Author: wmb Date: 2009-07-31 20:46:49 +0200 (Fri, 31 Jul 2009) New Revision: 1264
Added: cpu/x86/pc/olpc/via/copynand.fth Modified: cpu/x86/pc/olpc/via/devices.fth cpu/x86/pc/olpc/via/fw.bth cpu/x86/pc/olpc/via/olpc.bth Log: Via - added "fs-update" command for OS installation.
Added: cpu/x86/pc/olpc/via/copynand.fth =================================================================== --- cpu/x86/pc/olpc/via/copynand.fth (rev 0) +++ cpu/x86/pc/olpc/via/copynand.fth 2009-07-31 18:46:49 UTC (rev 1264) @@ -0,0 +1,567 @@ +\ See license at end of file +purpose: Copy a file onto the NAND FLASH + +0 value fileih +0 value nandih + +h# 20000 value /nand-block +h# 200 value /nand-page +/nand-block /nand-page / value nand-pages/block +0 value #nand-pages + +0 value #image-eblocks + +: $call-nand ( ?? method$ -- ?? ) nandih $call-method ; + +: close-image-file ( -- ) + fileih ?dup if 0 to fileih close-dev then +; +: close-nand ( -- ) + nandih ?dup if 0 to nandih close-dev then +; +: close-nand-ihs ( -- ) + close-image-file + close-nand +; + +: ?nand-abort ( flag msg$ -- ) + rot if + close-nand-ihs $abort + else + 2drop + then +; + +: ?key-stop ( -- ) + key? dup if key drop then ( stop? ) + " Stopped by keystroke" ?nand-abort +; + +: set-nand-vars ( -- ) + " size" $call-nand /nand-page um/mod nip to #nand-pages +; +: open-nand ( -- ) + " fsdisk" open-dev to nandih + nandih 0= " Can't open disk device" ?nand-abort + set-nand-vars +; + +h# 100 buffer: image-name-buf +: image-name$ ( -- adr len ) image-name-buf count ; + +: get-img-filename ( -- ) safe-parse-word image-name-buf place ; + +: open-img ( "devspec" -- ) + image-name$ open-dev to fileih + fileih 0= " Can't open NAND image file" ?nand-abort + " size" fileih $call-method ( d.size ) + + 2dup h# 20000 um/mod swap if 1+ then ( d.size #eblocks ) + nip nip ( #eblocks ) + + to #image-eblocks + + #image-eblocks 0= " Image file is empty" ?nand-abort +; + +: read-image-block ( -- ) + load-base /nand-block " read" fileih $call-method ( len ) + dup /nand-block <> if ( len ) + load-base over + /nand-page rot - h# ff fill + else + drop + then +; + +: check-mem-hash ( record# -- ) + drop \ XXX +; + + +defer show-init ( #eblocks -- ) +' drop to show-init + +defer show-erasing ( #blocks -- ) +: (show-erasing) ( #blocks -- ) ." Erasing " . ." blocks" cr ; +' (show-erasing) to show-erasing + +defer show-erased ( block# -- ) +: (show-erased) ( block# -- ) (cr . ; +' (show-erased) to show-erased + +defer show-bad ( block# -- ) +' drop to show-bad + +defer show-bbt-block ( block# -- ) +' drop to show-bbt-block + +defer show-clean ( block# -- ) +' drop to show-clean + +defer show-cleaning ( -- ) +: (show-cleaning) ( -- ) cr ." Cleanmarkers" ; +' (show-cleaning) to show-cleaning + +defer show-writing ( #blocks -- ) +: (show-writing) ." Writing " . ." blocks" cr ; +' (show-writing) to show-writing + +defer show-pending ( block# -- ) +' drop to show-pending + +defer show-written +: (show-written) ( block# -- ) (cr . ; +' (show-written) to show-written + +defer show-strange +' drop to show-strange + +defer show-done +' cr to show-done + +: written? ( adr len -- flag ) h# ffffffff lskip 0<> ; + +h# 80 h# 80 h# 80 rgb>565 constant bbt-color \ gray + 0 0 0 rgb>565 constant erased-color \ black +h# ff 0 0 rgb>565 constant bad-color \ red + 0 0 