Author: quozl Date: Thu Sep 6 10:11:52 2012 New Revision: 3296 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3296
Log: OLPC XO-4 - Neonode, double randomness of adjacent axis test, fix boxes test; many boxes could not be cleared, flush events and ignore buffered up event; to avoid old data on scribble and adjacent axis test, fix bug in watch-fss; was occasionally aborting due to touch event data seen in stream, source formatting; tabs to spaces.
Modified: cpu/arm/olpc/nn-touchscreen.fth ============================================================================== --- cpu/arm/olpc/nn-touchscreen.fth Thu Sep 6 02:30:17 2012 (r3295) +++ cpu/arm/olpc/nn-touchscreen.fth Thu Sep 6 10:11:52 2012 (r3296) @@ -111,6 +111,10 @@
: deactivate ( -- ) h# 00 h# 01 h# ee 3 bytes-out h# 00 d# 20 anticipate +; + +: deconfigure ( -- ) + deactivate true to configure? ;
@@ -130,8 +134,8 @@ no-data? if reset no-data? if - ." no response to reset" cr - pbuf-free false exit + ." no response to reset" cr + pbuf-free false exit then then ['] read-boot-complete catch if @@ -146,10 +150,15 @@ ;
: close - deactivate + deconfigure pbuf-free ;
+: flush + deconfigure + configure +; + : stream-poll? ( -- false | x y buttons true ) in? if \ FIXME: only handles one subpacket @@ -213,135 +222,135 @@ \ a trailing ? means this combination is untested string-array x-os
- ," PD13 open?" \ 01 00 00 00 00 00 00 00 - ," PD14 open?" \ 02 00 00 00 00 00 00 00 - ," PD15 open?" \ 04 00 00 00 00 00 00 00 - ," PD16 open?" \ 08 00 00 00 00 00 00 00 - ," PD17 open?" \ 10 00 00 00 00 00 00 00 - ," PD18 open?" \ 20 00 00 00 00 00 00 00 - ," PD19 open?" \ 40 00 00 00 00 00 00 00 - ," PD20 open?" \ 80 00 00 00 00 00 00 00 - - ," PD21 open?" \ 00 01 00 00 00 00 00 00 - ," PD22 open?" \ 00 02 00 00 00 00 00 00 - ," PD23 open?" \ 00 04 00 00 00 00 00 00 - ," PD24 open?" \ 00 08 00 00 00 00 00 00 - ," PD25 open?" \ 00 10 00 00 00 00 00 00 - ," PD26 open?" \ 00 20 00 00 00 00 00 00 - ," PD27 open?" \ 00 40 00 00 00 00 00 00 - ," PD28 open?" \ 00 80 00 00 00 00 00 00 - - ," PD13 short" \ 00 00 01 00 00 00 00 00 - ," PD14 short" \ 00 00 02 00 00 00 00 00 - ," PD15 short" \ 00 00 04 00 00 00 00 00 - ," PD16 short" \ 00 00 08 00 00 00 00 00 - ," PD17 short" \ 00 00 10 00 00 00 00 00 - ," PD18 short" \ 00 00 20 00 00 00 00 00 - ," PD19 short" \ 00 00 40 00 00 00 00 00 - ," PD20 short" \ 00 00 80 00 00 00 00 00 - - ," PD21 short" \ 00 00 00 01 00 00 00 00 - ," PD22 short" \ 00 00 00 02 00 00 00 00 - ," PD23 short" \ 00 00 00 04 00 00 00 00 - ," PD24 short" \ 00 00 00 08 00 00 00 00 - ," PD25 short" \ 00 00 00 10 00 00 00 00 - ," PD26 short" \ 00 00 00 20 00 00 00 00 - ," PD27 