Author: wmb Date: 2009-08-09 05:38:09 +0200 (Sun, 09 Aug 2009) New Revision: 1289
Modified: dev/via/unichrome/unichrome.fth Log: Via unichrome display driver changes in support of camera selftest.
Modified: dev/via/unichrome/unichrome.fth =================================================================== --- dev/via/unichrome/unichrome.fth 2009-08-09 03:34:40 UTC (rev 1288) +++ dev/via/unichrome/unichrome.fth 2009-08-09 03:38:09 UTC (rev 1289) @@ -4,15 +4,19 @@ hex headers
+\ These are non-instance values because we don't want to change +\ their values on a nested open as happens with selftest and +\ the camera sub-node's selftest.
-\ width and height are global instead of instance values because -\ the seltest method needs to get their values in a fresh instance -\ with re-running the open method. -d# 1280 ( instance ) value width \ Frame buffer line width -d# 1024 ( instance ) value height \ Screen height -d# 16 ( instance ) value depth \ Bits per pixel -d# 1024 instance value /scanline \ Frame buffer line width +0 value fb-va +0 value graphmem +0 value mmio-base
+d# 1280 value width \ Frame buffer line width +d# 1024 value height \ Screen height +d# 16 value depth \ Bits per pixel +d# 1024 value /scanline \ Frame buffer line width + : set-resolution ( width height depth -- ) to depth to height to width ; @@ -30,8 +34,6 @@
: /fb ( -- ) /scanline height * ; \ Size of framebuffer
-0 instance value mmio-base - : map-io-regs ( -- ) mmio-base if exit then (map-io-regs) to mmio-base @@ -40,8 +42,8 @@ ;
: map-frame-buffer ( -- ) - (map-frame-buffer) to frame-buffer-adr - frame-buffer-adr encode-int " address" property + (map-frame-buffer) to fb-va + fb-va encode-int " address" property ;
@@ -602,15 +604,13 @@
defer init-display ' init-primary-display is init-display
-0 instance value graphmem - : init-frame-buffer ( -- ) \ Initializes the controller \ smb-init \ set-dac-colors \ Set up initial color map \ video-on \ Turn on video
map-frame-buffer - frame-buffer-adr /fb ( adr len ) + fb-va /fb ( adr len ) depth case 8 of h# 0f fill endof d# 16 of background-rgb rgb>565 wfill endof @@ -619,7 +619,7 @@ endcase h# f to background-color
- frame-buffer-adr /fb + to graphmem + fb-va /fb + to graphmem ;
: set-fb ( -- ) @@ -628,16 +628,25 @@ /scanline depth fb-install ( gp-install ) ( ) ;
+0 value open-count + : display-remove ( -- ) + open-count 1 = if + then + open-count 1- 0 max to open-count ;
: display-install ( -- ) - map-io-regs \ Enable IO registers - init-display - init-frame-buffer - declare-props \ Setup properites + open-count 0= if + map-io-regs \ Enable IO registers + init-display + init-frame-buffer + declare-props \ Setup properites + then default-font set-font set-fb + fb-va to frame-buffer-adr + open-count 1+ to open-count ;
: display-selftest ( -- failed? ) false ;
