Author: wmb Date: Thu Nov 15 22:09:28 2012 New Revision: 3432 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3432
Log: OLPC ARM - In dcon node, changed the name to "clock-divider-regval"
Modified: cpu/arm/olpc/1.75/lcdcfg.fth
Modified: cpu/arm/olpc/1.75/lcdcfg.fth ============================================================================== --- cpu/arm/olpc/1.75/lcdcfg.fth Thu Nov 15 21:21:52 2012 (r3431) +++ cpu/arm/olpc/1.75/lcdcfg.fth Thu Nov 15 22:09:28 2012 (r3432) @@ -19,7 +19,6 @@ " OLPC DCON panel" model : +i encode-int encode+ ;
- h# 20001102 " set-clock-divider-regval" integer-property d# 4324096 " max-fb-size" integer-property
decimal @@ -32,7 +31,9 @@ " 1200x900@50" " linux,mode-names" string-property
h# 2000000d " lcd-dumb-ctrl-regval" integer-property - h# 08001100 " lcd-pn-ctrl0-regval" integer-property + h# 08001100 " lcd-pn-ctrl0-regval" integer-property + clkdiv " clock-divider-regval" integer-property \ Depends on MMP2 vs MMP3 + finish-device device-end