short" \ 00 00 00 40 00 00 00 00 - ," PD28 short" \ 00 00 00 80 00 00 00 00 - - ," IR12 short" \ 00 00 00 00 01 00 00 00 - ," IR13 short" \ 00 00 00 00 02 00 00 00 - ," IR14 short" \ 00 00 00 00 04 00 00 00 - ," IR15 short" \ 00 00 00 00 08 00 00 00 - ," IR16 short" \ 00 00 00 00 10 00 00 00 - ," IR17 short" \ 00 00 00 00 20 00 00 00 - ," IR18 short" \ 00 00 00 00 40 00 00 00 - ," IR19 short" \ 00 00 00 00 80 00 00 00 - - ," IR20 short" \ 00 00 00 00 00 01 00 00 - ," IR21 short" \ 00 00 00 00 00 02 00 00 - ," IR22 short" \ 00 00 00 00 00 04 00 00 - ," IR23 short" \ 00 00 00 00 00 08 00 00 - ," IR24 short" \ 00 00 00 00 00 10 00 00 - ," IR25 short" \ 00 00 00 00 00 20 00 00 - ," IR26 short" \ 00 00 00 00 00 40 00 00 - ," reserved?" \ 00 00 00 00 00 80 00 00 - - ," IR12 open?" \ 00 00 00 00 00 00 01 00 - ," IR13 open?" \ 00 00 00 00 00 00 02 00 - ," IR14 open?" \ 00 00 00 00 00 00 04 00 - ," IR15 open?" \ 00 00 00 00 00 00 08 00 - ," IR16 open?" \ 00 00 00 00 00 00 10 00 - ," IR17 open?" \ 00 00 00 00 00 00 20 00 - ," IR18 open?" \ 00 00 00 00 00 00 40 00 - ," IR19 open?" \ 00 00 00 00 00 00 80 00 - - ," IR20 open?" \ 00 00 00 00 00 00 00 01 - ," IR21 open?" \ 00 00 00 00 00 00 00 02 - ," IR22 open?" \ 00 00 00 00 00 00 00 04 - ," IR23 open?" \ 00 00 00 00 00 00 00 08 - ," IR24 open?" \ 00 00 00 00 00 00 00 10 - ," IR25 open?" \ 00 00 00 00 00 00 00 20 - ," IR26 open?" \ 00 00 00 00 00 00 00 40 - ," reserved?" \ 00 00 00 00 00 00 00 80 + ," PD13 open?" \ 01 00 00 00 00 00 00 00 + ," PD14 open?" \ 02 00 00 00 00 00 00 00 + ," PD15 open?" \ 04 00 00 00 00 00 00 00 + ," PD16 open?" \ 08 00 00 00 00 00 00 00 + ," PD17 open?" \ 10 00 00 00 00 00 00 00 + ," PD18 open?" \ 20 00 00 00 00 00 00 00 + ," PD19 open?" \ 40 00 00 00 00 00 00 00 + ," PD20 open?" \ 80 00 00 00 00 00 00 00 + + ," PD21 open?" \ 00 01 00 00 00 00 00 00 + ," PD22 open?" \ 00 02 00 00 00 00 00 00 + ," PD23 open?" \ 00 04 00 00 00 00 00 00 + ," PD24 open?" \ 00 08 00 00 00 00 00 00 + ," PD25 open?" \ 00 10 00 00 00 00 00 00 + ," PD26 open?" \ 00 20 00 00 00 00 00 00 + ," PD27 open?" \ 00 40 00 00 00 00 00 00 + ," PD28 open?" \ 00 80 00 00 00 00 00 00 + + ," PD13 short" \ 00 00 01 00 00 00 00 00 + ," PD14 short" \ 00 00 02 00 00 00 00 00 + ," PD15 short" \ 00 00 04 00 00 00 00 00 + ," PD16 short" \ 00 00 08 00 00 00 00 00 + ," PD17 short" \ 00 00 10 00 00 00 00 00 + ," PD18 short" \ 00 00 20 00 00 00 00 00 + ," PD19 short" \ 00 00 40 00 00 00 00 00 + ," PD20 short" \ 00 00 80 00 00 00 00 00 + + ," PD21 short" \ 00 00 00 01 00 00 00 00 + ," PD22 short" \ 00 00 00 02 00 00 00 00 + ," PD23 short" \ 00 00 00 04 00 00 00 00 + ," PD24 short" \ 00 00 00 08 00 00 00 00 + ," PD25 short" \ 00 00 00 10 00 00 00 00 + ," PD26 short" \ 00 00 00 20 00 00 00 00 + ," PD27 short" \ 00 00 00 40 00 00 00 00 + ," PD28 short" \ 00 00 00 80 00 00 00 00 + + ," IR12 short" \ 00 00 00 00 01 00 00 00 + ," IR13 short" \ 00 00 00 00 02 00 00 00 + ," IR14 short" \ 00 00 00 00 04 00 00 00 + ," IR15 short" \ 00 00 00 00 08 00 00 00 + ," IR16 short" \ 00 00 00 00 10 00 00 00 + ," IR17 short" \ 00 00 00 00 20 00 00 00 + ," IR18 short" \ 00 00 00 00 40 00 00 00 + ," IR19 short" \ 00 00 00 00 80 00 00 00 + + ," IR20 short" \ 00 00 00 00 00 01 00 00 + ," IR21 short" \ 00 00 00 00 00 02 00 00 + ," IR22 short" \ 00 00 00 00 00 04 00 00 + ," IR23 short" \ 00 00 00 00 00 08 00 00 + ," IR24 short" \ 00 00 00 00 00 10 00 00 + ," IR25 short" \ 00 00 00 00 00 20 00 00 + ," IR26 short" \ 00 00 00 00 00 40 00 00 + ," reserved?" \ 00 00 00 00 00 80 00 00 + + ," IR12 open?" \ 00 00 00 00 00 00 01 00 + ," IR13 open?" \ 00 00 00 00 00 00 02 00 + ," IR14 open?" \ 00 00 00 00 00 00 04 00 + ," IR15 open?" \ 00 00 00 00 00 00 08 00 + ," IR16 open?" \ 00 00 00 00 00 00 10 00 + ," IR17 open?" \ 00 00 00 00 00 00 20 00 + ," IR18 open?" \ 00 00 00 00 00 00 40 00 + ," IR19 open?" \ 00 00 00 00 00 00 80 00 + + ," IR20 open?" \ 00 00 00 00 00 00 00 01 + ," IR21 open?" \ 00 00 00 00 00 00 00 02 + ," IR22 open?" \ 00 00 00 00 00 00 00 04 + ," IR23 open?" \ 00 00 00 00 00 00 00 08 + ," IR24 open?" \ 00 00 00 00 00 00 00 10 + ," IR25 open?" \ 00 00 00 00 00 00 00 20 + ," IR26 open?" \ 00 00 00 00 00 00 00 40 + ," reserved?" \ 00 00 00 00 00 00 00 80
end-string-array
string-array y-os
- ," PD4 open?" \ 01 00 00 00 00 00 - ," PD3 open?" \ 02 00 00 00 00 00 - ," PD2 open?" \ 04 00 00 00 00 00 - ," PD1 open?" \ 08 00 00 00 00 00 - ," PD12 open?" \ 10 00 00 00 00 00 - ," PD11 open?" \ 20 00 00 00 00 00 - ," PD10 open?" \ 40 00 00 00 00 00 - ," PD9 open?" \ 80 00 00 00 00 00 - - ," PD8 open?" \ 00 01 00 00 00 00 - ," PD7 open?" \ 00 02 00 00 00 00 - ," PD6 open?" \ 00 04 00 00 00 00 - ," PD5 open?" \ 00 08 00 00 00 00 - ," PD12 short" \ 00 10 00 00 00 00 - ," PD11 short" \ 00 20 00 00 00 00 - ," PD10 short" \ 00 40 00 00 00 00 - ," PD9 short" \ 00 80 00 00 00 00 - - ," PD8 short" \ 00 00 01 00 00 00 - ," PD7 short" \ 00 00 02 00 00 00 - ," PD6 short" \ 00 00 04 00 00 00 - ," PD5 short" \ 00 00 08 00 00 00 - ," PD4 short" \ 00 00 10 00 00 00 - ," PD3 short" \ 00 00 20 00 00 00 - ," PD2 short" \ 00 00 40 00 00 00 - ," PD1 short" \ 00 00 80 00 00 00 - - ," IR11 short" \ 00 00 00 01 00 00 - ," IR10 short" \ 00 00 00 02 00 00 - ," IR9 short" \ 00 00 00 04 00 00 - ," IR8 short" \ 00 00 00 08 00 00 - ," IR7 short" \ 00 00 00 10 00 00 - ," IR6 short" \ 00 00 