Author: quozl Date: Fri Aug 10 07:23:01 2012 New Revision: 3150 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3150
Log: OLPC CL4 - Neonode, set GPIO directions, add missing early exit
Modified: cpu/arm/olpc/nn-touchscreen.fth ============================================================================== --- cpu/arm/olpc/nn-touchscreen.fth Fri Aug 10 07:20:13 2012 (r3149) +++ cpu/arm/olpc/nn-touchscreen.fth Fri Aug 10 07:23:01 2012 (r3150) @@ -10,15 +10,19 @@
fload ${BP}/cpu/arm/olpc/touchscreen-common.fth
+: set-gpios + touch-rst-gpio# dup gpio-set gpio-dir-out + touch-tck-gpio# dup gpio-clr gpio-dir-out +; : reset ( -- ) touch-rst-gpio# dup gpio-clr gpio-set d# 250 ms ; -: no-data? ( -- false | true ) touch-scr-gpio# gpio-pin@ ; +: no-data? ( -- no-data? ) touch-scr-gpio# gpio-pin@ ;
d# 250 constant /packet /packet buffer: packet 0 value packet-size
-: in? ( -- false | true ) - no-data? if false then +: in? ( -- got-data? ) + no-data? if false exit then
packet 2 " twsi-read" $call-parent ( ) packet 1+ c@ ( size ) @@ -69,6 +73,7 @@
: open ( -- okay? ) my-unit " set-address" $call-parent + set-gpios no-data? if reset then no-data? if false exit then ['] configure catch if false exit then