h# ff rgb>565 constant clean-color \ blue +h# ff 0 h# ff rgb>565 constant partial-color \ magenta +h# ff h# ff 0 rgb>565 constant pending-color \ yellow + 0 h# ff 0 rgb>565 constant written-color \ green + 0 h# ff h# ff rgb>565 constant strange-color \ cyan +h# ff h# ff h# ff rgb>565 constant starting-color \ white + +d# 22 constant status-line + +: gshow-init ( #eblocks -- ) + cursor-off " erase-screen" $call-screen + + starting-color ( #eblocks color ) + swap 0 ?do i over show-state loop + drop + 0 status-line at-xy +; + +: gshow-erasing ( #eblocks -- ) drop ." Erasing " ; + +: gshow-erased ( eblock# -- ) erased-color show-state ; +: gshow-bad ( eblock# -- ) bad-color show-state ; +: gshow-bbt-block ( eblock# -- ) bbt-color show-state ; +: gshow-clean ( eblock# -- ) clean-color show-state ; +: gshow-strange ( eblock# -- ) strange-color show-state ; + +: gshow-cleaning ( -- ) d# 26 status-line at-xy ." Cleanmarkers" cr ; +: gshow-done ( -- ) cursor-on ; + +: gshow-pending ( eblock# -- ) pending-color show-state ; + +: gshow-writing ( #eblocks -- ) + ." Writing " + 0 swap 0 ?do ( eblock# ) + dup show-pending ( eblock# ) + 1 ( eblock# increment ) + swap 1+ swap ( eblock#' increment ) + +loop ( eblock#' ) + drop +; + +: show-eblock# ( eblock# -- ) d# 20 status-line at-xy .x ; +: gshow-written ( eblock# -- ) + dup written-color show-state + show-eblock# +; + +: gshow + ['] gshow-init to show-init + ['] gshow-erasing to show-erasing + ['] gshow-erased to show-erased + ['] gshow-bad to show-bad + ['] gshow-bbt-block to show-bbt-block + ['] gshow-clean to show-clean + ['] gshow-cleaning to show-cleaning + ['] gshow-pending to show-pending + ['] gshow-writing to show-writing + ['] gshow-written to show-written + ['] gshow-strange to show-strange + ['] gshow-done to show-done +; + +gshow + +\ 0 - marked bad block : show-bad +\ 1 - unreadable block : show-bad +\ 2 - jffs2 w/ summary: show-written +\ 3 - jffs2 w/o summary: show-pending +\ 4 - clean : show-clean +\ 5 - non-jffs2 data : show-strange +\ 6 - erased : show-erased +\ 7 - primary bad-block-table : show-bbt-block +\ 8 - secondary bad-block-table : show-bbt-block +: show-status ( status eblock# -- ) + swap case + 0 of show-bad endof + 1 of show-bad endof + 2 of show-written endof + 3 of show-pending endof + 4 of show-clean endof + 5 of show-strange endof + 6 of show-erased endof + 7 of show-bbt-block endof + 8 of show-bbt-block endof + endcase +; + +0 value nand-map +0 value working-page +: classify-block ( page# -- status ) + to working-page + + working-page /nand-page um* " seek" $call-nand drop + + \ Try to read the first few bytes + load-base /l " read" $call-nand + + \ Check for non-erased, non-JFFS2 data + load-base l@ h# ffff.ffff <> if 5 exit then + + \ See if the whole thing is really completely erased + load-base /l + /nand-block /l - " read" $call-nand /nand-block /l - <> if 1 exit then + + \ Not completely erased + load-base /nand-block written? if 5 exit then + + \ Erased + 6 +; + +0 value current-block +0 value examine-done? + +string-array status-descriptions + ," Marked bad in Bad Block Table" \ 0 + ," Read error" \ 1 + ," JFFS2 data with summary" \ 2 + ," JFFS2 data, no summary" \ 3 + ," Clean (erased with JFFS2 cleanmarker)" \ 4 + ," Dirty, with non-JFFS2 data" \ 5 + ," Erased, no cleanmarker" \ 