Author: wmb Date: Wed Aug 1 06:34:49 2012 New Revision: 3106 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3106
Log: Marvell TIM compiler - accept either 4 ASCII or 3 ASCII plus decimal for ID values.
Modified: cpu/arm/marvell/tim.fth
Modified: cpu/arm/marvell/tim.fth ============================================================================== --- cpu/arm/marvell/tim.fth Wed Aug 1 00:41:17 2012 (r3105) +++ cpu/arm/marvell/tim.fth Wed Aug 1 06:34:49 2012 (r3106) @@ -78,11 +78,18 @@ image-adr image-size free-mem ; : id, ( -- ) - get-word ( adr len ) - \ Convert trailing number to binary byte value - e.g. NAN'6 -> NAN(06) - 2dup [char] ' left-parse-string 2drop ( adr len tail$ ) - push-decimal $number pop-base abort" Bad number" ( adr len n ) - nip over 3 + c! 4 ( adr 4 ) + get-word ( adr len ) + \ The ID can either be a 4 bytes of ASCII, e.g. OLPC, + \ or 3 ASCII plus a decimal number, e.g. SPI'10 + 2dup [char] ' left-parse-string ( adr len tail$ head$ ) + nip 4 = if ( adr len tail$ ) + \ No ' character in string; use verbatim + 2drop + else ( adr len tail$ ) + \ Convert trailing number to binary byte value - e.g. NAN'6 -> NAN(06) + push-decimal $number pop-base abort" Bad number" ( adr len n ) + nip over 3 + c! 4 ( adr 4 ) + then 4c, ; : tim: \ version trusted ID Processor
