Author: lwalter Date: Tue Aug 9 20:24:33 2011 New Revision: 2444 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2444
Log: Add mfgtest support
Added: cpu/x86/pc/alex/vstest.fth
Added: cpu/x86/pc/alex/vstest.fth ============================================================================== --- /dev/null 00:00:00 1970 (empty, because file is newly added) +++ cpu/x86/pc/alex/vstest.fth Tue Aug 9 20:24:33 2011 (r2444) @@ -0,0 +1,57 @@ +purpose: Video streaming test helper words +\ See license at end of file + +hex +headers + +load-base value vs-adr +0 value vs-/frame +0 value vs-height +0 value vs-width +0 value vs-x +0 value vs-y +d# 16 buffer: vs-guid +\ XXX Need support for other format than YUV2 frames. +: vs>screen ( -- ) + vs-adr dup vs-/frame yuv2>rgb + vs-adr vs-x vs-y vs-width vs-height " draw-rectangle" $call-screen +; + +: cfg-vs-test ( guid w h /frame -- xt adr ) + to vs-/frame to vs-height to vs-width + vs-guid d# 16 move + + ." Press a key to exit" + cursor-off + " dimensions" $call-screen ( w h ) + vs-height - 2/ to vs-y + vs-width - 2/ to vs-x + + ['] vs>screen vs-adr +; + + +\ LICENSE_BEGIN +\ Copyright (c) 2011 FirmWorks +\ +\ Permission is hereby granted, free of charge, to any person obtaining +\ a copy of this software and associated documentation files (the +\ "Software"), to deal in the Software without restriction, including +\ without limitation the rights to use, copy, modify, merge, publish, +\ distribute, sublicense, and/or sell copies of the Software, and to +\ permit persons to whom the Software is furnished to do so, subject to +\ the following conditions: +\ +\ The above copyright notice and this permission notice shall be +\ included in all copies or substantial portions of the Software. +\ +\ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, +\ EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF +\ MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND +\ NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE +\ LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION +\ OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION +\ WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. +\ +\ LICENSE_END +
