Author: wmb Date: Thu Feb 3 07:59:14 2011 New Revision: 2166 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2166
Log: Pong - added touchscreen support to pong game.
Modified: cpu/arm/olpc/1.75/exc7200-touchscreen.fth cpu/arm/olpc/1.75/fw.bth ofw/gui/ofpong.fth
Modified: cpu/arm/olpc/1.75/exc7200-touchscreen.fth ============================================================================== --- cpu/arm/olpc/1.75/exc7200-touchscreen.fth Thu Feb 3 07:58:08 2011 (r2165) +++ cpu/arm/olpc/1.75/exc7200-touchscreen.fth Thu Feb 3 07:59:14 2011 (r2166) @@ -6,6 +6,8 @@ " touchscreen" name : open ( -- okay? ) my-unit " set-address" $call-parent true + \ Read once to prime the interrupt + d# 10 " get" $call-parent 4drop 4drop 2drop ; : close ( -- ) ; : get-touch? ( -- false | x y z down? contact# true )
Modified: cpu/arm/olpc/1.75/fw.bth ============================================================================== --- cpu/arm/olpc/1.75/fw.bth Thu Feb 3 07:58:08 2011 (r2165) +++ cpu/arm/olpc/1.75/fw.bth Thu Feb 3 07:59:14 2011 (r2166) @@ -252,6 +252,7 @@ fload ${BP}/cpu/x86/pc/olpc/via/fsverify.fth devalias fsdisk int:0
+create pong-use-touchscreen fload ${BP}/ofw/gui/ofpong.fth [ifdef] notyet fload ${BP}/cpu/x86/pc/olpc/life.fth
Modified: ofw/gui/ofpong.fth ============================================================================== --- ofw/gui/ofpong.fth Thu Feb 3 07:58:08 2011 (r2165) +++ ofw/gui/ofpong.fth Thu Feb 3 07:59:14 2011 (r2166) @@ -7,10 +7,6 @@ 0 value erasecol -1 value drawcol
-0 value key_left_up -0 value key_left_down -0 value key_right_up -0 value key_right_down 0 value key_esc 0 value key_off
@@ -42,36 +38,39 @@ ballsize 5 * value batsize 1000 value pscale
+: scale ( coord -- scaled-coord ) pscale * ; + 0 value ball_limit_x -ballsize pscale * value ball_limit_lo_y +ballsize scale value ball_limit_lo_y 0 value ball_limit_hi_y
-ballsize pscale * value bat_limit_lo_y +ballsize scale value bat_limit_lo_y 0 value bat_limit_hi_y
0 value hit_limit_left_lo_x -ballsize 2 * pscale * value hit_limit_left_hi_x +ballsize 2 * scale value hit_limit_left_hi_x 0 value hit_limit_right_lo_x 0 value hit_limit_right_hi_x
-ballsize pscale * value reflect_left_x +ballsize scale value reflect_left_x 0 value reflect_right_x
: initlimits " dimensions" $call-screen to screenh to screenw - screenw ballsize - pscale * to ball_limit_x - screenh ballsize 2 * - pscale * to ball_limit_hi_y - screenh ballsize batsize + - pscale * to bat_limit_hi_y - screenw ballsize 3 * - pscale * to hit_limit_right_lo_x - screenw ballsize - pscale * to hit_limit_right_hi_x + screenw ballsize - scale to ball_limit_x + screenh ballsize 2 * - scale to ball_limit_hi_y + screenh ballsize batsize + - scale to bat_limit_hi_y + screenw ballsize 3 * - scale to hit_limit_right_lo_x + screenw ballsize - scale to hit_limit_right_hi_x
- screenw ballsize 2 * - pscale * to reflect_right_x + screenw ballsize 2 * - scale to reflect_right_x get-msecs to grandseed ;
: random1k ( -- n ) grandseed 16807 * 17 + abs to grandseed grandseed 1000 mod ; : unscale ( n -- n ) pscale 2/ + pscale / ; -: calcbatx ( n -- x ) screenw ballsize 3 * - * ballsize + ; +: leftbatx ( -- n ) ballsize ; +: rightbatx ( -- n ) screenw ballsize 2* - ; : paintrect ( c pixx pixy pixw pixh -- ) " fill-rectangle" $call-screen ;
\needs xy* : xy* ( x y w h -- x' y' ) rot * >r * r> ; @@ -223,8 +222,8 @@
ballsize 7 * ballsize 2* leftscore drawnumber screenw ballsize 7 * 9 scoresize * + - ballsize 2* rightscore drawnumber - 0 calcbatx leftbaty plotbat - 1 calcbatx rightbaty plotbat + leftbatx leftbaty plotbat + rightbatx rightbaty plotbat ballx bally plotball ;
