Author: wmb Date: 2008-10-05 22:00:00 +0200 (Sun, 05 Oct 2008) New Revision: 981
Modified: dev/olpc/touchpad/touchpad.fth Log: OLPC trac 8451 - Handle "test /mouse" issues raised by comment 9 of that ticket. Mostly cosmetic, but also slightly more robust handling of protocol botches.
Modified: dev/olpc/touchpad/touchpad.fth =================================================================== --- dev/olpc/touchpad/touchpad.fth 2008-10-05 09:37:37 UTC (rev 980) +++ dev/olpc/touchpad/touchpad.fth 2008-10-05 20:00:00 UTC (rev 981) @@ -271,8 +271,8 @@ endof ( default ) \ If the high bit is set it means it's the first byte - \ of a packet. Abort if we don't recognize the type. - dup h# 80 and abort" Touchpad protocol botch" + \ of a packet. Complain if we don't recognize the type. + dup h# 80 and if ." Protocol botch" then
\ If the high bit is not set, we have missed a start of packet miss? @ 0= if ." miss " then @@ -417,6 +417,9 @@
cursor-off track-init start
+ \ Consume already-queued keys to prevent premature exit + begin key? while key drop repeat + background gs-only begin @@ -441,6 +444,7 @@ until
close + page 0 ;