00 20 00 00 - ," IR5 short" \ 00 00 00 40 00 00 - ," IR4 short" \ 00 00 00 80 00 00 - - ," IR3 short" \ 00 00 00 00 01 00 - ," IR2 short" \ 00 00 00 00 02 00 - ," IR1 short" \ 00 00 00 00 04 00 - ," reserved?" \ 00 00 00 00 08 00 - ," reserved?" \ 00 00 00 00 10 00 - ," IR11 open?" \ 00 00 00 00 20 00 - ," IR10 open?" \ 00 00 00 00 40 00 - ," IR9 open?" \ 00 00 00 00 80 00 - - ," IR8 open?" \ 00 00 00 00 00 01 - ," IR7 open?" \ 00 00 00 00 00 02 - ," IR6 open?" \ 00 00 00 00 00 04 - ," IR5 open?" \ 00 00 00 00 00 08 - ," IR4 open?" \ 00 00 00 00 00 10 - ," IR3 open?" \ 00 00 00 00 00 20 - ," IR2 open?" \ 00 00 00 00 00 40 - ," IR1 open?" \ 00 00 00 00 00 80 + ," PD4 open?" \ 01 00 00 00 00 00 + ," PD3 open?" \ 02 00 00 00 00 00 + ," PD2 open?" \ 04 00 00 00 00 00 + ," PD1 open?" \ 08 00 00 00 00 00 + ," PD12 open?" \ 10 00 00 00 00 00 + ," PD11 open?" \ 20 00 00 00 00 00 + ," PD10 open?" \ 40 00 00 00 00 00 + ," PD9 open?" \ 80 00 00 00 00 00 + + ," PD8 open?" \ 00 01 00 00 00 00 + ," PD7 open?" \ 00 02 00 00 00 00 + ," PD6 open?" \ 00 04 00 00 00 00 + ," PD5 open?" \ 00 08 00 00 00 00 + ," PD12 short" \ 00 10 00 00 00 00 + ," PD11 short" \ 00 20 00 00 00 00 + ," PD10 short" \ 00 40 00 00 00 00 + ," PD9 short" \ 00 80 00 00 00 00 + + ," PD8 short" \ 00 00 01 00 00 00 + ," PD7 short" \ 00 00 02 00 00 00 + ," PD6 short" \ 00 00 04 00 00 00 + ," PD5 short" \ 00 00 08 00 00 00 + ," PD4 short" \ 00 00 10 00 00 00 + ," PD3 short" \ 00 00 20 00 00 00 + ," PD2 short" \ 00 00 40 00 00 00 + ," PD1 short" \ 00 00 80 00 00 00 + + ," IR11 short" \ 00 00 00 01 00 00 + ," IR10 short" \ 00 00 00 02 00 00 + ," IR9 short" \ 00 00 00 04 00 00 + ," IR8 short" \ 00 00 00 08 00 00 + ," IR7 short" \ 00 00 00 10 00 00 + ," IR6 short" \ 00 00 00 20 00 00 + ," IR5 short" \ 00 00 00 40 00 00 + ," IR4 short" \ 00 00 00 80 00 00 + + ," IR3 short" \ 00 00 00 00 01 00 + ," IR2 short" \ 00 00 00 00 02 00 + ," IR1 short" \ 00 00 00 00 04 00 + ," reserved?" \ 00 00 00 00 08 00 + ," reserved?" \ 00 00 00 00 10 00 + ," IR11 open?" \ 00 00 00 00 20 00 + ," IR10 open?" \ 00 00 00 00 40 00 + ," IR9 open?" \ 00 00 00 00 80 00 + + ," IR8 open?" \ 00 00 00 00 00 01 + ," IR7 open?" \ 00 00 00 00 00 02 + ," IR6 open?" \ 00 00 00 00 00 04 + ," IR5 open?" \ 00 00 00 00 00 08 + ," IR4 open?" \ 00 00 00 00 00 10 + ," IR3 open?" \ 00 00 00 00 00 20 + ," IR2 open?" \ 00 00 00 00 00 40 + ," IR1 open?" \ 00 00 00 00 00 80
end-string-array
@@ -362,30 +371,30 @@ pbuf 3 + c@ if pbuf 4 + c@ h# 16 <> abort" bad signals y" [ifdef] nn-components - ['] y-os to our-os + ['] y-os to our-os [then] /y-os ( addr bits# ) else pbuf 4 + c@ h# 1e <> abort" bad signals x" [ifdef] nn-components - ['] x-os to our-os + ['] x-os to our-os [then] /x-os ( addr bits# ) then
