Author: quozl Date: Fri Dec 3 08:10:10 2010 New Revision: 2065 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2065
Log: OLPC XO-1.5 - increase external SD card power-up off time for a 32 G class 10 SD card being tested.
Modified: dev/mmc/sdhci/sdhci.fth
Modified: dev/mmc/sdhci/sdhci.fth ============================================================================== --- dev/mmc/sdhci/sdhci.fth Fri Dec 3 07:55:12 2010 (r2064) +++ dev/mmc/sdhci/sdhci.fth Fri Dec 3 08:10:10 2010 (r2065) @@ -801,10 +801,16 @@ false to writing? ;
+\ time to hold card power off to allow VCC_SD to discharge +\ 25ms required for XO-1.5 with external SanDisk 32 G class 10 SD card +\ 29ms required for XO-1.5 with external SanDisk 8 G class 4 SD card +\ 1ms should be required for XO-1.75 A2 (due to discharge clamps) +d# 40 value power-off-time + \ -1 means error, 1 means retry : power-up-card ( -- false | retry? true ) intstat-on - card-power-off d# 20 ms + card-power-off power-off-time ms card-power-on d# 40 ms \ This delay is just a guess (20 was barely too slow for a Via board) card-inserted? 0= if card-power-off intstat-off false true exit then card-clock-slow d# 10 ms \ This delay is just a guess
