Author: wmb Date: Thu Nov 1 22:02:34 2012 New Revision: 3406 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3406
Log: OLPC XO-4 - Fixed OLPC trac #12265 (HDMI colors swapped). Also changed the PHY tuning parameters per wad's recommendations.
Modified: cpu/arm/mmp3/hdmi.fth
Modified: cpu/arm/mmp3/hdmi.fth ============================================================================== --- cpu/arm/mmp3/hdmi.fth Thu Nov 1 05:59:36 2012 (r3405) +++ cpu/arm/mmp3/hdmi.fth Thu Nov 1 22:02:34 2012 (r3406) @@ -225,11 +225,11 @@ : select-3d ( -- ) pll-cfg0@ 1 invert and pll-cfg0! ;
\ Tune these for best eye diagram -5 value damp 1 value eamp 0 value cp -0 value ajd 1 value svtx h# c value idrv +6 value damp 2 value eamp 0 value cp +0 value ajd 1 value svtx 8 value idrv
: setup-phy ( freq -- ) - drop \ We may need to retune the phy for different frequencies + d# 148 = if 9 else 8 then to idrv
select-phy
@@ -323,34 +323,6 @@ \ : dither! ( n -- ) h# a0 lcd! ; \ : dither-table! ( n -- ) h# a4 lcd! ;
-[ifdef] notdef -: tv-clear ( reg# -- ) 0 swap lcd! ; -: tv-unused-clear ( -- ) - h# 00 tv-clear h# 04 tv-clear h# 08 tv-clear \ Y0, U0, V0 start address - h# 10 tv-clear h# 14 tv-clear h# 18 tv-clear \ Y1, U1, V1 start address - h# 20 tv-clear h# 24 tv-clear \ Y+C pitch, U+V pitch - h# 28 tv-clear \ Video starting point on screen - h# 2c tv-clear h# 30 tv-clear \ Video source size, dest size - h# 38 tv-clear \ Graphic frame 1 start address - 0 0 tv-gfx-offset! - 0 0 tv-cursor-pos! - h# 68 tv-clear h# 6c tv-clear \ Cursor color 1, 2 - h# 70 tv-clear h# 74 tv-clear h# 78 tv-clear \ Y, U, V color keys -; -: tv-enable ( -- ) h# 5140 tv-dma-ctrl0! ; -: tv-misc ( -- ) - tv-unused-clear - h# 283eff00 tv-dma-ctrl1! - h# 00ff1001 tv-tvif! - h# 60010005 tv-divider! -; -: tv-base-res! ( hres vres -- ) - over bytes/pixel * tv-pitch! ( hres vres ) - 2dup tv-gfx-dst-res! ( hres vres ) - tv-active! ( ) -; -[then] - d# 16 value tv-bpp : init-tv-graphics ( -- ) init-tv-clock @@ -367,8 +339,7 @@
7 d# 9 -bits \ Turn off YUV422PACK, YVYU422P, UYVY422P
- 1 d# 12 -bits \ RGBswap -\ 1 d# 12 +bits \ RGBswap + 1 d# 12 +bits \ RGBswap (RGB, not BGR) 1 d# 27 +bits \ DMA AXI arbiter enable tv-dma-ctrl0!
