Author: wmb Date: 2009-12-14 10:48:18 +0100 (Mon, 14 Dec 2009) New Revision: 1595
Modified: ofw/core/ofwcore.fth Log: OFW core - changed the implementation of the alarm list scanner so that an alarm handler can safely remove itself from the list from inside the handler.
Modified: ofw/core/ofwcore.fth =================================================================== --- ofw/core/ofwcore.fth 2009-12-13 20:22:36 UTC (rev 1594) +++ ofw/core/ofwcore.fth 2009-12-14 09:48:18 UTC (rev 1595) @@ -3898,18 +3898,29 @@ \ then check to see if the time is expired (time-remain = 0). \ If time is not expired, decrement the time-remain.
-: time-expired? ( node -- flag ) +: run-alarm ( node -- ) dup >time-remain @ 1- dup 0<= if ( node time-remain ) drop dup >time-out @ over ( node time-out node ) dup >acf @ swap >ihandle @ ( node time-out acf ihandle ) ['] call-package catch if ( node time-out acf ihandle ) 2drop ( node time-out ) then ( node time-out ) - then swap >time-remain ! false ( false ) + then swap >time-remain ! ( ) ;
headers -: check-alarm ( -- ) alarm-list ['] time-expired? find-node 2drop ; +\ We do this manually instead of using find-node because we need +\ to do >next-node before calling time-expired? in case the alarm +\ routine uninstalls itself, which could cause a crash if the +\ pointer to the next node were overwritten while being freed. +: check-alarm ( -- ) + alarm-list >next-node ( node ) + begin ?dup while ( node ) + dup >next-node swap ( next node ) + run-alarm ( next ) + repeat ( ) +; + : alarm ( acf n -- ) my-self -rot ( ihandle acf n ) ?dup if set-alarm-node else turn-off-alarm then
