Author: wmb Date: 2009-12-11 06:24:29 +0100 (Fri, 11 Dec 2009) New Revision: 1570
Added: cpu/x86/pc/olpc/via/runin.fth Removed: cpu/x86/pc/olpc/via/after_runin.fth Log: OLPC manufacturing tests - Renamed script from after_runin.fth to runin.fth .
Deleted: cpu/x86/pc/olpc/via/after_runin.fth =================================================================== --- cpu/x86/pc/olpc/via/after_runin.fth 2009-12-11 05:22:40 UTC (rev 1569) +++ cpu/x86/pc/olpc/via/after_runin.fth 2009-12-11 05:24:29 UTC (rev 1570) @@ -1,343 +0,0 @@ -\ Post-runin boot script $Revision$ - -visible - -\ The Linux-based runin selftests put this file at int:\runin\olpc.fth -\ after they have finished. On the next reboot, OFW thus boots this -\ script instead of int:\boot\olpc.fth . This script either displays -\ the failure log (if int:\runin\fail.log is present) or modifies the -\ manufacturing data tags to cause the next boot to enter final test. - -[ifndef] $read-file -\ Read entire file into allocated memory -: $read-file ( filename$ -- true | data$ false ) - open-dev ?dup 0= if true exit then >r ( r: ih ) - " size" r@ $call-method drop ( len r: ih ) - dup alloc-mem swap ( adr len r: ih ) - 2dup " read" r@ $call-method ( adr len actual r: ih ) - r> close-dev ( adr len actual ) - over <> if ( adr len ) - free-mem true exit - then ( adr len ) - false -; -[then] - -[ifndef] $(delete-tag) -: ($delete-tag) ( adr len -- ) - 2dup ram-find-tag 0= if 2drop exit then ( tagname$ ram-value$ ) - 2nip ( ram-value$ ) - - 2dup + c@ h# 80 and ( ram-value$ tag-style ) - if 4 else 5 then + >r ( tag-adr tag-len ) - ram-last-mfg-data >r ( tag-adr r: len bot-adr ) - r@ 2r@ + ( tag-adr src-adr dst-adr r: len bot-adr ) - rot r@ - ( src-adr dst-adr copy-len r: len bot-adr ) - move ( r: len bot-adr ) - r> r> h# ff fill ( ) -; -[then] - -d# 20 buffer: sn-buf -: sn$ ( -- adr len ) sn-buf count ; - -: try-get-sn ( -- ) - sn-buf 1+ d# 20 accept ( n ) - d# 12 <> if - " Wrong length, try again" .problem - exit - then - sn-buf 1+ " TSHC" comp if - " Must begin with TSHC, try again" .problem - exit - then - sn-buf 2+ sn-buf 1+ d# 11 move \ Elide the T - d# 11 sn-buf c! -; - -: get-sn ( -- ) - ." *****" - - begin - " Please Input Serial Number ......" .instructions - try-get-sn - sn-acquired? until -; - -: board#$ ( -- adr len ) - " B#" find-tag 0= abort" Missing B# tag !!!" - -null -; - -: get-info ( -- ) - get-sn -; - -0 0 2value response$ - -\ Send the board number as the request and return the response data -: final-tag-exchange ( -- ) - board#$ " %s.txt" open-temp-file - sn$ " SN:" put-key+value - " Request" submit-file - " Response" get-response to response$ -; - -0 value test-passed? -: show-result-screen ( -- ) - restore-scroller - clear-screen - test-passed? if - ." Selftest passed." cr cr cr - green-screen - else - ." Selftest failed." cr cr cr - red-screen - then - d# 2000 ms -; - -: parse-tags ( adr len -- ) - begin dup while ( adr len ) - linefeed left-parse-string ( rem$ line$ ) - ?remove-cr ( rem$ line$ ) - [char] : left-parse-string ( rem$ value$ key$ ) - dup 2 = if ( rem$ value$ key$ ) - put-tag ( rem$ ) - else ( rem$ value$ key$ ) - 4drop ( rem$ ) - then ( rem$ ) - repeat ( adr len ) - 2drop ( ) -; - -: inject-tags ( -- ) - get-mfg-data - - " TS" ($delete-tag) - " MS" ($delete-tag) - " BD" ($delete-tag) - - " SHIP" " TS" ($add-tag) - - response$ parse-tags - - put-mfg-data -; - -: mfg-ntp-server ( -- name$ ) - " NT" find-tag if ?