6 + ," Primary Bad Block Table" \ 7 + ," Secondary Bad Block Table" \ 8 +end-string-array + +: show-block-status ( block# -- ) + dup show-eblock# + nand-map + c@ status-descriptions count type kill-line +; + +: cell-border ( block# color -- ) + swap >loc ( color x y ) + -1 -1 xy+ + 3dup grid-w 1 do-fill ( color x y ) + 3dup grid-w 0 xy+ 1 grid-h do-fill ( color x y ) + 3dup 0 1 xy+ 1 grid-h do-fill ( color x y ) + 1 grid-h xy+ grid-w 1 do-fill +; +: lowlight ( block# -- ) background-rgb rgb>565 cell-border ; +: highlight ( block# -- ) 0 cell-border ; +: point-block ( block# -- ) + current-block lowlight + to current-block + current-block highlight +; + +0 value nand-block-limit +: +block ( offset -- ) + current-block + nand-block-limit mod ( new-block ) + point-block + current-block show-block-status +; + +: process-key ( char -- ) + case + h# 9b of endof + [char] A of #cols negate +block endof \ up + [char] B of #cols +block endof \ down + [char] C of 1 +block endof \ right + [char] D of -1 +block endof \ left + [char] ? of #cols 8 * negate +block endof \ page up + [char] / of #cols 8 * +block endof \ page down + [char] K of 8 +block endof \ page right + [char] H of -8 +block endof \ page left + h# 1b of d# 20 ms key? 0= if true to examine-done? then endof + endcase +; + +: examine-nand ( -- ) + 0 status-line 1- at-xy red-letters ." Arrows, fn Arrows to move, Esc to exit" black-letters cr + #nand-pages nand-pages/block / to nand-block-limit + 0 to current-block + current-block highlight + false to examine-done? + begin key process-key examine-done? until + current-block lowlight +; + +: (scan-nand) ( -- ) + nand-map 0= if + #nand-pages nand-pages/block / alloc-mem to nand-map + then + + " usable-page-limit" $call-nand + dup nand-pages/block / show-init ( page-limit ) + + 0 ?do + i classify-block ( status ) + i nand-pages/block / ( status eblock# ) + 2dup nand-map + c! ( status eblock# ) + show-status + nand-pages/block +loop ( ) + + show-done +; + +: scan-nand ( -- ) + open-nand (scan-nand) close-nand-ihs + examine-nand +; + + +: >eblock# ( page# -- eblock# ) nand-pages/block / ; + +: copy-nand ( "devspec" -- ) + open-nand + get-img-filename + open-img + + ['] noop to show-progress + + #nand-pages >eblock# dup show-init ( #eblocks ) + + show-erasing ( ) + + #image-eblocks show-writing + + #image-eblocks 0 ?do + read-image-block + i check-mem-hash + load-base " copy-block" $call-nand ( page# error? ) + " Error writing to NAND FLASH" ?nand-abort ( page# ) + >eblock# show-written ( ) + loop + + show-done + + close-nand-ihs +; + +: verify-nand ( "devspec" -- ) + open-nand + get-img-filename + open-img + ['] noop to show-progress + + ." Verifing " #image-eblocks . ." blocks" cr + + #image-eblocks 0 ?do + (cr i . + read-image-block + + i /nand-block um* " seek" $call-nand drop + load-base /nand-block " read" $call-nand ( len ) + /nand-block <> " Disk read error" ?nand-abort ( ) + + load-base load-base /nand-block + /nand-block comp if ( ) + cr ." Miscompare in block starting at page# " ( ) + ?key-stop + then ( ) + loop ( ) + close-nand-ihs +; + +: verify-img ( "img-devspec" -- ) + hex + open-nand close-nand-ihs \ To set sizes + get-img-filename + open-img + + ['] noop to show-progress + + ." Verifying " #image-eblocks . ." blocks" cr + + #image-eblocks 0 ?do + (cr i . + read-image-block + i check-mem-hash + loop + close-nand-ihs +; + +: check-hash ( adr len -- ) + 2drop \ XXX +; + +: verify-nand ( "crc-devspec" -- ) + hex + open-nand + safe-parse-word open-img + ['] noop to show-progress + + ." Verifying " #image-eblocks . ." blocks" cr + + #image-eblocks 0 ?do + (cr i . + + i /nand-block um* " seek" $call-nand drop + load-base /nand-block " read" $call-nand ( len ) + /nand-block <> " Disk read failure" ?nand-abort ( ) + + load-base /nand-block check-hash if ( ) + cr ." Hash mismatch at eblock " i . cr ( ) + ?key-stop + else ( actual-crc expected-crc ) + 2drop ( ) + then ( ) + loop ( ) + close-nand-ihs +; + +: make-new-file ( devspec$ -- fileih ) + 2dup ['] $delete catch if 2drop then ( name$ ) + 2dup ['] $create-file catch if ( name$ x x ) + 2drop ( name$ ) + " Can't open a file. Try using the raw disk?" confirm if ( name$ ) + open-dev ( ih ) + else ( name$ ) + 2drop 0 ( ih=0 ) + then ( ih ) + else ( name$ ih ) + nip nip ( ih ) + then ( ih ) +; + +: open-dump-file ( devspec$ -- ) + cr ." Dumping to " 2dup type cr + + make-new-file to fileih + + fileih 0= " Can't open output" ?nand-abort +; + +: dump-eblock? ( block# -- flag ) + \ Dump JFFS2 w/summary (2), JFFS2 w/o summary (3), non JFFS2 data (5) + nand-map + c@ dup 2 = over 3 = or swap 5 = or +; + +0 [if] +: eblock>file ( -- ) + load-base /nand-block " write" fileih $call-method + /nand-block <> " Write to dump file failed" ?nand-abort + load-base /nand-block $crc #image-eblocks >crc l! + #image-eblocks 1+ to #image-eblocks +; + +: fastdump-nand ( -- ) + \ The stack is empty at the end of each line unless otherwise noted + (scan-nand) + + cursor-off + d# 20 status-line at-xy ." " + + " usable-page-limit" $call-nand >eblock# 0 do + i dump-eblock? if + i point-block + i show-eblock# + load-base i nand-pages/block * nand-pages/block " read-pages" $call-nand ( #read ) + nand-pages/block <> " Read failed" ?nand-abort + eblock>file + then + loop + show-done +; + +: slowdump-nand ( -- ) + \ The stack is empty at the end of each line unless otherwise noted + #nand-pages 0 ?do + (cr i >eblock# . + load-base i nand-pages/block " read-pages" $call-nand ( #read ) + nand-pages/block = if + load-base /nand-block written? if + ." w" + eblock>file + i nand-pages/block bounds ?do + i pad ! pad 4 " write" fileih $call-method + 4 <> " Write of eblock number failed" ?nand-abort + loop + else + ." s" + then + then + nand-pages/block +loop +; + +: (dump-nand) ( "devspec" -- ) + open-nand + get-img-filename + + alloc-crc-buf + image-name$ open-dump-file + + 0 to #image-eblocks + + fastdump-nand + cr ." Done" cr + + close-image-file + + close-nand-ihs +; +: save-nand ( "devspec" -- ) (dump-nand) ; + +: fastcopy-nand ( "devspec" -- ) + open-nand + + safe-parse-word open-dev to fileih + fileih 0= " Can't open NAND fastboot image file" ?nand-abort + + " size" fileih $call-method drop ( len ) + " start-fastcopy" $call-nand ( error? ) + " Not enough spare NAND space for fast copy" ?nand-abort + + begin ( ) + load-base /nand-block " read" fileih $call-method ( len ) + dup 0> while ( len ) + \ If the read didn't fill a complete block, zero the rest + load-base /nand-block rot /string erase + + load-base " next-fastcopy" $call-nand ( ) + repeat ( len ) + drop ( ) + " end-fastcopy" $call-nand ( ) + + close-nand-ihs +; +[then] + +\ LICENSE_BEGIN +\ Copyright (c) 2006 FirmWorks +\ +\ Permission is hereby granted, free of charge, to any person obtaining +\ a copy of this software and associated documentation files (the +\ "Software"), to deal in the Software without restriction, including +\ without limitation the rights to use, copy, modify, merge, publish, +\ distribute, sublicense, and/or sell copies of the Software, and to +\ permit persons to whom the Software is furnished to do so, subject to +\ the following conditions: +\ +\ The above copyright notice and this permission notice shall be +\ included in all copies or substantial portions of the Software. +\ +\ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, +\ EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF +\ MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND +\ NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE +\ LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION +\ OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION +\ WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. +\ +\ LICENSE_END
Modified: cpu/x86/pc/olpc/via/devices.fth =================================================================== --- cpu/x86/pc/olpc/via/devices.fth 2009-07-31 18:45:34 UTC (rev 1263) +++ cpu/x86/pc/olpc/via/devices.fth 2009-07-31 18:46:49 UTC (rev 1264) @@ -164,9 +164,6 @@ .( XXX Not clearing CMOS) cr patch noop init-bios-cmos stand-init
-devalias nand /nandflash -devalias mtd /nandflash - [ifdef] use-null-nvram \ For not storing configuration variable changes across reboots ... \ This is useful for "turnkey" systems where configurability would
Modified: cpu/x86/pc/olpc/via/fw.bth =================================================================== --- cpu/x86/pc/olpc/via/fw.bth 2009-07-31 18:45:34 UTC (rev 1263) +++ cpu/x86/pc/olpc/via/fw.bth 2009-07-31 18:46:49 UTC (rev 1264) @@ -319,9 +319,8 @@ fload ${BP}/dev/olpc/keyboard/selftest.fth \ Keyboard diagnostic fload ${BP}/dev/olpc/touchpad/touchpad.fth \ Touchpad diagnostic fload ${BP}/cpu/x86/pc/olpc/gridmap.fth \ Gridded display tools -[ifdef] Later -fload ${BP}/cpu/x86/pc/olpc/copynand.fth -[then] +fload ${BP}/cpu/x86/pc/olpc/via/copynand.fth + \ fload ${BP}/cpu/x86/pc/olpc/carousel.fth \ Carouseled NAND writing fload ${BP}/cpu/x86/pc/olpc/crypto.fth \ Cryptographic image validation fload ${BP}/cpu/x86/pc/olpc/lzip.fth \ Access zip images from memory @@ -480,8 +479,9 @@ [ifdef] Later fload ${BP}/cpu/x86/pc/olpc/nandcastui.fth fload ${BP}/cpu/x86/pc/olpc/wifichannel.fth -fload ${BP}/cpu/x86/pc/olpc/fsupdate.fth [then] +fload ${BP}/cpu/x86/pc/olpc/via/fsupdate.fth +devalias fsdisk /ide@0/disk:0
fload ${BP}/ofw/inet/sntp.fth : olpc-ntp-servers ( -- )
Modified: cpu/x86/pc/olpc/via/olpc.bth =================================================================== --- cpu/x86/pc/olpc/via/olpc.bth 2009-07-31 18:45:34 UTC (rev 1263) +++ cpu/x86/pc/olpc/via/olpc.bth 2009-07-31 18:46:49 UTC (rev 1264) @@ -145,8 +145,8 @@
" memtest" " memtest" $add-deflated-dropin
+ " verify.img" " verify" $add-deflated-dropin [ifdef] Later - " verify.img" " verify" $add-deflated-dropin " os.public" " ospubkey" $add-dropin \ Incompressible " fw.public" " fwpubkey" $add-dropin \ Incompressible " fs.public" " fspubkey" $add-dropin \ Incompressible
