Author: wmb Date: Tue Nov 15 02:13:49 2011 New Revision: 2685 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2685
Log: ARM - removed duplicate definition in cpu/arm/scc.fth - no functional change.
Modified: cpu/arm/scc.fth
Modified: cpu/arm/scc.fth ============================================================================== --- cpu/arm/scc.fth Mon Nov 14 05:26:21 2011 (r2684) +++ cpu/arm/scc.fth Tue Nov 15 02:13:49 2011 (r2685) @@ -99,7 +99,6 @@
code drain-write-buffer ( -- ) mcr p15,0,r0,cr7,cr10,4 c; alias data-sync-barrier drain-write-buffer -code drain-write-buffer ( -- ) mcr p15,0,r0,cr7,cr10,4 c; code data-memory-barrier ( -- ) mcr p15,0,r0,cr7,cr10,5 c;
code flush-i&d-tlb ( -- ) mcr p15,0,r0,cr8,cr7,0 c;
