Author: wmb Date: 2009-11-25 21:45:24 +0100 (Wed, 25 Nov 2009) New Revision: 1503
Added: forth/wrapper/xcbifce.c Modified: cpu/x86/Linux/Makefile Log: Fixed the "libxcb" compilation options section of the x86 Linus wrapper Makefile.
Modified: cpu/x86/Linux/Makefile =================================================================== --- cpu/x86/Linux/Makefile 2009-11-25 20:31:53 UTC (rev 1502) +++ cpu/x86/Linux/Makefile 2009-11-25 20:45:24 UTC (rev 1503) @@ -3,9 +3,14 @@ BP=../../..
CFLAGS = -O -g -m32 -DTARGET_X86 -CFLAGS += -DUSE_XCB -LIBS += -lxcb
+# Uncomment these lines to include X windows support to the wrapper +# via libxcb. The libxcb development package (headers, etc) must be +# present on your compilation machine for this to work. +# CFLAGS += -DUSE_XCB +# LIBS += -lxcb +# OBJS += xcbifce.o + WRTAIL = forth/wrapper WRDIR = ${BP}/${WRTAIL} ZIPTAIL = ${WRTAIL}/zip @@ -13,7 +18,7 @@
ZIPOBJS = zipmem.o deflate.o trees.o bits.o util.o inflate.o
-OBJS = wrapper.o logger.o ${ZIPOBJS} xcbifce.o +OBJS += wrapper.o logger.o ${ZIPOBJS}
all: forth x86forth ../build/inflate.bin
Added: forth/wrapper/xcbifce.c =================================================================== --- forth/wrapper/xcbifce.c (rev 0) +++ forth/wrapper/xcbifce.c 2009-11-25 20:45:24 UTC (rev 1503) @@ -0,0 +1,166 @@ +// See license at end of file + +/* Simple XCB application drawing a box in a window */ + +#include <xcb/xcb.h> +#include <stdlib.h> + +xcb_connection_t *c; +xcb_screen_t *s; +xcb_window_t w; +xcb_gcontext_t g; +xcb_colormap_t colormap; + +uint32_t rgbcolor(uint16_t b, uint16_t g, uint16_t r) +{ + xcb_alloc_color_reply_t *rep; + + rep = xcb_alloc_color_reply (c, xcb_alloc_color (c, colormap, r<<8, g<<8, b<<8), NULL); + + return rep->pixel; +} + +uint32_t color565(uint32_t color) +{ + uint16_t r, g, b; + xcb_alloc_color_reply_t *rep; + +#if 0 + r = (color>>11) << 11; + g = ((color>>5) & 0x3f) << 10; + b = (color & 0x1f) << 11; + + rep = xcb_alloc_color_reply (c, xcb_alloc_color (c, colormap, r, g, b), NULL); + + return rep->pixel; +#else + r = (color>>11) << 3; + g = ((color>>5) & 0x3f) << 2; + b = (color & 0x1f) << 3; + + return (r<<16) | (g<<8) | b; +#endif +} + +void fill_rectangle(uint32_t height, uint32_t width, uint32_t y, uint32_t x, uint32_t color) +{ + uint32_t value[1]; + xcb_rectangle_t r; + + value[0] = color; + xcb_change_gc (c, g, XCB_GC_FOREGROUND, value); + + r.x = x; r.y = y; r.width = width; r.height = height; + + xcb_poly_fill_rectangle(c, w, g, 1, &r); + xcb_flush(c); +} + +int open_window(uint32_t height, uint32_t width) { + uint32_t mask; + uint32_t values[2]; + + /* open connection with the server */ + c = xcb_connect(NULL,NULL); + if (xcb_connection_has_error(c)) { + return -1; + } + + /* get the first screen */ + s = xcb_setup_roots_iterator( xcb_get_setup(c) ).data; + + colormap = s->default_colormap; + + /* create black graphics context */ + g = xcb_generate_id(c); + w = s->root; + mask = XCB_GC_FOREGROUND | XCB_GC_GRAPHICS_EXPOSURES; + values[0] = s->black_pixel; + values[1] = 0; + xcb_create_gc(c, g, w, mask, values); + + /* create window */ + w = xcb_generate_id(c); +/* + mask = XCB_CW_BACK_PIXEL | XCB_CW_EVENT_MASK; + values[0] = s->white_pixel; + values[1] = XCB_EVENT_MASK_EXPOSURE | XCB_EVENT_MASK_KEY_PRESS; +*/ + mask = XCB_CW_BACK_PIXEL; + values[0] = s->white_pixel; + xcb_create_window(c, s->root_depth, w, s->root, + 0, 0, width, height, 1, + XCB_WINDOW_CLASS_INPUT_OUTPUT, s->root_visual, + mask, values); + + /* map (show) the window */ + xcb_map_window(c, w); + xcb_flush(c); + return 0; +} + +long close_window() +{ + xcb_disconnect(c); + return 0; +} + +#if 0 + +int main() +{ +#if 0 + xcb_generic_event_t *e; + + int done = 0; +#endif + + (void)open_window(900, 1200); + + fill_rectangle(60, 60, 20, 20, rgbcolor(0xff, 0, 0xff)); +#if 0 + /* event loop */ + while (!done && (e = xcb_wait_for_event(c))) { + switch (e->response_type & ~0x80) { + case XCB_EXPOSE: /* draw or redraw the window */ + fill_rectangle(60, 60, 20, 20, rgbcolor(0xff, 0, 0xff)); + break; + case XCB_KEY_PRESS: /* exit on key press */ + done = 1; + break; + } + free(e); + } +#endif + + sleep(10); + /* close connection to server */ + close_window(); + + return 0; +} +#endif + +// LICENSE_BEGIN +// Copyright (c) 2009 FirmWorks +// +// Permission is hereby granted, free of charge, to any person obtaining +// a copy of this software and associated documentation files (the +// "Software"), to deal in the Software without restriction, including +// without limitation the rights to use, copy, modify, merge, publish, +// distribute, sublicense, and/or sell copies of the Software, and to +// permit persons to whom the Software is furnished to do so, subject to +// the following conditions: +// +// The above copyright notice and this permission notice shall be +// included in all copies or substantial portions of the Software. +// +// THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, +// EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF +// MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND +// NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE +// LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION +// OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION +// WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. +// +// LICENSE_END
