Author: quozl Date: Sat Jun 2 12:02:39 2012 New Revision: 2998 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2998
Log: OLPC - test menu, automatic tests; maintain an overall failure state and report it at the end, handle any escape request from the hold message, make the quit item the default afterwards, and provide the timed menu again. #11847.
Modified: cpu/x86/pc/olpc/via/mfgtest.fth
Modified: cpu/x86/pc/olpc/via/mfgtest.fth ============================================================================== --- cpu/x86/pc/olpc/via/mfgtest.fth Fri Jun 1 20:57:38 2012 (r2997) +++ cpu/x86/pc/olpc/via/mfgtest.fth Sat Jun 2 12:02:39 2012 (r2998) @@ -31,6 +31,8 @@ warning on
0 value pass? +0 value overall-fail? +0 value stop?
: mfg-wait-return ( -- ) ." ... Press any key to proceed ... " @@ -52,7 +54,7 @@ ?dup if ( return-code ) ??cr ." Selftest failed. Return code = " .d cr mfg-color-red sq-border! - false to pass? + false to pass? true to overall-fail? red-screen flush-keyboard mfg-wait-return @@ -62,12 +64,12 @@ cancel mfg-color-green sq-border! true to pass? - d# 2000 hold-message drop + d# 2000 hold-message if true to stop? then then else ??cr ." Selftest failed due to abort" cr mfg-color-red sq-border! - false to pass? + false to pass? true to overall-fail? red-screen flush-keyboard mfg-wait-return @@ -95,11 +97,16 @@ mfg-test-result ;
-: all-tests-passed ( -- ) +: overall ( -- ) restore-scroller-bg clear-screen - ." All automatic tests passed successfully." cr cr cr - green-screen + overall-fail? if + ." Some tests failed." cr cr cr + red-screen + else + ." All automatic tests passed successfully." cr cr cr + green-screen + then wait-return cursor-off scroller-off gui-alerts refresh flush-keyboard @@ -140,6 +147,8 @@ icon: quit.icon rom:quit.565
: play-item ( -- ) \ Interactive autorun of all tests + false to overall-fail? + false to stop? #mfgcols #mfgtests + #mfgcols ?do i set-current-sq refresh @@ -147,12 +156,14 @@ d# 10 ms key? if unloop unloop exit then loop run-menu-item - pass? 0= if unloop exit then + stop? if unloop exit then loop - all-tests-passed + 0 3 rc>sq set-current-sq \ quit-item + overall ;
-: quit-item ( -- ) menu-done ; +false value quit? +: quit-item ( -- ) true to quit? menu-done ;
: init-menu ( -- ) ?open-screen ?open-pointer @@ -196,8 +207,8 @@ restore-scroller-bg ;
-: autorun-from-gamekey ( -- ) - default-selection set-current-sq refresh +: pause-to-interact + refresh (cr kill-line 0 d# 30 do i d# 10 mod 0= if (cr i d# 10 / .d then @@ -205,12 +216,25 @@ key? or if ( ) drop ( ) menu-interact ( ) + true to quit? unloop exit ( -- ) then ( ) d# 100 ms ( ) -1 +loop +; + +: autorun-from-gamekey ( -- ) + false to quit? + default-selection set-current-sq + pause-to-interact + quit? if exit then play-item + stop? if menu-interact exit then + quit? if exit then + 0 3 rc>sq set-current-sq \ quit-item + pause-to-interact ; + : gamekey-auto-menu ( -- ) ['] run-menu behavior >r ['] autorun-from-gamekey to run-menu \ Run menu automatically after a timeout