- 0 do ( addr ) - dup c@ ( addr byte ) - i 8 mod ( addr byte bit# ) - rshift 1 and if ( addr ) - 8sp - [ifdef] nn-components - i our-os count type - [then] - ." ( bit " i .d ." )" cr - fault - then ( addr ) - i 8 mod 7 = if 1+ then ( addr' ) - loop drop ( ) + 0 do ( addr ) + dup c@ ( addr byte ) + i 8 mod ( addr byte bit# ) + rshift 1 and if ( addr ) + 8sp + [ifdef] nn-components + i our-os count type + [then] + ." ( bit " i .d ." )" cr + fault + then ( addr ) + i 8 mod 7 = if 1+ then ( addr' ) + loop drop ( ) cr ;
@@ -454,8 +463,8 @@ dup c@ ( addr byte ) i 8 mod ( addr byte bit# ) rshift 1 and if ( addr ) - i .d - fault + i .d + fault then i 8 mod ( addr rem ) 7 = if 1+ then ( addr' ) @@ -476,6 +485,7 @@
[ifdef] nn-fll \ forced LED levels test : test-fll-signal ( signal# signal-value led-level -- ) +[ifdef] nn-too-strong-is-fatal dup 0= if fault rot ." fail on axis signal " .d @@ -484,6 +494,7 @@ cr exit then +[then] dup h# c > if fault rot ." fail on axis signal " .d @@ -626,7 +637,7 @@ : watch-fss-axis ( axis# -- ) dup to axis# ( axis# ) fs swap h# 0f h# 03 h# ee 5 bytes-out - h# 0f d# 20 anticipate + h# 0f d# 200 anticipate
pbuf 4 + c@ 0 do ( ) i pbuf 5 + over + c@ ( signal# level ) @@ -684,8 +695,13 @@ pbuf 4 + i 9 * + >r ( r:addr ) r@ w@ x>x' ( x r:addr ) r@ wa1+ w@ ( x y r:addr ) - r> 4 + c@ 2 rshift setcolor ( x y ) - (ev) ( ) + r> 4 + c@ ( x y id-state ) + dup 2 rshift setcolor ( x y id-state ) + 3 and 2 <> if ( x y ) + (ev) ( ) \ not an up event + else + 2drop ( ) \ an up event + then loop then then ( to ) @@ -700,7 +716,7 @@ configure cursor-off consume - begin in? 0= until + flush background -1 to remaining ; @@ -724,7 +740,7 @@ create boxen /boxen allot \ non-zero means box is expected to be hit
: 0boxen ( -- ) boxen /boxen erase ; -: >boxen ( bx by -- addr ) yleds * + +: >boxen ( bx by -- addr ) xleds * + dup /boxen > if debug-me then boxen + ;
@@ -744,9 +760,9 @@ ;
: box ( bx by colour -- ) - -rot ( colour bx by ) - bxby>xy ( colour x y ) - dx dy ( colour x y w h ) + -rot ( colour bx by ) + bxby>xy ( colour x y ) + dx dy ( colour x y w h ) fill-rectangle-noff ;
@@ -769,7 +785,7 @@ : unhit-all ( -- ) xleds 0 do yleds 0 do - j i unhit + j i unhit loop loop ; @@ -813,12 +829,16 @@ : ra ['] .ra to .tsmsg ev( ra0 ['] (ra) ev )ev r-fault? ;
: test-adjacent-axes - get-msecs 3 and \ pick random corner + get-msecs 7 and \ pick random corner case 0 of ta ra exit endof 1 of ra ba exit endof 2 of ba la exit endof 3 of la ta exit endof + 4 of ra ta exit endof + 5 of ba ra exit endof + 6 of la ba exit endof + 7 of ta la exit endof endcase ;
