Author: wmb Date: Sat Oct 22 12:40:07 2011 New Revision: 2643 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2643
Log: OLPC XO-1.75 - Fixed a name collision with timers-off .
Modified: cpu/arm/mmp2/dramrecal.fth
Modified: cpu/arm/mmp2/dramrecal.fth ============================================================================== --- cpu/arm/mmp2/dramrecal.fth Sat Oct 22 07:20:13 2011 (r2642) +++ cpu/arm/mmp2/dramrecal.fth Sat Oct 22 12:40:07 2011 (r2643) @@ -677,7 +677,7 @@ : wlan-stay-on ( -- ) h# 140 d# 34 af! h# 140 d# 57 af! h# 140 d# 58 af! ;
0 value sleep-mask -: screen-off +: screen-sleep sleep-mask 1 and if \ DCON power down dcon-freeze else @@ -696,7 +696,7 @@ wlan-power-off then \ saves 100 mW ; -: screen-on ( -- ) +: screen-wake ( -- ) sleep-mask 4 and 0= if wlan-power-on " /wlan" " wake" execute-device-method drop @@ -714,12 +714,12 @@ : stdin-idle-on ['] safe-idle to stdin-idle d# 15 enable-interrupt ; : stdin-idle-off ['] noop to stdin-idle ( install-uart-io ) d# 15 disable-interrupt ;
-: timers-off ( -- ) +: timers-sleep ( -- ) 0 h# 14048 io! \ Disable interrupts from the tick timer 7 h# 1407c io! \ Clear any pending interrupts h# f disable-interrupt \ Block timer interrupt ; -: timers-on ( -- ) +: timers-wake ( -- ) 1 h# 14048 io! \ Enable interrupts from the tick timer 7 h# 1407c io! \ Clear any pending interrupts h# f enable-interrupt \ Unblock timer interrupt @@ -736,9 +736,9 @@ : str ( -- ) disable-interrupts suspend-usb - timers-off + timers-sleep
- screen-off + screen-sleep stdin-idle-off 5 h# 38 mpmu! \ Use 32 kHz clock instead of VCXO for slow clock
@@ -779,8 +779,8 @@ \ idle_cfg &= (~PMUA_MOH_SRAM_PWRDWN); stdin-idle-on
- screen-on - timers-on + screen-wake + timers-wake resume-usb enable-interrupts ;
