Author: wmb Date: Fri Aug 3 10:48:38 2012 New Revision: 3127 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3127
Log: Q7A01' - removed startup bailouts, now that things are mostly working.
Modified: cpu/arm/olpc/banner.fth cpu/arm/olpc/build-fw.fth
Modified: cpu/arm/olpc/banner.fth ============================================================================== --- cpu/arm/olpc/banner.fth Fri Aug 3 10:32:02 2012 (r3126) +++ cpu/arm/olpc/banner.fth Fri Aug 3 10:48:38 2012 (r3127) @@ -65,9 +65,6 @@ ;
: .storage ( -- ) -[ifdef] olpc-cl4 -." olpc/banner.fth: Skipping .storage" cr exit -[then] internal-disk-present? 0= if ( ) get-internal-disk-info ( ) then
Modified: cpu/arm/olpc/build-fw.fth ============================================================================== --- cpu/arm/olpc/build-fw.fth Fri Aug 3 10:32:02 2012 (r3126) +++ cpu/arm/olpc/build-fw.fth Fri Aug 3 10:48:38 2012 (r3127) @@ -871,9 +871,6 @@ auto-banner? if banner then
+ use-screen-kbd ?text-on -[ifdef] olpc-cl4 - ." Quitting before auto-boot" cr visible banner quit -[then] auto-boot + use-screen-kbd close-hotspot