@@ -236,23 +235,23 @@
: resetball ( -- ) 500 to ballstop - screenw ballsize - 2 / pscale * ballx pscale mod + random1k + to ballx - screenh ballsize - 2 / pscale * bally pscale mod + random1k + to bally + screenw ballsize - 2 / scale ballx pscale mod + random1k + to ballx + screenh ballsize - 2 / scale bally pscale mod + random1k + to bally
- random1k screenw pscale * * 2000000 / to balldx - random1k screenh pscale * * 2000000 / to balldy - balldx screenw pscale * 3000 / + to balldx - balldy screenh pscale * 6000 / + to balldy + random1k screenw scale * 2000000 / to balldx + random1k screenh scale * 2000000 / to balldy + balldx screenw scale 3000 / + to balldx + balldy screenh scale 6000 / + to balldy
random1k 500 < if balldx negate to balldx then random1k 500 < if balldy negate to balldy then ;
: initvalues ( -- ) - ballsize 2* pscale * to leftbaty - screenh ballsize 2 * - batsize - pscale * to rightbaty + ballsize 2* scale to leftbaty + screenh ballsize 2* - batsize - scale to rightbaty
- screenh pscale * 1000 / to batdy + screenh scale 1000 / to batdy ;
: doreset ( -- ) @@ -267,6 +266,54 @@ \ poll key states if you can.
[ifdef] olpc +[ifdef] pong-use-touchscreen +0 value pong-ih +: >bat-center ( baty -- centery ) batsize scale 2/ + ; +0 value left-bat-target +0 value right-bat-target +: initkeys ( -- ) + pong-ih 0= if + " /touchscreen" open-dev to pong-ih + then + pong-ih 0= abort" Can't open touchscreen" + + rightbaty >bat-center to right-bat-target + leftbaty >bat-center to left-bat-target + + false to key_esc + false to key_off +; +: restorekeys ( -- ) pong-ih ?dup if close-dev 0 to pong-ih then ; +: scale-xy ( x y -- x' y' ) + swap screenw 1- * d# 15 rshift + swap screenh 1- * d# 15 rshift +; +: scankeys ( -- ) + " get-touch?" pong-ih $call-method if ( x y z down? touch# ) + 3drop ( x y ) + scale-xy ( x' y' ) + scale swap 4 lshift screenw / ( y' 0<=x'<16 ) + dup 1 <= if ( y 0<=x'<16 ) + drop to left-bat-target ( ) + exit + then ( y 0<=x'<16 ) + d# 14 >= if ( y ) + to right-bat-target + exit + then ( y ) + drop ( ) + then + key? if key 27 = if true to key_off else true to key_esc then then +; +\ The "5 >>a" makes the paddles a little sluggish, for more challenge +: left-deltay ( deltat oldy -- oldy deltay ) + nip left-bat-target over >bat-center - 5 >>a +; +: right-deltay ( deltat oldy -- oldy deltay ) + nip right-bat-target over >bat-center - 5 >>a +; +: wait-esc-off false to key_esc ; +[else] \ This works with the FirmWorks pckbd driver. The key map below \ is good for the OLPC keyboard. [ifdef] keyboard-ih @@ -275,6 +322,11 @@ : pong-ih stdin @ ; [then]
+0 value key_left_up +0 value key_left_down +0 value key_right_up +0 value key_right_down + : initkeys ." Shift, Hand, Esc, Square" cr d# 3000 ms @@ -314,9 +366,15 @@ then repeat ; +: wait-esc-off ( -- ) begin scankeys key_esc 0= until ; +[then] [else] \ This version uses "key" with normal ASCII. It is typically too slow \ dup to limited keyboard repeat rate. +0 value key_left_up +0 value key_left_down +0 value key_right_up +0 value key_right_down : initkeys ; : restorekeys ; : scankeys @@ -338,6 +396,33 @@ endcase then ; +: wait-esc-off false to key_esc ; +[then] +[ifndef] right-deltay +: left-deltay ( deltat oldy -- oldy deltay ) + 0 ( deltat oldy deltay ) + over bat_limit_lo_y > if ( deltat oldy deltay ) + key_left_up if batdy - then ( deltat oldy deltay' ) + then ( deltat oldy deltay ) + + over bat_limit_hi_y < if ( deltat oldy deltay ) + key_left_down if batdy + then ( deltat oldy deltay ) + then ( deltat oldy deltay ) + + rot * ( oldy deltay' ) \ Scale by the elapsed time +; +: right-deltay ( deltat oldy -- oldy deltay ) + 0 ( deltat oldy deltay ) + + over bat_limit_lo_y > if ( deltat oldy deltay ) + key_right_up if batdy - then ( deltat oldy deltay' ) + then + + over bat_limit_hi_y < if + key_right_down if batdy + then + then + rot * +; [then]
