Author: wmb Date: Sat Oct 13 03:41:13 2012 New Revision: 3368 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3368
Log: OLPC XO-4 - additional info in device tree for the interrupt controller node on MMP3.
Modified: cpu/arm/mmp2/irq.fth
Modified: cpu/arm/mmp2/irq.fth ============================================================================== --- cpu/arm/mmp2/irq.fth Sat Oct 13 03:40:00 2012 (r3367) +++ cpu/arm/mmp2/irq.fth Sat Oct 13 03:41:13 2012 (r3368) @@ -5,7 +5,12 @@
" interrupt-controller" device-name \ my-address my-space h# 400 reg +[ifdef] mmp3 + h# d4282000 encode-int h# 1000 encode-int encode+ + h# d4284000 encode-int encode+ h# 100 encode-int encode+ " reg" property +[else] my-address my-space h# 1000 reg +[then]
0 value base-adr d# 64 constant #levels @@ -46,6 +51,8 @@ : close ( -- ) ;
" mrvl,mmp2-intc" " compatible" string-property +[ifdef] mmp3 " mrvl,mmp3-intc" +compatible [then] + 1 " #address-cells" integer-property 1 " #size-cells" integer-property : encode-unit ( phys.. -- str ) push-hex (u.) pop-base ; @@ -97,100 +104,6 @@ [then] h# 128 h# 11c d# 48 d# 24 make-mux-node \ DMA mux - 16 PDMA, 4 ADMA, 2 VDMA channels
-0 [if] -new-device - " interrupt-controller" name - " mrvl,mmp2-mux-intc" +compatible - - 0 0 - h# 150 encode-int encode+ 4 encode-int encode+ - h# 168 encode-int encode+ 4 encode-int encode+ " reg" property - \ h# 150 " mrvl,intc-status" integer-property - \ h# 168 " mrvl,intc-mask" integer-property - - 4 " interrupts" integer-property - d# 2 " mrvl,intc-nr-irqs" integer-property - \ 0: USB_CHARGER 1: PMIC -finish-device - -new-device - " interrupt-controller" name - " mrvl,mmp2-mux-intc" +compatible - - 0 0 - h# 154 encode-int encode+ 4 encode-int encode+ - h# 16c encode-int encode+ 4 encode-int encode+ " reg" property - - 5 " interrupts" integer-property - d# 2 " mrvl,intc-numbers" integer-property - d# 1 " mrvl,clr-mfp-irq" integer-property - \ 0: RTC_ALARM 1: RTC -finish-device - -new-device - " interrupt-controller" name - - " mrvl,mmp2-mux-intc" +compatible - - 0 0 - h# 180 encode-int encode+ 4 encode-int encode+ - h# 17c encode-int encode+ 4 encode-int encode+ " reg" property - - d# 9 " interrupts" integer-property - d# 3 " mrvl,intc-numbers" integer-property - \ 0:KPC (keypad) 1:ROT (rotary) 2: TBALL (trackball) - \ h# 15c " mrvl,intc-status" integer-property - \ h# 174 " mrvl,intc-mask" integer-property -finish-device - -new-device - " interrupt-controller" name - " mrvl,mmp2-mux-intc" +compatible - - 0 0 - h# 158 encode-int encode+ 4 encode-int encode+ - h# 170 encode-int encode+ 4 encode-int encode+ " reg" property - - d# 17 " interrupts" integer-property - d# 5 " mrvl,intc-numbers" integer-property - \ 0: TWSI2 1: TWSI3 2: TWSI4 3: TWSI5 4: TWSI6 -finish-device - -new-device - " interrupt-controller" name - - " mrvl,mmp2-mux-intc" +compatible - - 0 0 - h# 15c encode-int encode+ 4 encode-int encode+ - h# 174 encode-int encode+ 4 encode-int encode+ " reg" property - \ h# 15c " mrvl,intc-status" integer-property - \ h# 174 " mrvl,intc-mask" integer-property - - d# 35 " interrupts" integer-property - d# 15 " mrvl,intc-numbers" integer-property - \ 0: PERF 1: L2_PA_ECC 2: L2_ECC 3: L2_UECC 4: DDR - \ 5: FABRIC0_TO 6: FABRIC1_TO 7: FABRIC2_TO 8: resv 9: THERMAL - \ 10: MAIN_PMU 11: WDT2 12: CORESIGHT 13: COMMTX 14: COMMRX -finish-device - -new-device - " interrupt-controller" name - 0 0 " interrupt-controller" property - " mrvl,mmp2-mux-intc" +compatible - - 0 0 - h# 160 encode-int encode+ 4 encode-int encode+ - h# 178 encode-int encode+ 4 encode-int encode+ " reg" property - - d# 51 " interrupts" integer-property - d# 2 " mrvl,intc-numbers" integer-property - \ 0:HSI_CAWAKE 1:MIPI_HSI_INT1 - \ h# 15c " mrvl,intc-status" integer-property - \ h# 174 " mrvl,intc-mask" integer-property -finish-device -[then] - end-package
\ LICENSE_BEGIN
