Author: wmb Date: 2009-10-10 01:43:00 +0200 (Sat, 10 Oct 2009) New Revision: 1411
Modified: cpu/x86/pc/olpc/via/fw.bth cpu/x86/pc/olpc/via/padlock.fth ofw/inet/tcp.fth Log: Via - randomize TCP sequence number.
Modified: cpu/x86/pc/olpc/via/fw.bth =================================================================== --- cpu/x86/pc/olpc/via/fw.bth 2009-10-09 23:36:03 UTC (rev 1410) +++ cpu/x86/pc/olpc/via/fw.bth 2009-10-09 23:43:00 UTC (rev 1411) @@ -451,6 +451,8 @@
fload ${BP}/forth/lib/selstr.fth
+fload ${BP}/cpu/x86/pc/olpc/via/padlock.fth \ Via security engine + fload ${BP}/ofw/inet/loadtcp.fth
support-package: http @@ -481,7 +483,6 @@ fload ${BP}/cpu/x86/pc/olpc/nandcastui.fth fload ${BP}/cpu/x86/pc/olpc/wifichannel.fth [then] -fload ${BP}/cpu/x86/pc/olpc/via/padlock.fth \ Via security engine fload ${BP}/cpu/x86/pc/olpc/via/fsupdate.fth fload ${BP}/cpu/x86/pc/olpc/via/fsverify.fth devalias fsdisk int:0
Modified: cpu/x86/pc/olpc/via/padlock.fth =================================================================== --- cpu/x86/pc/olpc/via/padlock.fth 2009-10-09 23:36:03 UTC (rev 1410) +++ cpu/x86/pc/olpc/via/padlock.fth 2009-10-09 23:43:00 UTC (rev 1411) @@ -2,7 +2,7 @@
: enable-padlock ( -- ) cr4@ h# 200 or cr4! ; \ SSE enable
-code random-bytes ( adr len -- ) +code random-bytes ( adr len -- ) \ The buffer at adr must be at least 8 bytes long cr4 ebx mov ebx eax mov h# 200 # eax or eax cr4 mov cx pop 0 [sp] di xchg @@ -12,6 +12,7 @@ ax cx sub 0= until 0 [sp] di xchg + ax pop ebx cr4 mov c; code random-byte ( -- n ) @@ -27,6 +28,7 @@ cx di mov ebx cr4 mov c; +: random-long ( -- l ) 0 0 sp@ 4 random-bytes nip ;
create sha256-constants h# 6A09E667 , h# BB67AE85 , h# 3C6EF372 , h# A54FF53A ,
Modified: ofw/inet/tcp.fth =================================================================== --- ofw/inet/tcp.fth 2009-10-09 23:36:03 UTC (rev 1410) +++ ofw/inet/tcp.fth 2009-10-09 23:43:00 UTC (rev 1411) @@ -1390,8 +1390,12 @@ ;
: next-iss ( -- ) +[ifdef] random-long + random-long to iss +[else] tcp_iss to iss issincr 2/ tcp_iss + to tcp_iss +[then] ;
: do-syn-sent? ( -- done? )