: moveball ( oldx oldy newx newy -- ) 2swap eraseball plotball ; @@ -353,7 +438,7 @@ ballx 0< if resetball balldx abs negate to balldx - ballx ballsize 2 * pscale * + to ballx + ballx ballsize 2 * scale + to ballx rightscore 1 + to rightscore rightscore 15 = if -1 to ballstop @@ -362,7 +447,7 @@ ballx ball_limit_x > if resetball balldx abs to balldx - ballx ballsize 2 * pscale * - to ballx + ballx ballsize 2 * scale - to ballx leftscore 1 + to leftscore leftscore 15 = if -1 to ballstop @@ -380,13 +465,13 @@
balldx 0< if ballx hit_limit_left_lo_x hit_limit_left_hi_x between if - bally leftbaty ballsize pscale * - leftbaty batsize pscale * + between if + bally leftbaty ballsize scale - leftbaty batsize scale + between if
bally leftbaty < if balldy abs negate to balldy then
- bally leftbaty batsize ballsize - pscale * + > if + bally leftbaty batsize ballsize - scale + > if balldy abs to balldy then
@@ -406,13 +491,13 @@
balldx 0> if ballx hit_limit_right_lo_x hit_limit_right_hi_x between if - bally rightbaty ballsize pscale * - rightbaty batsize pscale * + between if + bally rightbaty ballsize scale - rightbaty batsize scale + between if
bally rightbaty < if balldy abs negate to balldy then
- bally rightbaty batsize ballsize - pscale * + > if + bally rightbaty batsize ballsize - scale + > if balldy abs to balldy then
@@ -472,8 +557,8 @@ drawcol batx r> batsize + ballsize r> paintrect ;
-: movebat ( n oldy newy -- ) - rot calcbatx to batx swap ( newy oldy ) +: movebat ( oldy newy x -- ) + to batx swap ( newy oldy ) over unscale over unscale - ( newy oldy deltay ) dup abs batsize < if ( newy oldy deltay ) dup if ( newy oldy deltay ) @@ -493,36 +578,19 @@ then ;
-: updatebats ( deltat -- ) +: updatebats ( deltat -- )
r
- 0 leftbaty 0 ( n oldy deltay ) - - over bat_limit_lo_y > if - key_left_up if batdy - then - then + r@ leftbaty left-deltay ( oldy deltay r: deltat )
- over bat_limit_hi_y < if - key_left_down if batdy + then - then - - r@ * ( n oldy deltay' ) \ Scale by the elapsed time - over + ( n oldy newy ) - dup to leftbaty ( n oldy newy ) - movebat + over + ( oldy newy r: deltat ) + dup to leftbaty ( oldy newy r: deltat ) + leftbatx movebat
- 1 rightbaty 0 ( 1 right dy ) + r> rightbaty right-deltay ( oldy deltay )
- over bat_limit_lo_y > if - key_right_up if batdy - then - then - - over bat_limit_hi_y < if - key_right_down if batdy + then - then - - r> * over + - dup to rightbaty - movebat + over + ( oldy newy ) + dup to rightbaty ( oldy newy ) + rightbatx movebat ( ) ;
: initeverything ( -- ) @@ -548,25 +616,25 @@ ;
: pong ( -- ) - initeverything - begin - get-msecs glastupdate - + initeverything + begin + get-msecs glastupdate - dup 0> if - dup 250 > if - drop - get-msecs to glastupdate - 250 - then - doloop + dup 250 > if + drop + get-msecs to glastupdate + 250 + then + doloop else - drop + drop then - scankeys - key_esc if doreset begin scankeys key_esc 0= until then - key_off until - restorekeys - h# ffff 0 0 screenw screenh paintrect - page + scankeys + key_esc if doreset wait-esc-off then + key_off until + restorekeys + h# ffff 0 0 screenw screenh paintrect + page \ " Count:" type loopcount .d cr \ " Avg millisec:" type totalupdate loopcount / .d cr ;