-null else " 10.60.0.2" then -; -' mfg-ntp-server to ntp-servers - -d# 4 constant rtc-threshold -: verify-rtc-date ( -- ) - ." Getting time from NTP server " - begin ntp-timestamp while ." Retry " repeat ( d.timestamp ) - cr - ntp>time&date unix-seconds> ( ntp-seconds ) - today unix-seconds> ( ntp-seconds rtc-seconds ) - - ( difference ) - dup rtc-threshold > if ( difference ) - page show-fail - ." Clock lost " .d ." seconds since SMT" cr - begin halt again - else - abs rtc-threshold > if - page show-fail - ." Clock gained " .d ." seconds since SMT" cr - begin halt again - then - then -; - -: finish-final-test ( -- ) - show-result-screen - - test-passed? 0= if - ." Type a key to power off " - key drop cr power-off - then - - wait-lan - wait-scanner - - get-info - - verify-rtc-date - - cifs-connect - ." Connecting to server " final-tag-exchange ." Done" cr - cifs-disconnect - - inject-tags - - ." Powering off ..." d# 2000 ms - power-off -; - - -d# 15 to #mfgtests - -: final-tests ( -- ) - 5 #mfgtests + 5 do - i set-current-sq - refresh - d# 1000 ms - doit - pass? 0= if false to test-passed? finish-final-test unloop exit then - loop - true to test-passed? finish-final-test -; - -\ Make the "wait for SD insertion" step highly visible -dev ext -warning @ warning off -: selftest ( -- ) page show-pass selftest ; -warning ! -dend - -\ This modifies the menu to be non-interactive -: doit-once ( -- ) do-key final-tests ; -patch doit-once do-key menu-interact - -: silent-probe-usb ( -- ) - " /" ['] (probe-usb2) scan-subtree - " /" ['] (probe-usb1) scan-subtree - report-disk report-net report-keyboard -; - -: scanner? ( -- flag ) - " usb-keyboard" expand-alias if 2drop true else false then -; -: wait-scanner ( -- ) - scanner? 0= if - " Connect USB barcode scanner" .instructions - begin d# 1000 ms silent-probe-usb scanner? until - then - ; -: wired-lan? ( -- flag ) - " /usb/ethernet" locate-device if false else drop true then -; -: wait-lan ( -- ) - wired-lan? 0= if - " Connect USB Ethernet Adapter" .instructions - begin d# 1000 ms silent-probe-usb wired-lan? until - then -; -: usb-key? ( -- flag ) - " /usb/disk" locate-device if false else drop true then -; -: wait-usb-key ( -- ) - usb-key? 0= if - " Connect USB memory stick" .instructions - begin d# 1000 ms silent-probe-usb usb-key? until - then -; -: wait-connections ( -- ) - silent-probe-usb - wait-scanner - wait-lan -\ wait-usb-key -; - -: fail-log-file$ ( -- name$ ) " int:\runin\fail.log" ; - -: after-runin ( -- ) - fail-log-file$ $read-file 0= if ( adr len ) - page - show-fail - ." Type a key to see the failure log" - key drop cr cr - list - else -\ set-tags-for-fqa -\ " int:\runin\olpc.fth" $delete-all - - 5 to test-station - true to diag-switch? - " patch final-tests play-item mfgtest-menu" evaluate - menu - \ Shouldn't get here because the menu never exits - then - - ." Type a key to power off" - key cr - power-off -; - -after-runin - -SN:SHC946009D3 -B#:QTFJCA94400297 -P#:1CL11ZU0KDU -M#:CL1 -LA:USA -CC:2222XXXXXX -F#:F6 -L#:J -S#:CL1XL00802000 -T#:TSIMG_V3.0.6 -WM:00-17-C4-B9-39-ED -MN:XO-1 -BV:Q2E34 -U#:A4112195-98FE-419A-A77B-9F33C08FF913 -SD:241109 -IM_IP:10.1.0.2 -IM_ROOT:CL1XL00802000 -IM_NAME:CL1XL00802000 -WP:0 -Countries:Alabama -LO:en_US.UTF-8 -KA:USInternational_Keyboard -KM:olpc -KL:us -KV:olpc -ak:0 -sk:20 -SG:79 -DT:20091124152811 - -SET WO=304027439 - -Use these info to check the tags inside the SPI flash. - -Write the following tags from response file: - -WP: -SG: - -Get date time from NTP server 10.1.0.1 and write MD tag - MD: 20081014T200700Z - -Set TS tag to SHIP - -Send the following information to shop flow - -SN: -M#: -U#: -P#: -B#: -LA: -CC: -F#: -L#: -S#: -T#: -BV: -TS: -SS: -FQ: -SD: -WM: -MN: -KL: -KV: -KM: -LO: -WP: -RESULT:PASS - - -
