Author: wmb Date: 2010-01-12 23:45:35 +0100 (Tue, 12 Jan 2010) New Revision: 1661
Modified: cpu/x86/pc/olpc/via/fw.bth Log: OLPC trac 9980 - disable pretty boot during factory test.
Modified: cpu/x86/pc/olpc/via/fw.bth =================================================================== --- cpu/x86/pc/olpc/via/fw.bth 2010-01-11 20:43:51 UTC (rev 1660) +++ cpu/x86/pc/olpc/via/fw.bth 2010-01-12 22:45:35 UTC (rev 1661) @@ -582,19 +582,15 @@ \ .built cr ;
-: ?factory-boot-sequence ( -- flag ) +: factory-test? ( -- flag ) \ TS is the "test station" tag. Its value is set to "DL" at the \ end of manufacturing test. - " TS" find-tag if ( adr len ) - ?-null " DL" $= 0= ( in-factory? ) - else ( ) - \ Missing TS tag is treated as not factory mode + " TS" find-tag if ( adr len ) + ?-null " SHIP" $= 0= ( in-factory? ) + else ( ) + \ Missing TS tag is treated as not in factory test false - then ( in-factory? ) - if ( ) - " /prober /usb/ethernet disk:\boot\olpc.fth int:\boot\olpc.fth /xp ext:\boot\olpc.fth /wlan" - to boot-device - then ( ) + then ( in-factory? ) ;
: debug-interact ( -- ) @@ -650,7 +646,6 @@ no-page
?factory-mode -\ ?factory-boot-sequence
disable-user-aborts console-start @@ -663,7 +658,7 @@
read-game-keys
- text-off + factory-test? 0= if text-off then
" probe-" do-drop-in
@@ -688,7 +683,7 @@ ?scan-nand [then] ?fs-update - secure-startup + factory-test? 0= if secure-startup then unblock-exceptions ['] (interrupt-auto-boot?) to interrupt-auto-boot? ?usb-keyboard
