame-buffer ( -- ) + 0 /fb h# 18 map-bar to frame-buffer-adr +; +: dump-regs ( -- ) + h# 80000 0 do + i mmio@ dup 0<> swap h# ffffffff <> and if + i 5 u.r i mmio@ 9 u.r cr + then + 4 +loop +; + +: declare-props ( -- ) \ Instantiate screen properties + " width" get-my-property if + width encode-int " width" property + height encode-int " height" property + depth encode-int " depth" property + bytes/line encode-int " linebytes" property + else + 2drop + then +; + +defer gp-install ' noop to gp-install + +: set-terminal ( -- ) + width height ( width height ) + over char-width / over char-height / ( width height rows cols ) + bytes/line depth " fb-install" evaluate gp-install ( ) +; + + +0 value open-count + +: display-remove ( -- ) + open-count 1 = if + then + open-count 1- 0 max to open-count +; + +: display-install ( -- ) + open-count 0= if + setmode + declare-props \ Setup properites + map-frame-buffer + erase-frame-buffer + else + map-frame-buffer + then + default-font set-font + set-terminal + open-count 1+ to open-count +; + +: display-selftest ( -- failed? ) false ; + +' display-install is-install +' display-remove is-remove +' display-selftest is-selftest + +" display" device-type +" ISO8859-1" encode-string " character-set" property +0 0 encode-bytes " iso6429-1983-colors" property