Copied: cpu/x86/pc/olpc/via/runin.fth (from rev 1569, cpu/x86/pc/olpc/via/after_runin.fth) =================================================================== --- cpu/x86/pc/olpc/via/runin.fth (rev 0) +++ cpu/x86/pc/olpc/via/runin.fth 2009-12-11 05:24:29 UTC (rev 1570) @@ -0,0 +1,343 @@ +\ Post-runin boot script $Revision$ + +visible + +\ The Linux-based runin selftests put this file at int:\runin\olpc.fth +\ after they have finished. On the next reboot, OFW thus boots this +\ script instead of int:\boot\olpc.fth . This script either displays +\ the failure log (if int:\runin\fail.log is present) or modifies the +\ manufacturing data tags to cause the next boot to enter final test. + +[ifndef] $read-file +\ Read entire file into allocated memory +: $read-file ( filename$ -- true | data$ false ) + open-dev ?dup 0= if true exit then >r ( r: ih ) + " size" r@ $call-method drop ( len r: ih ) + dup alloc-mem swap ( adr len r: ih ) + 2dup " read" r@ $call-method ( adr len actual r: ih ) + r> close-dev ( adr len actual ) + over <> if ( adr len ) + free-mem true exit + then ( adr len ) + false +; +[then] + +[ifndef] $(delete-tag) +: ($delete-tag) ( adr len -- ) + 2dup ram-find-tag 0= if 2drop exit then ( tagname$ ram-value$ ) + 2nip ( ram-value$ ) + + 2dup + c@ h# 80 and ( ram-value$ tag-style ) + if 4 else 5 then + >r ( tag-adr tag-len ) + ram-last-mfg-data >r ( tag-adr r: len bot-adr ) + r@ 2r@ + ( tag-adr src-adr dst-adr r: len bot-adr ) + rot r@ - ( src-adr dst-adr copy-len r: len bot-adr ) + move ( r: len bot-adr ) + r> r> h# ff fill ( ) +; +[then] + +d# 20 buffer: sn-buf +: sn$ ( -- adr len ) sn-buf count ; + +: try-get-sn ( -- ) + sn-buf 1+ d# 20 accept ( n ) + d# 12 <> if + " Wrong length, try again" .problem + exit + then + sn-buf 1+ " TSHC" comp if + " Must begin with TSHC, try again" .problem + exit + then + sn-buf 2+ sn-buf 1+ d# 11 move \ Elide the T + d# 11 sn-buf c! +; + +: get-sn ( -- ) + ." *****" + + begin + " Please Input Serial Number ......" .instructions + try-get-sn + sn-acquired? until +; + +: board#$ ( -- adr len ) + " B#" find-tag 0= abort" Missing B# tag !!!" + -null +; + +: get-info ( -- ) + get-sn +; + +0 0 2value response$ + +\ Send the board number as the request and return the response data +: final-tag-exchange ( -- ) + board#$ " %s.txt" open-temp-file + sn$ " SN:" put-key+value + " Request" submit-file + " Response" get-response to response$ +; + +0 value test-passed? +: show-result-screen ( -- ) + restore-scroller + clear-screen + test-passed? if + ." Selftest passed." cr cr cr + green-screen + else + ." Selftest failed." cr cr cr + red-screen + then + d# 2000 ms +; + +: parse-tags ( adr len -- ) + begin dup while ( adr len ) + linefeed left-parse-string ( rem$ line$ ) + ?remove-cr ( rem$ line$ ) + [char] : left-parse-string ( rem$ value$ key$ ) + dup 2 = if ( rem$ value$ key$ ) + put-tag ( rem$ ) + else ( rem$ value$ key$ ) + 4drop ( rem$ ) + then ( rem$ ) + repeat ( adr len ) + 2drop ( ) +; + +: inject-tags ( -- ) + get-mfg-data + + " TS" ($delete-tag) + " MS" ($delete-tag) + " BD" ($delete-tag) + + " SHIP" " TS" ($add-tag) + + response$ parse-tags + + put-mfg-data +; + +: mfg-ntp-server ( -- name$ ) + " NT" find-tag if ?