Author: quozl Date: Mon Dec 31 11:43:11 2012 New Revision: 3504 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3504
Log: OLPC XO-4 - touchscreen, change to version 0.0.0.9, which caused a few more timing changes, requiring some fixes to the driver.
Modified: cpu/arm/olpc/4.0/nn-version.fth cpu/arm/olpc/nn-touchscreen.fth
Modified: cpu/arm/olpc/4.0/nn-version.fth ============================================================================== --- cpu/arm/olpc/4.0/nn-version.fth Mon Dec 31 07:36:36 2012 (r3503) +++ cpu/arm/olpc/4.0/nn-version.fth Mon Dec 31 11:43:11 2012 (r3504) @@ -1,2 +1,2 @@ \ The Neonode touchscreen firmware -macro: NN_VERSION 0_0_0_8 +macro: NN_VERSION 0_0_0_9
Modified: cpu/arm/olpc/nn-touchscreen.fth ============================================================================== --- cpu/arm/olpc/nn-touchscreen.fth Mon Dec 31 07:36:36 2012 (r3503) +++ cpu/arm/olpc/nn-touchscreen.fth Mon Dec 31 11:43:11 2012 (r3504) @@ -111,7 +111,21 @@ then ( id limit ) dup get-msecs - 0< ( id limit timeout? ) until ( id limit ) - 2drop ( ) + drop ( id ) + ." timeout waiting for " 2u.x cr ( ) + r> rstrace >r + pbuf /pbuf erase +; + +: ?id-abort ( id $message -- ) + rot pbuf 2+ c@ <> if + pbuf plen cdump + r> rstrace >r + cr + $abort + else + 2drop + then ;
: ?missing @@ -120,22 +134,24 @@
: flush-input ( -- ) begin - 0 0 anticipate - pbuf 2+ c@ h# 07 = if ?missing then + in? if + pbuf 2+ c@ h# 07 = if ?missing then + then no-data? until ;
: read-boot-complete ( -- ) - 0 pbuf 2+ c! - h# 07 d# 0 anticipate - pbuf 2+ c@ h# 07 <> abort" response other than boot complete" - ?missing + in? if + h# 07 " response other than boot complete" ?id-abort + ?missing + then ;
+ : read-version h# 1e h# 01 h# ee 3 bytes-out h# 1e d# 100 anticipate - pbuf 2+ c@ h# 1e <> abort" response other than status" + h# 1e " response other than status" ?id-abort pbuf 9 + le-w@ pbuf 7 + le-w@ wljoin pbuf 5 + le-w@ pbuf 3 + le-w@ wljoin to version# ; @@ -151,12 +167,14 @@ : start ( -- ) h# 04 h# 01 h# ee 3 bytes-out ;
: deactivate ( -- ) - h# 00 h# 01 h# ee 3 bytes-out h# 00 d# 60 anticipate + h# 00 h# 01 h# ee 3 bytes-out h# 00 d# 100 anticipate ;
: deconfigure ( -- ) - deactivate - true to configure? + configure? 0= if + deactivate + true to configure? + then ;
: configure ( -- ) @@ -216,7 +234,6 @@ ;
: stream-poll? ( -- false | x y buttons true ) - 0 pbuf 2+ c! in? if \ FIXME: only handles one subpacket pbuf 2+ c@ h# 04 = if @@ -245,7 +262,6 @@ : test-response ( -- ) 6 0 do h# 40 h# 0 h# 0f 3 h# ee 5 bytes-out \ fss full level - 0 pbuf 2+ c! h# 0f d# 130 anticipate pbuf 2+ c@ dup 0= abort" missing response after fixed signal strength" h# 0f <> abort" response other than fixed signal strength" @@ -405,8 +421,8 @@
: test-os-axis ( axis -- ) h# 21 h# 02 h# ee 4 bytes-out - h# 21 d# 60 anticipate - pbuf 2+ c@ h# 21 <> abort" response other than open short" + h# 21 d# 100 anticipate + h# 21 " response other than open short" ?id-abort
pbuf d# 5 + ( addr )
@@ -466,7 +482,7 @@ : test-fss-axis ( axis -- ) d# 64 swap h# 0f h# 03 h# ee 5 bytes-out h# 0f d# 60 anticipate - pbuf 2+ c@ h# 0f <> abort" response other than fixed signal strength" + h# 0f " response other than fixed signal strength" ?id-abort 8sp push-decimal pbuf 4 + c@ 0 do ( ) @@ -601,7 +617,7 @@ : test-ls-axis ( axis -- ) h# 0d h# 02 h# ee 4 bytes-out h# 0d d# 200 anticipate - pbuf 2+ c@ h# 0d <> abort" response other than low signals" + h# 0d " response other than low signals" ?id-abort
8sp pbuf 5 + ( addr ) @@ -1010,15 +1026,25 @@ ;
+: (lg-tooling) test-os test-fll ; + : lg-tooling ( -- error? ) - open if test-os test-fll else fault then + open if + ['] (lg-tooling) catch ?dup if .error fault then + else + fault + then faults close ;
: ir-pcb-smt ( -- error? ) hold-reset connect - open if test-os else fault then + open if + ['] test-os catch ?dup if .error fault then + else + fault + then close hold-reset disconnect faults @@ -1027,8 +1053,10 @@ : ir-pcb-assy ( -- error? ) hold-reset connect open if - test-fll - faults 0= if test-adjacent-axes then + ['] test-fll catch ?dup if .error fault then + faults 0= if + ['] test-adjacent-axes catch ?dup if .error fault then + then else fault then @@ -1039,14 +1067,14 @@
: mb-smt ( -- error? ) open 0= if true exit then - show-version + ['] show-version catch ?dup if .error fault then close - false + faults ;
: mb-assy ( -- error? ) open 0= if true exit then - test-adjacent-axes + ['] test-adjacent-axes catch ?dup if .error fault then close faults ;
