Author: wmb Date: 2009-07-29 03:10:30 +0200 (Wed, 29 Jul 2009) New Revision: 1258
Modified: cpu/x86/pc/olpc/via/probemem.fth Log: OLPC trac #9401 - Via - Fixed test-all crash by removing redundant mmu-map from memory node selftest method in probemem.fth
Modified: cpu/x86/pc/olpc/via/probemem.fth =================================================================== --- cpu/x86/pc/olpc/via/probemem.fth 2009-07-29 01:08:57 UTC (rev 1257) +++ cpu/x86/pc/olpc/via/probemem.fth 2009-07-29 01:10:30 UTC (rev 1258) @@ -93,9 +93,7 @@ begin ?dup while 2 decode-ints swap ( rem$ chunk$ ) 2dup .chunk ( rem$ chunk$ ) -[ifdef] virtual-mode - 2dup over swap 3 mmu-map ( rem$ chunk$ ) -[then] + \ We maintain a 1-1 convenience mapping so explicit mapping is unnecessary memory-test-suite if 2drop true exit then ( rem$ ) repeat drop false