-null else " 10.60.0.2" then +; +' mfg-ntp-server to ntp-servers + +d# 4 constant rtc-threshold +: verify-rtc-date ( -- ) + ." Getting time from NTP server " + begin ntp-timestamp while ." Retry " repeat ( d.timestamp ) + cr + ntp>time&date unix-seconds> ( ntp-seconds ) + today unix-seconds> ( ntp-seconds rtc-seconds ) + - ( difference ) + dup rtc-threshold > if ( difference ) + page show-fail + ." Clock lost " .d ." seconds since SMT" cr + begin halt again + else + abs rtc-threshold > if + page show-fail + ." Clock gained " .d ." seconds since SMT" cr + begin halt again + then + then +; + +: finish-final-test ( -- ) + show-result-screen + + test-passed? 0= if + ." Type a key to power off " + key drop cr power-off + then + + wait-lan + wait-scanner + + get-info + + verify-rtc-date + + cifs-connect + ." Connecting to server " final-tag-exchange ." Done" cr + cifs-disconnect + + inject-tags + + ." Powering off ..." d# 2000 ms + power-off +; + + +d# 15 to #mfgtests + +: final-tests ( -- ) + 5 #mfgtests + 5 do + i set-current-sq + refresh + d# 1000 ms + doit + pass? 0= if false to test-passed? finish-final-test unloop exit then + loop + true to test-passed? finish-final-test +; + +\ Make the "wait for SD insertion" step highly visible +dev ext +warning @ warning off +: selftest ( -- ) page show-pass selftest ; +warning ! +dend + +\ This modifies the menu to be non-interactive +: doit-once ( -- ) do-key final-tests ; +patch doit-once do-key menu-interact + +: silent-probe-usb ( -- ) + " /" ['] (probe-usb2) scan-subtree + " /" ['] (probe-usb1) scan-subtree + report-disk report-net report-keyboard +; + +: scanner? ( -- flag ) + " usb-keyboard" expand-alias if 2drop true else false then +; +: wait-scanner ( -- ) + scanner? 0= if + " Connect USB barcode scanner" .instructions + begin d# 1000 ms silent-probe-usb scanner? until + then + ; +: wired-lan? ( -- flag ) + " /usb/ethernet" locate-device if false else drop true then +; +: wait-lan ( -- ) + wired-lan? 0= if + " Connect USB Ethernet Adapter" .instructions + begin d# 1000 ms silent-probe-usb wired-lan? until + then +; +: usb-key? ( -- flag ) + " /usb/disk" locate-device if false else drop true then +; +: wait-usb-key ( -- ) + usb-key? 0= if + " Connect USB memory stick" .instructions + begin d# 1000 ms silent-probe-usb usb-key? until + then +; +: wait-connections ( -- ) + silent-probe-usb + wait-scanner + wait-lan +\ wait-usb-key +; + +: fail-log-file$ ( -- name$ ) " int:\runin\fail.log" ; + +: after-runin ( -- ) + fail-log-file$ $read-file 0= if ( adr len ) + page + show-fail + ." Type a key to see the failure log" + key drop cr cr + list + else +\ set-tags-for-fqa +\ " int:\runin\olpc.fth" $delete-all + + 5 to test-station + true to diag-switch? + " patch final-tests play-item mfgtest-menu" evaluate + menu + \ Shouldn't get here because the menu never exits + then + + ." Type a key to power off" + key cr + power-off +; + +after-runin + +SN:SHC946009D3 +B#:QTFJCA94400297 +P#:1CL11ZU0KDU +M#:CL1 +LA:USA +CC:2222XXXXXX +F#:F6 +L#:J +S#:CL1XL00802000 +T#:TSIMG_V3.0.6 +WM:00-17-C4-B9-39-ED +MN:XO-1 +BV:Q2E34 +U#:A4112195-98FE-419A-A77B-9F33C08FF913 +SD:241109 +IM_IP:10.1.0.2 +IM_ROOT:CL1XL00802000 +IM_NAME:CL1XL00802000 +WP:0 +Countries:Alabama +LO:en_US.UTF-8 +KA:USInternational_Keyboard +KM:olpc +KL:us +KV:olpc +ak:0 +sk:20 +SG:79 +DT:20091124152811 + +SET WO=304027439 + +Use these info to check the tags inside the SPI flash. + +Write the following tags from response file: + +WP: +SG: + +Get date time from NTP server 10.1.0.1 and write MD tag + MD: 20081014T200700Z + +Set TS tag to SHIP + +Send the following information to shop flow + +SN: +M#: +U#: +P#: +B#: +LA: +CC: +F#: +L#: +S#: +T#: +BV: +TS: +SS: +FQ: +SD: +WM: +MN: +KL: +KV: +KM: +LO: +WP: +RESULT:PASS + + +
