Author: wmb Date: Sat Oct 22 05:40:03 2011 New Revision: 2630 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2630
Log: OLPC XO-1.75 - added watch-dc-biased and watch-dc-unbiased commands for checking sensor input mode.
Modified: cpu/arm/olpc/1.75/alc5631.fth cpu/arm/olpc/1.75/sound.fth
Modified: cpu/arm/olpc/1.75/alc5631.fth ============================================================================== --- cpu/arm/olpc/1.75/alc5631.fth Sat Oct 22 05:39:56 2011 (r2629) +++ cpu/arm/olpc/1.75/alc5631.fth Sat Oct 22 05:40:03 2011 (r2630) @@ -30,7 +30,7 @@ \ The speaker gain ratio must be <= the ratio of SPKVDD to AVDD. \ In our system, SPKVDD is 5V and AVDD is 3.3V, so we need a gain ratio <= 1.51 . \ The value 3 gives a ratio of 1.44, and value 4 gives a ratio of 1.56 . We use 3. - h# 3e00 h# 40 codec! \ Speaker Amp Ratio GAIN is 1.44x, no HPFs + h# 3e00 h# 40 codec! \ Speaker Amp Ratio GAIN is 1.44x, HPF on ADC and DAC
h# 0000 h# 42 codec! \ Use MCLK, not PLL \ b# 1110.1100.1001.0000 h# 52 codec! \ Protection on @@ -42,10 +42,10 @@ : mic-bias-off ( -- ) h# 000c h# 3b codec-clr ; : mic-bias-on ( -- ) h# 000c h# 3b codec-set ;
-: mic1-high-bias ( -- ) h# 80 h# 22 codec-clr mic-bias-on ; \ 0.90*AVDD, e.g. 3V with AVDD=3.3V -: mic1-low-bias ( -- ) h# 80 h# 22 codec-set mic-bias-on ; \ 0.75*AVDD, e.g. 2.5V with AVDD=3.3V -: mic2-high-bias ( -- ) h# 08 h# 22 codec-clr mic-bias-on ; \ 0.90*AVDD, e.g. 3V with AVDD=3.3V -: mic2-low-bias ( -- ) h# 08 h# 22 codec-set mic-bias-on ; \ 0.75*AVDD, e.g. 2.5V with AVDD=3.3V +: mic1-high-bias ( -- ) h# 80 h# 22 codec-clr ; \ 0.90*AVDD, e.g. 3V with AVDD=3.3V +: mic1-low-bias ( -- ) h# 80 h# 22 codec-set ; \ 0.75*AVDD, e.g. 2.5V with AVDD=3.3V +: mic2-high-bias ( -- ) h# 08 h# 22 codec-clr ; \ 0.90*AVDD, e.g. 3V with AVDD=3.3V +: mic2-low-bias ( -- ) h# 08 h# 22 codec-set ; \ 0.75*AVDD, e.g. 2.5V with AVDD=3.3V
: depop! ( value -- ) h# 54 codec! ; : pwr3a! ( value -- ) h# 3a codec! ; @@ -201,8 +201,9 @@ : adc-mono-right ( -- ) h# 8000 adc-source ; \ R->L+R : adc-stereo-reversed ( -- ) h# c000 adc-source ; \ L->R, R->L (channels swapped)
+true value mic-bias? : open-in-specific ( -- ) - h# 000c h# 3b codec-set \ Power on MIC1/2 bias + mic-bias? if mic-bias-on else mic-bias-off then \ Power on MIC1/2 bias adc-stereo h# 0c00 h# 3b codec-set \ Power on RECMIXLR h# 0030 h# 3b codec-set \ Power on MIC1/2 boost gain
Modified: cpu/arm/olpc/1.75/sound.fth ============================================================================== --- cpu/arm/olpc/1.75/sound.fth Sat Oct 22 05:39:56 2011 (r2629) +++ cpu/arm/olpc/1.75/sound.fth Sat Oct 22 05:40:03 2011 (r2630) @@ -400,6 +400,51 @@ : read ( adr len -- actual ) open-in audio-in close-in ;
0 value mono? +: stereo false to mono? ; +: mono true to mono? ; + +: average-channel ( adr -- n ) + 0 swap /audio-buf bounds do ( accum ) + i <w@ + ( accum' ) + /l +loop ( accum ) + /audio-buf /l / / ( average ) +; +: average-in ( -- ) + my-in-desc 2 la+ l@ ( adr ) + (cr push-decimal ( adr ) + dup average-channel ( adr average ) + 6 .r space ( adr ) + wa1+ average-channel ( average ) + 6 .r ( ) + pop-base ( ) + my-in-desc 3 la+ l@ to my-in-desc +; +: audio-watch ( -- ) + setup-sspa-rx ( ) + make-in-ring ( ) + start-in-ring ( ) + master-rx ( ) + begin ( ) + wait-in ( ) + average-in ( ) + key? until ( ) + disable-sspa-rx ( ) + stop-in-ring ( ) + reset-rx ( ) +; +: watch-dc ( bias? -- ) + to mic-bias? + d# 143 gpio-set \ DC input mode + h# 0400 h# 40 codec-clr + open-in + stereo 0 set-adc-gain 0 set-mic-gain + \ High bias gets us closer to the top of the digital range - but bias can + \ be turned off completely with "false to mic-bias?" + mic1-high-bias mic2-high-bias + audio-watch + close-in +; + 0 value in-adr0 0 value in-len0 : collapse-in ( -- ) @@ -504,9 +549,6 @@ set-adc-gain ;
-: stereo false to mono? ; -: mono true to mono? ; - : init-codec ( -- ) codec-on set-default-gains @@ -570,6 +612,15 @@
end-package
+: (watch-dc) ( bias? -- ) + " /audio" open-dev >r ( bias? r: ihandle ) + " watch-dc" r@ $call-method ( r: ihandle ) + r> close-dev ( ) +; +: watch-dc-biased ( -- ) true (watch-dc) ; +: watch-dc-unbiased ( -- ) false (watch-dc) ; + + \ LICENSE_BEGIN \ Copyright (c) 2011 FirmWorks \
